| BIMARE Javelin 16 #11718 10/15/02 04:21 AM 10/15/02 04:21 AM |
Posts: 26 | BIMARE announced that the first production Javelins 16 will be on sale in April 2003. The new boat will feauture wave piercing hulls and will be fitted with a slightly reinforced version of the 9,00 m RIBA carbon mast which fits the Javelin A and the same 12,50 sqm main of its bigger brother, as the latest version of the BIM 16.
The Javelin 16 will be offered only in the UNIRIG configuration. As optional the boat (with a conspicuos reduction of its price) will be offered with a 9,00 m aluminium mast. Besides it will come ex factory with a 17/17,5 sqm spinnaker and a new - BIMARE made - mid pole snuffer.
The price of the standard version (carbon mast, spinnaker and spinnaker kit - snuffer included) will be at least 30% lower of the price of most F18s in Europe (40% for the optional alumunium mast version), and competitive with the price of the other aluminium mast fitted F16s.
Therefore, according to my opinion, if the reason to ban the carbon mast from the F16 rule is PRICE concern, this cannot be retained anymore as a valid argument.
Don't forget the SAFETY advantage of a carbon mast over an aluminum mast | | | Re: BIMARE Javelin 16
[Re: Maurizio]
#11719 10/16/02 08:37 AM 10/16/02 08:37 AM |
Posts: 12 | This is great news for the F-16HP class. Bimare will produce AFFORDABLE, well built Jav 16s just like their great Jav2 18footer.
The T 4.9 cost as much as a Bimare Javelin 2 and maybe more after adding a chute, so the Bimare Javelin 16 (BIM 16)should be a bargain! Maurizio pointed out that the boat would be sold at 30% less than the F-18s. The Taipan 4.9 with spin cost about the same as a F-18, so the new BIM 16 should cost less than the T 4.9. This is very significant and should help the F-16HP class grow much faster.
As far as the 9m mast, I am sure that Bimare has spent a great deal of time and money developing this new F-16HP (they announced it in July of this year) with a 9m mast. My point is, they have built their boat to work with a 9m mast and now the F-16HP guys are considering lowering the max mast height for their class. This seems to be very convienient for the T 4.9 owners in the class! Don't change the rules, after a new boat has been developed under the old one!!!!!!!!!!! This will stiffle the classes' progress.
Another point to consider is that with Bimare's success with the F-18HT class, they could start their own class and outnumber the current USA F-16HP class very quickly, if their design were outlawed. This is a reasonable assumption, based on their growth in the F-18HT class. I think that this consideration should be reviewed by the F-16HP class with high priority.
I look forward to more information on Bimare's 16, as my son is looking for a new boat, after we recently had a bad experience with a Austrailian Flyer A-Cat. This Javelin 16 should fit the bill perfectly and affordably.
Steve Jones | | | Re: BIMARE Javelin 16
[Re: Maurizio]
#11720 10/16/02 08:58 AM 10/16/02 08:58 AM |
Posts: 344 Arkansas, USA | Maurizio-
Sounds very interesting and I look forward to seeing one! I wonder why you persisted in the UNIRIG configuration for this class where all the other sloop boats are outfitted with jibs and to not design/produce a boat with this available seems to "slant" it to a solo person boat only? Was this your intent? When can we see photos and/or expect to see some over here?
Kirt
Kirt Simmons
Taipan #159, "A" cat US 48
[Re: Nacracando]
#11721 10/16/02 09:30 AM 10/16/02 09:30 AM |
Posts: 344 Arkansas, USA | Steve-
You seem to be biased against the Taipan (or is it AHPC in particular - re your reference to the Australian Flyer, which swept the "A" Worlds by the way).
As US Class head I welcome any and all new F 16HP boats and look forward to this new offerring from BIM, built specifically to the class rules (except for the provision for a jib- Which in the F 18HT class is not an issue but the original intent of this class was to have boats that could go "either way" easily and be competitive more or less with each other, which differs greatly from the F 18HT's). BIM seems to be (I can only go on the information in Maurizio's post since I have not seen or heard any more about this boat but have seen/sailed with the current BIM 16) offerring a boat maximized under our rules for one-up sailing and not amenable to sailing as a sloop, which is their perogative. But to compare that boat specifically to a T 4.9 / Stealth / Spitfire / etc. designed and sold to go sloop or solo is not really comparing apples to apples IMO. A Taipan uni (which can be ordered) is conspicuously less expensive than a sloop and faster in "uni mode" than a sloop w/ the jib merely left off (less weight slightly and different cut mainsails).
