Page 4 of 4 1 2 3 4
Re: Tornado Question [Re: Hakan Frojdh] #116502
09/12/07 05:53 PM
09/12/07 05:53 PM
The wind is blowing 15 knots and you are sailing an A-class upwind with full depower on the main (you are trapezing in 6 knots of wind on the A-class). Then add a 5 m2 jib which gives you more stuff (you don't need) to drag around. Will this be faster??
Yes, for the simple reason that with a jib you will be concentrating more drive low in the rig. Exactly what you want when you are overpowered.
I'm surprised that you didn't pick up on this yourself.
For the readers understanding mathematics [Re: Wouter] #116503
09/12/07 06:17 PM
09/12/07 06:17 PM
For the readers understanding mathematics here a numerical example of why a sloop rig is favoured when overpowered.
The boat :
mast height = 100%
mainsail centre of effort = 45% up the mast.
mainsail sail area = 100%
hound fitting = 75 % up the mast
jib sail area = additional 25%
jib sail centre of effort = 1/3 of hound fitting height = 25% up the mast
Uni-rig :
heeling moment = 100% * 45% = 4500 (no % as it will have no meaning here) = say 100 %
drive = 100 %
Sloop rig (added jib) :
heeling moment = 100% * 45% + 25% * 25% = 5125 translates into 5125/4500 = 114 % = say 115 %
drive = 125 %
Now lets say you keep the jib fully power-up but depower the mainsail to correct for the extra heeling moment.
Basically you want to find X in the equation : X % * 45% + 25% * 25 % = 4500 ( = 100 %)
We find X = 86 % ; basically you need to depower the mainsail down to 86 % drive over its full length to total compensate for the added heeling moment of the jib.
But if we now add all the drive precentages together we find that :
Uni-rig drive = 100 %
Sloop rig drive = 86 % + 25 % = 111 %
We can redo this calculation for any new (overpowered) drive percentage (smaller then 100%) and each time the sloop rig will come out increasingly better.
example :
take uni-rig mainsail drive = 80 %
Heeling uni rig then becomes : 80 % * 45 % = 3600
Mainsail drive on sloop rig : X% * 45 % + 25% * 25 % = 3600 <=> X = 66 %
Total Sloop rig drive becomes : 66 % + 25 % = 91 % <=> 91%/80% = 114 % that of the uni-rig.
With each lower percentage for the uni-rig mainsail drive (more overpowered) the advantage of the sloop rig grows larger. For 50 % uni mainsail drive we find a ratio between created drive to be 61%/50% = 122 %
And there you have it. Adding a jib to an existing mainsail creates more drive then just having the mainsail even when sailing overpowered in a squall.
And with this numerical example we also have found what the minimal gains of adding a jib are over a wide range of conditions.
In light laminair winds : no net gains (Jib is suituated too close to watersurface to catch much wind)
In light but turbulant winds : 25 % additional drive
Medium winds (fully powered up) : 11 % additional drive (lowest value reached when in turbulant winds)
Strong winds (depowering mainsail) : up to 25 % additional drive
Re: Tornado Question [Re: Wouter] #116504
09/12/07 07:38 PM
09/12/07 07:38 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Bollocks.
Re: For the readers understanding mathematics [Re: Wouter] #116505
09/13/07 01:09 AM
09/13/07 01:09 AM
North Europe, Sweden, Uppsala
Hakan Frojdh Offline
You need to refine your model a bit and add the extra drag that the jib gives you. You have a lower aspect ratio sail jib+main than the main alone, and more area of the sail wich is disturbed from the eddies at the ends.
I have several cases where the M20 uni proved to be faster on the upwind compared to Tornado, M20 sloop and Eagle cat. My examples are based on intervies with Marstrom on different occasions. That proves that your model needs to be refined.
Can you point out cases where the M20 uni was passed by an
M20 sloop, Eagle cat or Tornado on the upwind? Don't start talking about finishing times in Texel again!
I think it's time for you F16 guys to do some testing. Sail the boat single handed and uni rigged upwind in 15 knots of wind together with a referens F16. Add the jib to the single handed boat and test again.
/hakan
Re: For the readers understanding mathematics [Re: Hakan Frojdh] #116506
09/13/07 05:23 AM
09/13/07 05:23 AM
Read your literature (Marchaj, Gentry and others). There is no extra drag due to adding the jib. That is another misconception. Interaction between the jib sail and mainsail results in a situation where the increase in drive is about proportional to the increase in total sail area. The only pay back is found in some lost of pointing angle (but less then you would expect) and in very light laminair winds (winds below 5 knots) where any area far away from the watersurface experiences much higher windspeeds.
Pretty much you are losing yourself in details (eddies, aspect ratio, etc); all these details combined lead to the above macro result.
You are a bad scientist Hakan, because the more obvious explanation would be that Goran is a better sailor then the others. Also you are allowing unverifiable data to enter the discussion and to top it off this data comes from interviews with the designer of these M20's himself. We are assured that that unknown Italian Tornado team sailing at that unspecified event are good sailors. We have a few more examples like that, for example that a foiling moth will beat a modern Tornado around the race course. Do you take those at face value ? I certainly don't.
