Cracked rudder #114555
08/13/07 06:22 PM
08/13/07 06:22 PM
Lindale, Texas Inland freshwa...
Wallybear Offline OP
I realized recently that the right hand rudder has a crack that is about 8" in length. What is the best method of repairing this crack? My idea is to grind down about 3/16" deep the length of the crack, approximately 2" on either side of crack and on both sides of the rudder, then fill crack with epoxy using syringe and build back up with several layers of glass and epoxy, sand flush and paint. Will this work or is there a better alternative short of buying a new rudder?
Please see attachment.
Thanks,
Walter
Re: Cracked rudder [Re: Wallybear] #114556
08/13/07 06:36 PM
08/13/07 06:36 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
Buy a new to you rudder...
Re: Cracked rudder [Re: Wallybear] #114557
08/13/07 06:41 PM
08/13/07 06:41 PM
That's a Lexan rudder.
Nothing sticks to it for very long. Epoxy / fiberglass is brittle in comparison and the different elasticity will eventually cause them to separate.
You could try pinning it together (think orthopedics), but your bet bet is to replace it.
Re: Cracked rudder [Re: Wallybear] #114558
08/13/07 06:56 PM
08/13/07 06:56 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Try crack spackle.... Plumbers use it to fill their cracks.
Re: Cracked rudder [Re: mbounds] #114559
08/13/07 07:36 PM
08/13/07 07:36 PM
OOPS! I was guessing it was fiberglass, but if it is lexan, your right, glassing would not work. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> Thanks. On to plan B.........whatever that may be.
Re: Cracked rudder [Re: Wallybear] #114560
08/14/07 02:50 AM
08/14/07 02:50 AM
Bernhards Bay, N.Y.
popeyez7 Offline
popeyez7  Offline
Bernhards Bay, N.Y.
it's gonna break sooner or later,, might as well replace it!!!!!!!!!
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION''
~17,18 Hobies,
~Jet boat~Speedster 150
~2 Kayaks~
~~~~VIETNAM VET. 69-71~~~~
0 registered members (), 426 guests, and 47 spiders.
