Page 1 of 3 1 2 3
What limits your speed? #115925
08/29/07 05:30 PM
08/29/07 05:30 PM
Norman,OK
gree2056 Offline OP
gree2056  Offline OP
Norman,OK
There has been a discussion going on the wave forum about what the limiting factor for speed on these boats.
On my 5.2 sailing solo I always thought the limiting factor was being able to hold the boat down. I have to start spilling air out of the sails long before the lee hull starts to dig in to deep.
But in some posts people have said that their limiting factor is the lee bow diving.
So what is it, does it differ by boat?
Re: What limits your speed? [Re: gree2056] #115926
08/29/07 06:42 PM
08/29/07 06:42 PM
Santa Fe, New Mexico, USA
WillLints Offline
WillLints  Offline
I am no nautical architect but there is always hull speed which clamps the speed at a certain point unless you can get the boat to plane, or if it heals then the hull speed changes, also flying a hull changes the hull speed. You can move your weight to the rear in order to get the nose to come up, just like surfing. Also, raking the mast back will keep the bows up longer.
Will_Lints
one-up, Blade 706, epoxy bottoms
Re: What limits your speed? [Re: WillLints] #115927
08/29/07 11:59 PM
08/29/07 11:59 PM
ncik Offline
ncik  Offline
Raking the mast has little to no effect on nose-diving, upwind or downwind.
Except that for slower boats that can't sail with the apparent wind off the breeze, raking forward lets the sails "breath" and generates slightly more power, which creates a greater pitching moment. This is only relevant for slower boats like one & two sail dinghies which don't generally have to worry about nose-diving anyway because they are fat.
Generally speaking, resistance, power and control will limit your speed.
Why do you need to de-power when your hull starts flying?
Re: What limits your speed? [Re: gree2056] #115928
08/30/07 08:45 AM
08/30/07 08:45 AM
Houston
carlbohannon Offline
Houston
In general the limiting factor is hull speed. Multi-hulls have a hull speed, just like monohulls, the constants in the formula are just a little different.
For a displacemt hull:
hull speed ~= constant* square root of the waterline lenght
That constant is proportional to the ratio of the waterline length and waterline width. If you make the hulls long and thin enough then they start acting like foils and anouther set of rules take effect.
Based on GPS logs over the last few years the maximum speed:
Hobie Wave ~22kt (very scary, wants to go in every direction)
Custom 14 _~24 kts (wants to pitchpole)
Tornado ~26 kts (wants to pitchpole)
Marstrom A ~28 kts (stern squats)
Hobie 18 ~24 kts (rudders cavitate)
These speeds are probably +/- 1-2 kts, they are just something the analysis programs spits out. I have only really looked hard at the 14 data.
A really cool test would be to test the top speed of your boat and then stick your rig (mast and sails) on an iceboat and test the top speed of your rig.
Re: What limits your speed? [Re: ncik] #115929
08/30/07 08:54 AM
08/30/07 08:54 AM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
One of the most commonly given answers to pitchpoling a h16 is to rake the mast aft. Am I missing something here?
Thanks
Sam
[b] Sail Like you have a Pair
Re: What limits your speed? [Re: Banzilla] #115930
08/30/07 09:24 AM
08/30/07 09:24 AM
Rake was for the other p word...point
Have reached cavitation on the 18 and this or ventilation (or something?) on the 20 as well and let me tell you IT IS VERY SCARY
Re: What limits your speed? [Re: gree2056] #115931
08/30/07 10:17 AM
08/30/07 10:17 AM
C
Commodore_CCC Offline
C
Bohannon is the only one who gets it.
Suggest reading Bethwaite's "High Performance Sailing" for an exhaustive, ACCURATE answer.
Raking changes the centre of effort which will have an effect on heeling moment and pointing ability.
Pitchpoling, in a nutshell, comes from the boat being ultimately overpowered. Bethwaite's answer is to get the boat out the water (planing, or foils). Or, I suppose, you could lengthen your bows.
And beachcat rudders would VERY seldom cavitate (create low pressure enough such that air 'boils' out of the water).
They VENTILATE (drag air down the edge, side, wherever of the rudder such that the rudder 'dissociates' from the water around it.)
Re: What limits your speed? [Re: carlbohannon] #115932
08/30/07 11:13 AM
08/30/07 11:13 AM
srm Offline
srm  Offline
>>If you make the hulls long and thin enough then they start acting like foils and anouther set of rules take effect.<<
Not really sure what you mean by this statement. "Act like foils"?? All surfaces traveling through a fluid are subject to the same set of rules. They will all experience forces parallel to and in the opposite direction of the flow (drag) as well as forces perpendicular to the flow (lift) dependant on incident angle.
Actually a shorter and wider hull is more efficient at producing vertical lift (similar to a hyrodfoil). To get an idea of this, look at modern Formula Windsurf boards. Extremly short and wide and are considered to be very high-aspect and efficient planing surfaces.
sm
Re: What limits your speed? [Re: srm] #115933
08/30/07 11:46 AM
08/30/07 11:46 AM
SC
zander Offline
zander  Offline
SC
To answer our question, My poor sailing ability limits my speed. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Always borrow money from a pessimist. He won't expect it back.