So please, let's keep things positive here and not get into the pissing contest some of the other forums seem to revel in. All the builders in our class build good strong boats and ALL the other CURRENT boats (Stealth, Taipan, Spitfire, etc.) have 8.5 m masts whether CF or Al so the "mast rule" you allude to only affects the BIM (a boat that is not yet in production and could be changed easily leaving no CURRENT class members disadvantaged.) Maurizio points to CF as being "safer"- I presume he's referring to the ease in righting, well, it's easier to right a boat with a 8.5m CF mast than one with a 9m CF mast all other things being equal so limiting mast height could be "defended" as a safety issue. I'm just trying to point out there are generally more than one ways to "view" an issue. I'm personally okay with leaving the length at 9m but we are a class run organization so majority rules but I appreciate your opinion and I agree the more manufacturers we have competing with each other the better the boats/rigs/sails/cost will become FOR US (the sailors)!!
And we will all win!
Kirt
Kirt Simmons
[Re: taipanfc]
#11724 10/16/02 07:39 PM 10/16/02 07:39 PM |
Posts: 12 | Hello again,
Interesting stuff! Here are a couple of thoughts-
1- The Bimare 16 is often pictured being sailed by two people, so I think that a jib would not be neccessary for conversion to and from singlehander and doublehander. I don't no much more about the convertability of this new boat. I do know that the F-18HT is a doublehander and has no jib.
2-Granted there are many (200+) Taipan 4.9s worldwide, but less than 20 in the USA. Most of these Taipan 4.9s are not maxed out to the F-16HP rule and race one-design Taipan 4.9 class. The Bimare Jav 2 18 footer has sold more than twice that many in 9 months, here in the USA. I only care about the classes in the USA. With the proper pricing the Bimare will quickly outnumber the Taipans here in the USA. If the F-16HP class does not accept the Bimare 16 Javelin, then I feel sure that a new class can be organized for them! I would be willing to work hard to organize such a class, if necessary. I am sure that Bimare's USA guy, W.F. Oliver, would lend a hand in such an endeaver. The potential resources between myself and Mr. Oliver are significant. Maybe the F-18HT class would help us out? In short, it would be in the F-16HP classes' best interest to welcome the new Bimare.
3-I am VERY excited about this new boat, as the "smaller" F-18HT is just the ticket for my son. Once he grows, then we can go F-18HT or other larger cat.
Steve
[Re: Maurizio]
#11725 10/16/02 08:30 PM 10/16/02 08:30 PM |
Thank you very much for the explanation, I think I understand now why they did not put a jib on the boat- Sort of "Company policy".
Thanks again,
Kirt
Kirt Simmons
[Re: Nacracando]
#11727 10/16/02 08:38 PM 10/16/02 08:38 PM |
Posts: 105 | Hi, steve,
I'm glad to see you're interested in the class. I'm excited about the prospect of a cheaper addition.
I think you might want some clarification, though:
1. As far as uni vs. sloop, the F18ht comparison is not accurate...the f16 as a doublehanded uni loses the WHOLE sail area of the jib. I have trouble seeing a 300 lb. team being competetive in less than 8-10 kts with that significant of a redux. in sail area.
2. a) Actually, most of the T4.9's (in fact, almost all) in the U.S. have F16 chutes. We represent the current class. Ignoring us does not make sense to me.
b) I would love to see WF become involved in the class... however, he has not done so, since he quit sailing the BIM. I do not blame him for this, but it is unrealistic for you to expect him to give equal support to a class that he does not race in. If he gives Randy a boat, and gets the F16 in as a Worrell boat, then I'll concede this point to you, and wholeheartedly agree that you're right. ;-) Until then, though, the class should rely on those members it already has in the U.S. You can't ignore the Worrell and Rockstar factor of the 18ht's success. ANY boat newly chosen for the Worell will sell 20+ boats in a year, based on that alone. Brilliant marketing, but unlikely for the BIM 16.
3. As I said, I'm very excited about the new boat. I really wish they'd chosen to build a "true" doublehander, though. As far as the difference in mast height, a redux. of .5 meters is a minimal task for the factory. I don't buy that it would be a great hardship for them. Matter of fact, I believe that several of the earlier BIM 16's had shorter masts.
Thanks,
Michael Coffman
T4.9#32 | | | Re: BIMARE Javelin 16
[Re: Nacracando]
#11728 10/16/02 09:06 PM 10/16/02 09:06 PM |
I was not trying to say the BIM could not be sailed two handed but that the F 16HP class was originally set up so that the handicap numbers of a uni rig solo sailor boat would be essentially equal to the handicap numbers of the same boat with the added sail area of a jib and a second person (which was to equal the handicap numbers of the popular F 18 class). If someone wishes to forego the jib and race doublehanded on a boat which meets the other requirements for the F 16HP class they can and they are welcome to do so. It is not an option in our class (at this time) to "add" the sail area that would be in the jib to the mainsail (and/or spinnaker) ala the F 18HT. If this were an option then one would "have to" get two separate mainsails and/or masts to be able to sail one or two up safely (as some of the F 18HT owners have proposed to do). Our class did not want to "require" someone to do any more than merely remove one sail (the jib) and related hardware to be able to safely sail (and race) the boats with one or two persons.
