| Re: Why do A-Cat STOP racing at 22mph windspeed?
[Re: brobru]
#11664 10/14/02 06:21 PM 10/14/02 06:21 PM |
Posts: 805 Gainesville, FL 32607 USA | It gets pretty hairy at 22 knots on my A-cat, besides I'd like to keep this sail for a while! Actually I haven't seen one break yet because of wind. At the Hobie 20 Nationals last November 2001 it never got over about 20 and it was a lot of work but fun. The 2000 Hobie 20s/ Pensacola one morning it was close to 22 knots and many did not go out to race: those that did were doing repeated cartwheels including Woodie Cope. Tough conditions.
[Re: brobru]
#11665 10/15/02 04:35 AM 10/15/02 04:35 AM |
Joined: Sep 2002 Posts: 27 Sydney, Australia TornadoALIVE
Posts: 27 Sydney, Australia | Hi Guys, In Austalia we are ment to stop racing if the wind exceeds 22.5 knots for a sustained period of time. Many insurance policies do not cover us in winds over this, therefore clubs and classes have adopted this as their wind limits. Had the kite up on our Tornado twice in winds in excess of 30 knots and reaching as high as 36 knots. Very scary, very exciting, bent the mast and broke battens in a HUGE catwheel the last week. Time to ring Marstrom. Go Hard Stephen Medwell Team Tornado 'ALIVE' www.tornadoalive.com | | | Re: Why do A-Cat STOP racing at 22mph windspeed?
[Re: brobru]
#11666 10/15/02 10:04 PM 10/15/02 10:04 PM | Anonymous
| Anonymous
Unregistered | Just a couple of thoughts about the "wind". For one thing most people usually overstate what the wind is
really blowing----22 mph is a lot of wind! Also, the sustained wind is one thing, but often it's the gusts
that get you! In Tampa last fall at the Hobie 20 nationals Mr Davis (PRO) made his famous statement about the sustained wind not exceeding 18.7 knots----no doubt that was true, but the gusts were well into the
high 20's and those big gusts were what was taking so many people down! | | | Re: Why do A-Cat STOP racing at 22mph windspeed? #11667 10/15/02 11:36 PM 10/15/02 11:36 PM |
Posts: 80 Vero Beach Fl | I think you hit it on the head! Cat sailors are a bit like fishermen when it comes to judging wind and hull speed. We talk about the 30 knot gust when in fact it might be a small...tad bit...less? If you want to see what these winds look like go to floridamultihullsailor.com and look at the pictures of the IRCA campout.
| | | Apparent wind
[Re: nacra 269]
#11669 10/16/02 01:13 AM 10/16/02 01:13 AM |
Joined: Jun 2001 Posts: 425 Toledo, Ohio (western end of ... Mike Fahle
Posts: 425 Toledo, Ohio (western end of ... | I think there is another valid, and more charitable, reason that sailors seem to persistently overestimate the wind speed. They are feeling the apparent windspeed while sailing, not the true wind speed. So when they are going upwind at ten mph in a 20 mph breeze, they feel something close to 30 mph and that is what they report. You can easily "prove" this yourself by taking windspeed readings while stopped, then sheeting in while continuing to read the windspeed while trapped out and going full tilt. Quite a difference! Now add in the spray and it seems like even more! So they go in and report what they felt without mentally subtracting the boat speed to arrive at the true wind speed. It is a natural, understandable effect. All we need to do is to ask the question if that was apparent wind speed or true wind speed and most sailors will realize what they have been doing subconciously. Sailing on "big boats" with all the high tech electronics gives one the advantage of knowing exactly what the windspeed is but the mistake commonly made there is to not adjust for height off the water. A masthead wind instrument on a forty footer is often more than 60 feet off the water where the air can be moving significantly faster than close to the water surface. So even with good instruments the wind speeds are often over reported unintentionally. So I think the most useful reporting often is not wind speed but rather specifics describing the effect of the wind. (e.g. "we were double trapped with 320 pounds combined flying a hull while playing the 16/1downhaul to the max setting in puffs"). BTW, for regatta reporting purposes, I think the same principle applies for temperature because of the combination of effects caused by air and water temps. (e.g. "we were cold in our shorty wetsuits in the 80 degree sunny air because of the drenching we took every time the boat crashed through the 3 footers churned up by the wind against the current"). Tells you a whole lot more than "it was 80 and sunny", doesn't it?!
Mike | | | Re: Why do A-Cat STOP racing at 22mph windspeed?
[Re: Will_R]
#11673 10/16/02 11:00 PM 10/16/02 11:00 PM |
Posts: 96 Racine, Wisconsin | I had the opportunity once this summer to do screaming reaches and deeper in 25 gusting to 30. All that was going thru my mind was, "At least I'll die happy!!!"
Paul Scott Bartelt
2001 NACRA 6.0 NA #546
[Re: brobru]
#11677 10/29/02 10:43 PM 10/29/02 10:43 PM |
Joined: Aug 2002 Posts: 164 The Netherlands (North West Eu... RobLammerts
Posts: 164 The Netherlands (North West Eu... | I know the safe way to go is stopping at 22knots on a A cat,
But there are some smaller sails available for 22knots+
I myself stop at +/- 30 knots on my Nacra 6.0 .
Anything above there is almost no one on the water to rescue you in case of an emergency.
Also you should consider are you sailing on a lake or at Sea there is a big difference from the impact of the waves to your material.
Rob
Nacra 6.0 European version
Nr 090 + Spi
20,577
guests, and 826