Re: What limits your speed? [Re: zander] #115934
08/30/07 02:02 PM
08/30/07 02:02 PM
H
hobie17guy Offline
hobie17guy  Offline
H
A MEN, Zander,
That and the amount of bulge in my pants.
Re: What limits your speed? [Re: hobie17guy] #115935
08/30/07 02:44 PM
08/30/07 02:44 PM
A MEN, Zander,
Whoaaaa! Hey, that's too much information.
Re: What limits your speed? [Re: Banzilla] #115936
08/30/07 06:32 PM
08/30/07 06:32 PM
ncik Offline
ncik  Offline
Sorry, a better answer would be that rake should be set for upwind/downwind performance before being set to prevent nose-diving as its effect on nose-diving is practically nothing.
The only influence on nose-diving that raking the mast aft has is to move a little bit of weight aft (mast and mainsail) and very slightly depower the rig (in a similar way as sheeting the main in downwind). Both these influences would be close to immeasureable and would be far outweighed by a rig tuned for upwind/downwind performance.
PS. The reason I say upwind/downwind performance is because H16's don't have kites so the rig should be raked for performance over the whole course, not just upwind. I'm sure there are tuning guides out there with the optimal rake for certain conditions.
Re: What limits your speed? [Re: gree2056] #115937
08/30/07 10:44 PM
08/30/07 10:44 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
...I always thought the limiting factor was being able to hold the boat down. I have to start spilling air out of the sails long before the lee hull starts to dig in to deep. But in some posts people have said that their limiting factor is the lee bow diving.
I guess you want to know if the limiting factor is the max roll torque or the max pitch torque. In this case, the limiting factor depends on each boat's geometry, mainly the beam size and bow volume.
- Large beams mean lots of roll torque resistance - the boat buries the bow before capsizing.
- Large bow volume mean lots of pitch torque resistance - the boat capsizes before burying the bow.
An ideal design would always reach both limits at the same time, but in practice this is impossible to achieve. The same boat may be capsize prone in certain conditions and pitchpole prone in other conditions.
Luiz
Re: What limits your speed? [Re: gree2056] #115938
09/02/07 02:51 AM
09/02/07 02:51 AM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Hull speed. At some point cats either have to take planing more seriously or start foiling. I prefer the planing option.
Re: What limits your speed? [Re: gree2056] #115939
09/02/07 03:53 AM
09/02/07 03:53 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
too much cake
Re: What limits your speed? [Re: warbird] #115940
09/02/07 01:26 PM
09/02/07 01:26 PM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
This has been done to death before, but "Hull Speed" is a bit of a red herring when it comes to cats. The idea of "Hull Speed" is a rule of thumb that applies to hulls that are primarily limited by wave drag. Beach cats are primarily limited by skin drag. So, whilst you can adjust the constant in the "hull speed" formula to something appropriate for the shape of a cat hull, and that will tell you something about the wave drag of the hull, it still doesn't give you a limit on the hull speed because wave drag is not the dominant factor.
To answer the original question, I think it depends on the conditions as well as the boat. I haven't sailed many different types of boat, but my experience on F18 and F16 is that in flat water with a steady wind the limit will be righting moment i.e. you won't be able to hold it down. With waves or gusty weather, it'll be bouyancy in the bows that's the limiting factor. Then again, flat waters with very strong, steady winds are hard to find, and normally we're chasing VMG not straight line speed, so this may not be correct.
Re: What limits your speed? [Re: pdwarren] #115941
09/02/07 03:39 PM
09/02/07 03:39 PM
Agree with Paul, but there are other isses as well.
"rig" drag also comes into the mix. A low drag (but high power) rig will be better assuming other issues remain constant; but in lighter wind, power (fuller sails) does create drag.
Aspect ratio of plates is also a consideration, as is angle of attack and lift created.
Re: What limits your speed? [Re: scooby_simon] #115942
09/02/07 06:45 PM
09/02/07 06:45 PM
ncik Offline
ncik  Offline
Info - Hull speed for a 16' boat is about 5.4 knots.
Hull speed for an 18' boat is about 5.7 knots.
Hull speed is not an inpenetrable brick wall, it is a hump that requires a bit of effort to get over (literally and figuratively).
Re: What limits your speed? [Re: ncik] #115943
09/02/07 06:54 PM
09/02/07 06:54 PM
Norman,OK
gree2056 Offline OP
gree2056  Offline OP
Norman,OK
I do not feel that hull speed is a factor in cats, but I am not one to talk,
Re: What limits your speed? [Re: gree2056] #115944
09/02/07 07:15 PM
09/02/07 07:15 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
"Hull speed" (Froude's law) is ok for displacement boats that sail between two waves, unable to pierce or surf the front one. It is irrelevant for beach cats.
Besides stability, the other limitations are: the maximum power made available by the sails and the total drag.
Friction drag (a function of wetted area) is the main responsible for the increase in drag when beach cats sail at high speeds.
Luiz
Page 1 of 3 1 2 3
0 registered members (), 15,933 guests, and 384 spiders.
Yesterday at 04:54 AM
