Spinnaker question #11446
10/07/02 10:05 PM
10/07/02 10:05 PM
PSAILOR Offline OP
PSAILOR  Offline OP
I was wondering about the differance between the symetrical and asymetrical spin. I see that most cats use am asym. spin, and I also saw that the trapseat spin is a symetrical spin. Can a cat use a symetrical spin? will it do any good? I actually have an old symetrical one from a monohull and enough parts to rig it up on my cat. I was thinking of setting it up mainly for fun, it would be cool to try even if it did not provide to be any great benifit.
Could a symetrical spin be used? would the set-up be different from the asymetrical one??
Many thanks for your input!!
Re: Spinnaker question [Re: PSAILOR] #11447
10/08/02 06:17 AM
10/08/02 06:17 AM
Key Largo, FL
MaryAWells Offline
MaryAWells  Offline
Key Largo, FL
For people to give you intelligent answers, you need to let them know what kind of boat you have. It would make a difference as to whether they would recommend symmetric or asymmetric. A Hobie 16, for example, usually sails straight downwind rather than tacking downwind -- or at least tacks downwind at very deep angles. So it might be more likely to benefit from a symmetrical spinnaker. Cats with daggerboards or centerboards that tack downwind at greater angles and have more leeway resistance benefit more from an asymmetric spinnaker.
Maybe rephrase your question with boat type.
Mary A. Wells
Re: Spinnaker question [Re: MaryAWells] #11448
10/08/02 08:45 AM
10/08/02 08:45 AM
PSAILOR Offline OP
PSAILOR  Offline OP
OOPS!
My boat is a P16
Re: Spinnaker question [Re: PSAILOR] #11449
10/08/02 01:15 PM
10/08/02 01:15 PM
MI
sail6000 Offline
sail6000  Offline
MI
Hi
Yes ,-you can experiment with a fuller symetrical spin .
set it up and have fun .
The assymetric kites were developed for faster sailing craft
{like cats}that can readily build apparent wind by reaching moreso or sailing at higher angles to the true wind direction while keeping a certain degree of attached flow around them.. Because of the boats high speed movement and higher angles it sails both faster and progressively lower angles downwind .
As the boat builds speed the apparent wind moves forward allowing you to bear off downwind more at higher speeds .A boat sailing downwind with the sails stalled --{without attached flow around them } --will sometimes be traveling at half the speed of a cat sailing with attached flow ,--again as this skipper initially reaches up and gains flow they are able to progressively sail a lower course at this speed and new lower angle due to apparent wind the boats speed has built up .
A sysemtrical kite will let you reach to some extent ,but is much more limited than the assymetric kite designed for this purpose .
hope that helps -
wish I had a little better command of language ,
here learning also -
take care
Carl
Re: Spinnaker question [Re: sail6000] #11450
10/08/02 06:52 PM
10/08/02 06:52 PM
O.K....but how do you manage the need for a spinnaker pole and gybing a symetrical spin on a cat?
Re: Spinnaker question [Re: Jake] #11451
10/08/02 09:02 PM
10/08/02 09:02 PM
toronto, canada
basket.case Offline
basket.case  Offline
toronto, canada
blocks on the bow and run it like a drs. float the tack between the two bows.
Re: Spinnaker question [Re: Jake] #11452
10/09/02 10:20 AM
10/09/02 10:20 AM
Fulshear, TX
SGalway Offline
SGalway  Offline
Fulshear, TX
You could gybe the same way you gybe the pole on small dinghies. Bungie pole return system alongside the boom and you are done. Takes a little practice and momentary low angles to bring the chute around, but it's done all the time.
However, I don't think a cat is the place for a sym chute. I don't think you will be able to get low enough (without a huge degree of apparent wind) to really use the sail like it wants to be used. What you gain with the sym chute, you loose by your main not being about to sail that low.
Shannon Galway
Fulshear, TX
YoNav! Flying Phantom
www.yonav.net
0 registered members (), 399 guests, and 47 spiders.
