| Re: formula 14 +
[Re: warbird]
#114595 08/15/07 06:50 AM 08/15/07 06:50 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | You can definitely overpower the H14 type boats as you pointed out -- not much freeboard or buoyancy. At the Spring Fever two years ago we had an F14 class, with two or three H14s and my Wave. When the wind picked up, they were a bit faster with their Hooters, but both H14s in the class capsized. No problem with the Wave with Hooter.., and I could have added a lot more sail area. Haven't had much time to do so, but I had plans for a huge Hooter, fairly large self-tacking jib. Every time I used it, it was screaming, but broke something every time (bow sprit exploded from the load one time). Still on the drawing board. Rick | | | Re: formula 14 +
[Re: David Parker]
#114597 08/15/07 12:35 PM 08/15/07 12:35 PM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Well, the one I am presently using is tried and has proven faultless. No breakage, good speed upwind and off the wind. When first playing with it I was fearful of having the halyard turning block to high. But, after test, found when it was lower, the speed was better, but would not live up to the handicap hit. So, I finally went masthead and it made all the difference in the world. The rig in the following link is what I presently recommend. http://store.catsailor.com/tek9.asp?pg=products&specific=jmnrkomnk0As I said, If I could get the longer pole to work with the self-tacking jib, it would be really hot. For about a half mile I was staying with a Hobie 20. Rick | | | Re: formula 14 +
[Re: warbird]
#114598 08/15/07 05:30 PM 08/15/07 05:30 PM |
Posts: 9 chesapeake, VA | I have sailed the Windy14 and the Nacra 14sq a lot. I think that following the H14 development and the Maricat style would be the most sensible thing to do. Check the two attachaments...that Maricat sail isssswweeeeeet for for an older boat. The Windy is a boat challenged by it's date of design and simply adding cloth might not help. Way more mast rake, square top and mast head reacher would be a good bet.
Taking great care to lighten the rig would do the boat a lot of favours as it has very little boynacy and freeboard.I am clear that if you got the Nacra sail and mast that it would just overwelm the Windy. hey thats my boat:):):):)the blue one is mine and the white one's dans bergers | | |
1 registered members (FredL),
2,799
guests, and 283