I (and the class) cannot control BIM, I certainly hope they wish to make the boat comply with the F 16HP rules but that is up to them. Performance, for instance, chose to modify the Inter 18 sold here in the US so it did NOT comply with the F 18 rules- Hobie chose to make the Tiger comply- Not much question which there are more of now in the US and unfortunately it has caused "issues" for F 18 sailing in the US which I would like to avoid but it's not up to me.
The "F 18HT" class you refer to is really at the moment a "Jav F 18HT class" since it's the only one readily available here in the US. It's success is attributable (IMO) to a unique design, very strong company backing and personal financial backing by WF plus some smart political moves to outbid the competition for things like the Alter Cup and Worrell 1000. IMO it is very hard for any "foreign" cat manufacturer (or actually any small domestic one like Isotope, Hardcore, Freestyle, Sea Spray, etc.) to "break into" the US market and probably requires things like WF and BIM have done to take off quickly.
In closing, let me say I truly hope BIM's intentions are to produce and promote a fully compliant F 16HP model which is comparable to the offerrings of the other F 16HP builders, as that is the intent of the "Formula" concept.
Looking forward to seeing you on one!
Kirt
Kirt Simmons
[Re: Kirt]
#11733 10/20/02 07:59 PM 10/20/02 07:59 PM |
Maurizio,
I also understand that reasoning and really have no problem with that. But why does bimare intend to use the 12,5 sq.mtr. mainsail and not the 15 % bigger F16 mainsail for their Javelin 16 design ? Surely in the same line of thinking the bimare Javelin 16 will be faster and better suited to double handed sailing as a result ?
[Re: Wouter]
#11734 10/21/02 04:32 AM 10/21/02 04:32 AM |
Posts: 26 | Wouter,
in order to avoid misunderstandings, the Javelin 16 is to be fitted with a 12,50 sqm A class main, as the old BIM 16, giving a total surface, mast included, of 13,94 sqm or 150 sqft.
Are you saying that the Javelin 16, with two crew, is allowed - under the F16HP rule - a 15% larger mainsail, that is 16 sqm (included mast)?
Maurizio | | | Correction
[Re: Maurizio]
#11735 10/21/02 02:17 PM 10/21/02 02:17 PM |
Ahh, 12,5 ex mast; there is the reason for my misinterpretation of that area. As I understand it the A=cat class also includes the area of the boom in the 13,94 sq.mtr. limit.
The area limit for F16 mainsail is now at 103,5 % of the 8,7 mtr. by 13,7 sq.mtr. (=13,94-area boom) of the Javelin 16. Ergo the current proposed Jav 16 mainsail is at 97 % of the max allowed.
So yes the jav 16 mainsail is a pretty good F16 mainsail and the jav 16 will be full compliant in this setup in both 1-up and 2-up races.
| | | Re: Correction
[Re: Wouter]
#11736 10/22/02 09:12 AM 10/22/02 09:12 AM |
Posts: 344 Arkansas, USA | Wouter-
I don't remember the "A"'s measuring the boom (although I think there IS something about it can't be over a certain size without being included in the sail area- Like the rudder can't be over a certain width or it is included in the length of the hull- This is to prevent someone having a 12" wide boom, etc. The Taipan rules also limit boom size- by saying it must fit through a circle of X dimension as I remember). They measure and mark the mast and the sail, but not the boom.
Kirt
Kirt Simmons
| | | A-class
[Re: Kirt]
#11737 10/22/02 01:10 PM 10/22/02 01:10 PM |
Posts: 9,582 North-West Europe | As far as I know the boom is included in the sailarea when its height is 1.5 tiems it's width. Also the area of the whole mast is included in the sailarea. Under F16 rules only the part of the mast next to the sail is included.
All this leads to Texel measurements of A-cats sail which are 13,60 sq.tr. or less. I guess the difference between 13,94 and 13,60 is caused by these issues. This 13,6 sq.mtr. on a 8,8 mtr luff results in a rated mainsail area of 12,62 sq. mtr. = 97 % of the allowed max.
But all this doesn't really matter much as the max. A-cat sail and mast combo of 13,94 sq.mtr. and a luff length of 9 mtrs (0,15 mtr boom clearence near mast) results in 12,976 sq.mtr rated mainsail area which is 99,8 % of the max allowed under F16 rules. All other sails in the F16 measure in at 99 to 99,9 %
So any A-class mast-sail combo will measure in, just like we intended at the beginning. That is ofcourse when the mast height isn't limited to 8.5 mtr.
20,053
guests, and 1,598
