| Pressure #117360 09/16/07 07:00 PM 09/16/07 07:00 PM |
Joined: Dec 2003 Posts: 244 Central Coast NSW Australia TonyJ OP
Posts: 244 Central Coast NSW Australia | There was an ealier post with a photo of a F16 with the kite up, showing the rig moving forward.
Any ideas on what the forces would be on the rigging?
For example ! Would it be the same as lifting a 500 kg weight with a fork lift by the rigging?
Regards TJ
Teach them how to think.
Not what to think.
Aus
Blade 002
| | | Re: Pressure
[Re: TonyJ]
#117362 09/17/07 04:54 AM 09/17/07 04:54 AM |
Posts: 9,582 North-West Europe | On the static calculations that I have performed in the past on my own boat I found :
The forestay can see 600 kg loading, the bridles are much the same
The sidestays are loaded up less to about 450-500 kg. (when both crew are sitting on the hull in a blow. )
This assumes that you can pull on the mainsheet line with 50 kg and are using a 8:1 tackle setup. It also assumes sailing hard in 2-up mode.
When the crew is double trapezing then the side stay load drops to about 350 kg. As such the sidestay loads respond differently to going double trapeze then the forestay. You unload the sidestays by going double trapping when you load up the forestay even more (max about 600 kg). However by far the most of the forestay loading comes of the mainsheet system. Pulling harder on that increases the forestay load, the sail forces on the sails are not a large component in this setup. Going into a violant dive actually decreases the forestay load and increases the sidestay/mainsheet loading. As such this is a positive thing as the latter can easily take the increases when the forestay can not.
I've chosen to use 4 mm steel 1x19 all around. Basically because I had to choose between 2.5 mm dyform (625 kg), 3 mm 1x19 (720kg )and 4mm 1x19 (1200 kg). I found the breaks strengths of the first two unnervingly close to the real loads and I couldn't get 3 mm dyform (900 kg) that I really wanted. I also planned to race my F16 doublehanded hard and my calculations were based on that.
If you are only sailing singlehandedly then 3 mm 1x19 may well be enough but for hard 2-up racing I would choose 3 mm dyform or 4 mm 1x19 for the forestay and bridles. I feel that on the sidestays you can take some more risks.
In engineering it is common to use a factor of 150-200% as a safety margin.
I also discussed this with Greg Goodall in the past and he mentioned that they could get away with the older 1/8th inch 1x19 wires on the Taipan 4.9's. That was before they started using 3 mm dyform. However, he was convinced that any smaller diameters would break.
The older stype 1/8 wires are actually a little stronger then the new metric 3mm 1x19 wires. These tow sizes are very close together as 1/8 inch = 3.175 mm, but this difference still allows the older wires to carry 12% higher loads before breaking. 720kg (new) to 810 kg (old) and everything helps. This also makes clear how attractive 3 mm dyform is (900 kg).
It must be noted that the F16's, with the large squaretops, need more leech tension then the older Taipan mainsails. As the mainsheet is such a large component of the whole I would not take to much risk on the forestay.
Difference in weight between 20 meter 3mm 1x19 and 20 meter 4mm 1x19 = 1.060 kg - 1.885 kg = 0.825 kg.
I think the difference between 20 meter 3mm 1x19 and 3mm dyform is about 0.350 kg
Those are the downsides of 4 mm 1x19
The advantage being of course that you are totally secure about this wire not breaking AND more importantly having a stiffer rig !
If indeed keeping the spi luff tight is so important and the mast movement is sufficiently large to upset this then the 4 mm 1x19 wire will by far have the least mast movement of all the alternatives discussed below. Similar things will apply to the forestay stretching and sagging (=upwind pointing ability). 4mm 1x19 is still 50% stiffer then 3mm dyform.
I hope this helps.
| | | Re: Pressure
[Re: Rolf_Nilsen]
#117364 09/17/07 05:52 AM 09/17/07 05:52 AM |
Posts: 9,582 North-West Europe | I also want to try synthetic stays and even bridles/forestay (Wouter have strongly adviced against it)
Did I ? I'm sure it can be made to work, but I do have an uneasy feeling about them on the following points : - Stretching - UV protection and degradation - Dependability when hit by a sharp object when under high tension. (say a trapeze harness buckle with a badly finished egde. But then again I've been hanging on synthetic trapeze lines for 10 years now. Never failed on me once. Wouter
| | | Re: Pressure
[Re: Wouter]
#117366 09/17/07 06:07 AM 09/17/07 06:07 AM |
Posts: 4,451 West coast of Norway | Stretch, creep, mechanical failure (from bending over the mast when it rotates), how to adjust it, stretching under load, stretch before the fibers in the core have aligned and a whole load of other issues have made acceptance slow on small boats. But the stays are heavy, so I think there is a gain to be made. It would also make it easier to build your own rigging without special tools. It should also make visual inspection of their condition easier.
UV degradation should not be too bad as long as there is a cover over the core. Cutting the stays by accident sounds like a freak occurrence. If you see it the other way, stays you can cut with a knife could be a safety measure.
You could under doubt accept fibre sidestays, but not a fibre forestay in earlier discussions <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> | | | Re: Pressure
[Re: Rolf_Nilsen]
#117367 09/17/07 06:50 AM 09/17/07 06:50 AM |
Posts: 244 Central Coast NSW Australia | Thanks for the excellent info.
