New Trap...??? #115669
08/26/07 11:56 PM
08/26/07 11:56 PM
IL, WI, MI
BowtieWarrior Offline OP
IL, WI, MI
Ok guys I need a new Trap for my H 16... does anyone have a Black one? if so how is it? How about a trap wiht a hicker foot straps? good bad? what about rope bag? who has what and how do they like it?
2nd unrelated question... I am about 250 and I sail with my buddy he is about 130 is it possible to get on one hull? or will the boat just sink...????
Thanks guys.
Joe
Hobie the only way to fly!
Re: New Trap...??? [Re: BowtieWarrior] #115670
08/27/07 12:32 AM
08/27/07 12:32 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
I think that you must mean a tramp... the trap is the system that allows you to trapeze off the side of the boat.
I have a black tramp on my Nacra 5.2 and it is nice. I figured it owuld get hot but it never really does.
I am not sure about the 16, but I know on the Hobie 14 you definently need hiking straps.
Once again I am no Hobie 16 expert but in my mind you all should be able to fly a hull but it will take some pretty serious wind.
Re: New Trap...??? [Re: gree2056] #115671
08/27/07 11:19 PM
08/27/07 11:19 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
380 lbs is a lot for a H16. It pushes the leeward hull deep in the water, slowing it, and making it prone to sticking the lee bow when pushed. But can be done with skill.
Black mesh tramps are quite durable, may need to be restitched occaisionally (spend money on teflon thread, it lasts longer). Hiking straps sewn to the tramp are an absolute must to be able to hike out(lean outward) from the tramp. Hiking from the tramp with 380 lbs might easily require 20+ knots of wind to fly a hull. More to fly a hull trapezing. Could be wild!
I enjoyed the 16 the most as a solo boat, which seemed the best way to keep the weight far enough aft. I had a footstrap mounted as far aft as possible on each hull, and felt really secure and in control, solo on the wire.
Dave
Re: New Trap...??? [Re: davefarmer] #115672
08/28/07 08:46 AM
08/28/07 08:46 AM
brucat Offline
brucat  Offline
Buy a Hobie tramp. They are worth every penny (and are required for racing). You will definitely want the hiking straps, because you'll mostly be single-trapping (crew only), and you'll want to be able to hike out.
I sail at the same weight as you. Takes a bit more wind to single-trap the crew (10-12 kts), more to double-trap (14-15 kts), but you can DEFINITELY fly a hull. You can actually do OK in light air. The moderate stuff is where you have no chance when racing against lightweights... <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Hope this helps.
Re: New Trap...??? [Re: brucat] #115673
08/28/07 11:15 PM
08/28/07 11:15 PM
IL, WI, MI
IL, WI, MI
Thanks guys and Yes I did mean Tramp.. Sorry.
I was kinda worried that flyin one hull at my weight was not going to happen but we will see.. if I can ever get any decent days to go out on the boat before it gets cold!!!
Could some one explain the mess tramp to me or possible pictures?
Thanks.
Re: New Trap...??? [Re: BowtieWarrior] #115674
08/28/07 11:24 PM
08/28/07 11:24 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
There are two materials that tramps are made of regularly. One is the vinyl like hobie tramps. They are waterproof and water pools on them, also you can't see through them. Also they are the only tramps allowed for hobie regattas.
The Mesh tramps are made of the same stuff that kids trampolines are made of. water can splash through them and you can see through them.
Re: New Trap...??? [Re: gree2056] #115675
08/29/07 04:34 AM
08/29/07 04:34 AM
Kennethsf Offline
Kennethsf  Offline
The mesh material is called permatrom or something, made by Ten Cate /Bayer, it is produced in the US somewere.
It is used for kids trampolines and coastal protection [to keep the rocks in place at stone barrier, it is used in the farming industry as well
If you are a DIY-guy try to find the fabric at an industrial supplier[saves you a lot of $$$]
Re: New Trap...??? [Re: gree2056] #115676
08/29/07 06:09 AM
08/29/07 06:09 AM
Hobie makes both vinyl and mesh tramps and they are both legal for racing. They are competitively priced and are RF welded, not stitched - a process that can not be duplicated by the do-it-yourself-er.
