| Re: Nacra 20 mast question
[Re: Todd Berget]
#116237 09/05/07 04:18 PM 09/05/07 04:18 PM |
Posts: 1,203 uk | The bolts underneath are just to stop the spanner from drooping. assuming that you have a carbon mast, fill the holes with epoxy filler [colloidal silica] and redrill. Actually by saying redrill, that would mean undoing the bolts - then they drop into the mast. just fill around the spanner bolts [tape up the threads to keep them clean].
paul
[Re: TEAMVMG]
#116238 09/05/07 04:20 PM 09/05/07 04:20 PM |
Posts: 833 St. Louis, MO, | I believe the purpose of the lower bolts is to keep the rotator arm from hitting the boom. So in other words they are just there as a stop.
I've also heard of this problem. You might check with your dealer to see if they have a kit to fix. Otherwise your plan to put some stainless on the mast is a good one.
Mike Hill
Mike Hill N20 #1005
[Re: Mike Hill]
#116239 09/06/07 07:17 AM 09/06/07 07:17 AM |
Posts: 1,304 Gulf Coast relocated from Cali... | I had the same problem with mine. The bolts are attached to a plate on each side to spread the load. It's really a crappy design. The plate from Performance Cat for fixing it is just a bandaid. The whole design should never be used on a carbon mast in the first place without a compression sleeve. I re-located the rotator arm to the base like the F18's and Tornados and had a grommet installed on the trampoline and have never been happier. If you do this, put some 5200 around the bolts and re-tighten them so your mast will stay sealed. Good luck. Lee
Lee
3,195
guests, and 376
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
