Bridle wire tension #115705
08/27/07 12:03 PM
08/27/07 12:03 PM
Chattanooga, TN
jody Offline OP
jody  Offline OP
Chattanooga, TN
Noticed this weekend that with no sails up the bridle wires were somewhat slack, even with the cat on beach wheels with the bows up. The psudo bridles were tied loose. The tension appeared to be mostly on the pole at the bottom of the pelican striker. With the sail up and sheeted the wires appeared to be tight. The discussion came up about changing to a slightly shorter shackely to see if this would change anything. Anyone have any thoughts on this.
thanks
Jody Blade F16 724 Plays with Sharp Objects
Re: Bridle wire tension [Re: jody] #115706
08/27/07 12:23 PM
08/27/07 12:23 PM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
Isn't this indicating a need for tightening at the sidestays? A loose forestay would allow the prebend to come out of the spinnaker pole, slackening the bridle wires. Or so it seems.
Re: Bridle wire tension [Re: jody] #115707
08/27/07 05:14 PM
08/27/07 05:14 PM
I would tighten the shrouds to get rid of the slackness of the bridle wires.
Can someone measure the bridle wire length for me?
Bored and got 1/8 spectra sitting around <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
0 registered members (), 360 guests, and 32 spiders.