Re: New Trap...??? [Re: mbounds] #115677
08/29/07 01:45 PM
08/29/07 01:45 PM
IL, WI, MI
IL, WI, MI
Well I have a Sky blue ragady tramp now.. and I want to get a new one for next season so I am thinking black.. but I am kinda unsure about the few that are on ebay for cheap what do you guys think? Ebay Hobie 16 Tramp Black
Re: New Trap...??? [Re: BowtieWarrior] #115678
08/29/07 04:18 PM
08/29/07 04:18 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
I don't want to talk smack on the Amish, but as Mbounds said these tramps are sewn not RF Welded, and will last about 1/4 the time that a Hobie tramp will. Also the material is different. If you look closely at one of these after-market tramps the material is woven, whereas the Hobie material is all one piece- like it's been coated. The after-market tramps are priced right though.
Your blue vinyl Hobie tramp is probably from the 80's? That' a pretty good lifespan I'd say. Stick with the factory one.
Go here to find an OG Hobie one:
http://www.hobiecat.com/company/dealer.html
Re: New Trap...??? [Re: SurfCityRacing] #115679
08/29/07 04:43 PM
08/29/07 04:43 PM
California
mmiller Offline
mmiller  Offline
California
Just to be clear...
The Hobie trampolines are all vinyl coated materials.
Solid or mesh styles, but all vinyl and both heat and sonic welded.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: New Trap...??? [Re: SurfCityRacing] #115680
08/29/07 04:50 PM
08/29/07 04:50 PM
IL, WI, MI
IL, WI, MI
as for the factory hobie tramps do they come in colors or just in white?
Re: New Trap...??? [Re: BowtieWarrior] #115681
08/30/07 03:16 PM
08/30/07 03:16 PM
IL, WI, MI
IL, WI, MI
so I called and checked on the prices of "real" hobie Tramps.. and they are a little pricey 320 and 427 for mesh.. thats a little steep.. and the guy at the shop said that the mesh tramps can make it a little easier to keep flying a hull becasue it lets the wind through...?
Re: New Trap...??? [Re: BowtieWarrior] #115682
08/30/07 03:49 PM
08/30/07 03:49 PM
Don't believe everything you hear.
Re: New Trap...??? [Re: Jake] #115683
08/30/07 03:53 PM
08/30/07 03:53 PM
IL, WI, MI
IL, WI, MI
I've herd that before ha ha well I am sure its a ploy for selling the more expensive tramp but what can ya do..
I am not sure I want an all white tramp tho.. how are the mesh tramps wiht weight on them? I normally stand on my tramp to raise the mast will the mesh tramp support the load?
Re: New Trap...??? [Re: BowtieWarrior] #115684
08/31/07 12:32 PM
08/31/07 12:32 PM
Clinton, Mississippi
rattlenhum Offline
rattlenhum  Offline
Yes....at least my 9 year old factory tramp does.
Jerome Vaughan
Hobie 16
Clinton, Mi'sippi
Re: New Trap...??? [Re: rattlenhum] #115685
08/31/07 12:45 PM
08/31/07 12:45 PM
IL, WI, MI
IL, WI, MI
is your 9 yr old factory a mesh tramp?
Re: New Trap...??? [Re: BowtieWarrior] #115686
08/31/07 01:17 PM
08/31/07 01:17 PM
Gang:
I have a 6 year oldor more sunrise mesh that looks brand new. They are TUFF!!!!!! Wings show no sign off wear.
Doug
Re: New Trap...??? [Re: BowtieWarrior] #115687
08/31/07 01:28 PM
08/31/07 01:28 PM
you should EASILY expect to stand on the trampoline to step the mast. This is standard load bearing use.
Re: New Trap...??? [Re: BowtieWarrior] #115688
09/04/07 12:52 PM
09/04/07 12:52 PM
rattlenhum Offline
rattlenhum  Offline
Yes.
Jerome Vaughan
Hobie 16
Clinton, Mi'sippi
0 registered members (), 18,403 guests, and 1,082 spiders.
6 hours ago