Interestingly enough, all the data that is well know like the Texel data of the last 7 years gets thrown out by you, except for a single (unstable) upwind beat at Texel 2006. I call that cherry picking the data.
I have given you Non-Texel race data in the past on several occasions. You just ignore and forget it, coming back asking for the same data several months c.q. years later. I'm not going to do that again this time. Sorry.
Were exactly do you think part of my experience comes from ?
I'm not making these things up you know.
I've been sailing my Taipan F16 without a jib for the last 16 months, often doublehanded. This because my jib sail was completely ruined by the sailmaker. Over that time, I've sailed 2-up with just my mainsail against other 2-up F16's as sloops and 2-up F18's. I even got witnesses. Tim Bohan and Gill, you guys remember these rides ?
Every time the result as the same. I could put up a good fight on the upwind legs but they would pass me eventually. On reaches they walk away, not very fast but they do. Under spinnaker the difference (if at all present) is too small to be determined accurately.
In the really strong winds I found that I had to point lower then a sloop rig to keep my speed and VMG up. Pointing high would kill its speed/vmg. All sailing as 2-up. Basically my 15 sq. mtr mainsail was too small to sufficiently power-up even in the strong winds. I ran into the following problem. To get speed I needed drive which I could only get by increasing the angle of attack of my mainsail, so I had the beat off. This powered up the top of my mainsail to much in the gusts lifting me high even when having 150 kg on the wire. Then I flattened the top to calm down the boat as a result I lost some drive but far more importantly I also lost my pointing advantage. I could not break this circle of cause and effect sufficiently to outperform the sloops. Also, forcing a mainsail to operate at larger angles of attack cuts down on its efficiency. Basically it CL (lift) factor goes up with larger angles but its Cd (drag) factor goes up even more leading to significant increases in induced drag.
Basically it felt that I couldn't get the (relatively small) uni-rig to develop enough drive to hold off the sloops. Interestingly enough we were fully powered all the time but this made no difference.
From this I know that adding a jib to an existing mainsail (uni-rig) will improve performance of the boat. At least it does to F16's when sailed 2-up. I fail to see how the results can be difference when sailed 1-up.
All boats named in this post were optimized for 2-up sailing and were sailed that way. My mainsail is cut to suit 150 kg of crew weight. Most often I sailed against Geerts old boat that had an Ullman F16 mainsail that was cut flatter then my Redhead mainsail. His new Blade F16 with the Glaser suit of sails is noticeably faster upwind. The Glaser mainsail has a little more draft to it. We haven't sailed 2-up sloop/uni against eachother yet with his new boat yet.
The numerical model presented earlier appears to be consistent with my own experiences.
How about you doing some testing for yourself.
For the readers relying on facts and not fiction.. [Re: Wouter] #116507
09/13/07 04:06 PM
09/13/07 04:06 PM
I'm not "cherry picking the data", I'm trying to find Round Texels where you had a lot of upwind, downwind and not a reaching party in extreme wind conditions! The races I know about where you had both versions of M20 with good sailors and that had a lot of upwind/downwind was 2006 and 2007.
I mentioned several examples where uni rigged M20 was sailing faster on the upwind, one is based on legtime on 2007 Texel and the rest is interviews with Marstrom. Give me some examples Wouter and not the usual b-s with finishing times in Texel....
/hakan
Re: For the readers relying on facts and not fiction.. [Re: Hakan Frojdh] #116508
09/13/07 07:10 PM
09/13/07 07:10 PM
Well, I guess this end our debate then.
Re: For the readers relying on facts and not fiction.. [Re: Wouter] #116509
09/14/07 12:25 AM
09/14/07 12:25 AM
Thanks for an interesting debate Wouter!
/hakan
Re: For the readers relying on facts and not fiction.. [Re: Hakan Frojdh] #116510
09/14/07 01:03 AM
09/14/07 01:03 AM
C Ya later !
Best of winds to you.
Re: For the readers understanding mathematics [Re: Wouter] #116511
09/14/07 08:42 AM
09/14/07 08:42 AM
Houston
carlbohannon Offline
Houston
(This is in reply to the long discusion of why your boat is slower with just a mainsail)
One problem is your main is not cut to be sailed as a uni. From what you wrote, I would say your main is too flat for the weight and sail area. It could be just perfect as a sloop but too flat as a uni.
I tend to agree that for a non-overlapping jib, a optimzed sloop with more sail area will be a little faster than a uni. In theory, simulation, a wind tunnel or flat water and absolutly steady wind. I think a uni would have an edge. In reality, mostly because of it's greater flexability I think the sloop would have a edge. This based on experimenting with a Wave and a N6.0.
Page 4 of 4 1 2 3 4
0 registered members (), 14,964 guests, and 652 spiders.
Most Online16,046
Yesterday at 04:24 PM
