Rudder systems #116643
09/09/07 02:05 AM
09/09/07 02:05 AM
New Zealand
G
GoGecko Offline OP
GoGecko  Offline OP
G
New Zealand
Hi All
Just seeking opinions on rudder systems.
With the fibre tube system with the ss pins are they supposed to shear off when the ruddErs hit something or just bend.
If they shear off when sailing they obviously cant be replaced quickly.
If anyone is using a rope pull down and up system could you advise how that is set up and do you need shockcord in the line somewhere to relieve the impact shock when you do hit something.
All ideas appreciated.
GoGecko New Zealand
Re: Rudder systems [Re: GoGecko] #116644
09/09/07 02:50 PM
09/09/07 02:50 PM
Northwest-Germany Hamburg
Holger Offline
Holger  Offline
Here you can see another rudder system from my boat.
Part 1:
With the push rod you can raise the rudder to full up position, here it is additionally secured with a black bungee for moving around at land...
Dynautic Blade F16-GER 001
Re: Rudder systems [Re: Holger] #116645
09/09/07 02:54 PM
09/09/07 02:54 PM
Holger Offline
Holger  Offline
Part 2:
This is the position when starting at the beach, rudder half down. To lock the rudder down you have to push the rod back and the white curved plastic part at the rod slides over a roller an locks the rudder.
Re: Rudder systems [Re: Holger] #116646
09/09/07 03:03 PM
09/09/07 03:03 PM
Holger Offline
Holger  Offline
Part 3:
Here you can see the locked down position, the curved plastic is slid with the undercut over the roller and locks the system.
For emergency release if you hit something underwater, there is a cut in the white plastic which will give the roller free, and the rudder pops up.
So far i like this rudder system and it works as described without problems.
Holger
Re: Rudder systems [Re: GoGecko] #116647
09/09/07 03:27 PM
09/09/07 03:27 PM
Neither, the rod should bent slightly thus unhooking the pins from their securing holes and the whole setup should unlock. Works abolutely perfect on my carbon AHPC stocks/rudders, but I do know that there some imitation about that don't.
The only thing I like less about my AHPC rudder setup is the crossectional profile of the rudders itself. The stocks, tiller connections, locking rods/pins etc are all just as they should be.
Hey Holger, next year a short holliday on the Dutch coast for you ? With boat of course !
Re: Rudder systems [Re: Holger] #116648
09/09/07 03:28 PM
09/09/07 03:28 PM
Seems like a good mod for the Blade. Is this a setup upu will be selling?
Doug
Re: Rudder systems [Re: ] #116649
09/10/07 12:43 PM
09/10/07 12:43 PM
Holger Offline
Holger  Offline
No I won't sell these rudders, I like them on my Blade.
I found the manufacturer in the web and remembered when the
question came which rudder to chose for my boat. Big advantage
is, that it is a local builder for me, in Hamburg/Germany.
The rudders are used on my F16 and some F18ht.
here is the link:
http://www.shakedesign.de/rudder.htm
Holger
Re: Rudder systems [Re: Holger] #116650
09/12/07 05:12 AM
09/12/07 05:12 AM
New Zealand
G
GoGecko Offline OP
GoGecko  Offline OP
G
New Zealand
Hey all
Many thanks for all the help
Really appreciated
Ron Heydon
GoGecko New Zealand
1 registered members (Damon Linkous), 2,534 guests, and 340 spiders.