I have decided against using carbon and Iam trying aramid.
The carbon was stong but frayed too easy and brittle. On the other hand the aramid is more plyable. The experiments are home grown and ugly, but I will post some pictures soon.
TJ
Not what to think.
Aus
Blade 002
| | | Re: Pressure
[Re: waynemarlow]
#117371 09/17/07 04:23 PM 09/17/07 04:23 PM |
Can you post pictures of your setup on this forum ?
Seeing is believing and I sure want to believe this.
| | | Re: Pressure
[Re: Wouter]
#117372 09/17/07 06:35 PM 09/17/07 06:35 PM |
Joined: Mar 2005 Posts: 322 South Australia Marcus F16
Posts: 322 South Australia | Wouter,
I am wondering how accurate your calcs are. The reason being I used 2.5mm dyform on the Aus Blade at Zandvoort & its worked fine. No sign of failure obviously & I was getting about 110 - 120 degrees of rotation down wind.
Do you know what the breaking strain of 2.5mm dyform is.?
Marcus
Marcus Towell
| | | Re: Pressure
[Re: phill]
#117375 09/18/07 06:10 AM 09/18/07 06:10 AM |
Posts: 322 South Australia | Actually I just re read Wouters post, he states 625kgs.....so which is it 625/690?? Wouter - how did you incorporate/calculate the shockloads that go thru the hull & rig like what we saw at Zandvoort & the image of matts boat.?
Marcus Towell
| | | Re: Pressure
[Re: Marcus F16]
#117376 09/18/07 10:48 AM 09/18/07 10:48 AM |
Posts: 9,582 North-West Europe | Actually I just re read Wouters post, he states 625kgs.....so which is it 625/690??
Maybe both ? Different companies different publized specs ? Surely there is more then one company in the world make steel wires ? However, I've written most of my post from memory, I haven't done a detailed check-up on the facts. Although I'm pretty sure about most specs used in the posting. Wouter - how did you incorporate/calculate the shockloads that go thru the hull & rig like what we saw at Zandvoort & the image of matts boat.?
Good question, How would anyone go about that ? Such a calculation would require a much more elaborate model and in depth knowlegde of the causes of such shock loads like wind gusts, sea-state and sailor behaviour. And even then it can only be made to work after making a whole lot of assumptions. Such a model will easily take 1000's of hours in research and implementation. Even when using some of the modern software simulation packages. These packages make creating pictures and nice looking graphs easy, but they do not do the modelling for you or finding all the parameters for the variables involved in such an elaborate model. Basically this is the reason why engineers use safety margins so much. And it is the prime reason I don't want to skim on these. I made a static calculation assuming perfectly stable conditions and flat water. The result was that the forestay would see 571 kg (rounded off to 600 kg) tension already under these conditions. A 720 3mm 1x19 wire only had some 26 % safety margin on that. Apparently 2.5 mm dyform has less then that. I felt that considering the "perfect" nature of my model that that was too little. So I went for 1235 kg for 4 mm 1x19 with a safety margin of 116%. A little bit too much but it was the only alternative I could find. No-one could sell me 3.5 mm 1x19 or 3 mm dyform, both of them would have better. Wouter
| | | Re: Pressure
[Re: Wouter]
#117377 09/18/07 10:39 PM 09/18/07 10:39 PM |
Joined: Feb 2004 Posts: 1,012 South Australia Darryl_Barrett
Posts: 1,012 South Australia | Years ago I had a small, quite inexpensive, instrument specifically for measuring maximum rig loadings under actual sailing conditions (read in lb’s or maybe ft lbs I can’t remember back that far). It was a small gauge that I used to attach between the rigging wire and its anchor point either at the hull or at the hounds up the mast, and it would show the maximum loads that the rigging at that point had been subjected to. It had a graduated gauge and the reading would stay at the maximum that it had been subjected to. To use it again it was a simple press point reset back to zero. It was very interesting initially but as the max’ readings never ever approached the safe loadings given by the wire manufacturers, I stopped using it and like most unused things it has gravitated to that “unknown place” where all such similar things seem to disappear to. I also used at that time a “pressure pad” that I would place under the base of the mast to show, similarly the maximum compression generated down the mast. I also stopped using that years ago as well. Actually from memory, unlike the loadings on the wire, which were quite disappointingly low, some of those mast compression loadings were quite horrendous. We still regularly receive “industry” advertising literature offering for sale a whole range of suitable instruments for measuring every conceivable loading on every conceivable material in every conceivable position, the big difference “now” from “then” is that they all cost an “arm and a leg” to buy now. BUT THEY ARE ALL DIGITAL (which obviously makes them better and worth more, although they still only do the same job with no apparent greater accuracy if you can believe their data) | | | Re: Pressure
[Re: Darryl_Barrett]
#117378 09/18/07 11:47 PM 09/18/07 11:47 PM |
Posts: 322 South Australia | Darryl,
The mast base is not only subjected to compression loads as the mainsheet angles on most cats put a lot of pressure on the goose neck to aid the mast rotation. I am not stating the boom bressure to be higher than the compression load, but you would want to consider all aspects.
Somehow I dont think there is gauge that could do both.?
Marcus Towell
1 registered members (JesperS),
754
guests, and 39
