| Re: spin halyard...where?
[Re: mitch]
#116074 09/02/07 07:27 PM 09/02/07 07:27 PM |
Posts: 902 Norman,OK | The usual advice is 1/3 of the way above where the shrouds attach... but with the comptip.... I am not sure. Can you attach stuff to the comptip without it exploding?
[Re: gree2056]
#116075 09/02/07 08:22 PM 09/02/07 08:22 PM | Anonymous
| Anonymous
Unregistered | Mitch:
Be careful. I was going to put a Hooter on my 17, but they told me it would break mast. Try to find a 18 SX to look at. Don't they have a spin?
Doug | | | Re: spin halyard...where?
[Re: mitch]
#116076 09/02/07 09:53 PM 09/02/07 09:53 PM |
Posts: 3,969 | I looked at the parts diagram on Hobiecat.com, it's not obvious. I was hoping to see an 18SX-specific mast or comptip, but no dice.
Per the class rules (hobieclass.com), Hobie 18SX Rule 14 b): "The [spinnaker] sail cannot be attached to the mast above 23 ft. 11-1/2 in. (7.30 meters) measured from the bottom of the mast extrusion."
I believe that the only difference between an 18 mast and an 18SX mast is the comptip (the 18SX is longer). Matt Miller or the guys at Surf City might chime in here, but I'm very certain that there was an upgrade kit at one time to upgrade a standard 18 to an 18SX, and it included the wings, sails, rigging, and longer comptip.
If this is true, measure your current 18 mast, find the place where 23 ft. 11-1/2 in from the bottom puts you, and maybe go a little lower. I'm fairly sure they are rigged from the comptip.
Hope this helps.
Mike | | | Re: spin halyard...where?
[Re: brucat]
#116077 09/02/07 11:12 PM 09/02/07 11:12 PM | Anonymous
| Anonymous
Unregistered | | | | Re: spin halyard...where?
[Re: gree2056]
#116079 09/03/07 03:22 AM 09/03/07 03:22 AM |
Posts: 9,582 North-West Europe | The usual advice is 1/3 of the way above where the shrouds attach...
This is not true. This was the advice that the designer of the Supercat line, Bill Roberts, gave to everyone. However nearly as goood as all other designers (and therefor designs) have the spi gate at 60% of the distance between hound fitting and mast top. In effect: It your mast is 8.5 mtr long and your hound fitting is at 6.0 mtr. then the spi gate will be at (8.5-6.0)*0.6 + 6.0 = 7.5 mtr. This distance is also used on the F18's, F20's (inter-20) and the F16's to name but a few well know cat types with a spinnaker. Wouter
[Re: brucat]
#116080 09/03/07 01:46 PM 09/03/07 01:46 PM |
Posts: 606 League City, TX | Hobie 18 with comp tip, where do i put the spin halyard block on the mast, how high up and is it o.k. to put it on the comp tip section? thanks
It is OK to put in on the comptip. Follow the Hobie installation advice - which gives a postion about 1/3 the way up the comp tip. Higher than that and you are really overstressing it without the addition of mast heads shrouds to stabilise the comptip. Don't cut your pole as short as Hobie suggests - this results in a very narrow slot between the spinnaker and jib. Go about 11' long. You will have to mount the spin blocks somewhere between the rear cross beam and the side shrouds to get the correct sheeting angle (assuming you have the Hobie factory kite). Make up some stainless slugs to fit under the lip and through bolt into them to distribute the load. Not class legal - but who cares unless you'll be in a fleet of class legal H18s with spinnakers. Good luck with your project! I looked at the parts diagram on Hobiecat.com, it's not obvious. I was hoping to see an 18SX-specific mast or comptip, but no dice.
Hope this helps.
Mike Hobie 18/18SX parts manual shows different part numbers for the mast extrusions (the 18SX is 18" longer but the same section as the stock 18 mast). The comp tip is the same part number for both boats. I've owned both boats and can confirm they use the same comptip. To upgrade an 18 to an 18SX takes a new mast section, rigging, sails. Chris. | | | Re: spin halyard...where?
[Re: flumpmaster]
#116081 09/03/07 02:08 PM 09/03/07 02:08 PM |
Posts: 3,969 | Thanks for clarifying this Chris. I just re-looked at the Hobie site. There are two links to Hobie 18 parts diagrams, and they lead to different pictures and parts lists... The one you linked to makes a little more sense than the other one that I found: http://www.hobiecat.com/support/tech/h18parts.html I still don't see two masts listed in this diagram. I am really surprised that they made the upgrade require a new aluminum section (as opposed to a different comptip). I guess I had bad local knowledge. (Someone in our fleet was considering this upgrade years ago.) Is the aluminum cheaper than the comptip? It sounds like a lot more work if you have to transfer all the fittings, spreaders, etc. to new aluminum mast AND deal with the comptip, as opposed to just changing the comptip. Not that any of this answers the original question... Mike
[Re: wildtsail]
#116083 09/03/07 08:31 PM 09/03/07 08:31 PM |
Posts: 606 League City, TX | I'm not sure the newer style halyard bails would work as the mast track isn't too strong. I agree - I'm sure it would not work. The upper part of the 18 mast track is a plastic extrusion that snaps onto the back of the comptip. If you tried to tie a bail line through it it would snap. I also just riveted a stainless tang to the mast and hung a block from it. Chris. | | |
2,857
guests, and 161
