Page 3 of 3 1 2 3
Re: T-foil rudders that allow traversing a big sur [Re: Tony_F18] #118208
11/02/07 03:42 PM
11/02/07 03:42 PM
Shouldn't there be a rule that says rudders have to be able to go through the surf?
Like in the spirit of being an of-the-beach catamaran?
Sounds like they are able to traverse the surf.
Re: T-foil rudders that allow traversing a big sur [Re: Tony_F18] #118209
11/04/07 06:24 PM
11/04/07 06:24 PM
San Diego
H
hokie Offline
hokie  Offline
H
San Diego
I haven't read this whole thread so maybe someone has thought of this but if the wings were allowed to rotate freely (sort of like a max prop) could you set a stop so that when the rudders are down the axis or rotation causes them to take the path of least resistance except that when bows go down X degrees the wings hit the stop, and then when rudders are kicked up they continue to take path of least resistance. This would seem to solve both the issue of light air drag and moving with rudders kicked up.
Re: T-foil rudders that allow traversing a big sur [Re: hokie] #118210
11/04/07 07:56 PM
11/04/07 07:56 PM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
Except that the stop will stop them from moving in the direction that they need to move in order to reduce drag when kicked up.
Re: T-foil rudders that allow traversing a big sur [Re: pdwarren] #118211
11/04/07 09:28 PM
11/04/07 09:28 PM
San Diego
H
hokie Offline
hokie  Offline
H
San Diego
After thinking about it the whole idea may be flawed and would add more complexity with very little benefit.
Re: T-foil rudders that allow traversing a big sur [Re: Wouter] #118212
11/05/07 02:14 AM
11/05/07 02:14 AM
CA
Glenn_Brown Offline
Glenn_Brown  Offline
CA
The only drawback I can establish with respect of the T-foil rudders as they are available now is traversing the surf. Ones that issue is solved then we'll all be sailing with them.
Kelp, kelp, KELP! It's a show-stopper for me.
--Glenn
Re: T-foil rudders that allow traversing a big sur [Re: hokie] #118213
11/05/07 06:20 AM
11/05/07 06:20 AM
Wouter Offline OP
Wouter  Offline OP
That is doable, Some people are working on it.
Currently we are working on a setup that will unlock the T-foils when the rudder kick-up mechanism is unlocked (like when hitting something)
Re: T-foil rudders that allow traversing a big sur [Re: Tony_F18] #118214
11/05/07 11:18 AM
11/05/07 11:18 AM
Western Australia
Stewart Offline
Stewart  Offline
Western Australia
No.. The rules should NOT have such a clause.
Re: T-foil rudders that allow traversing a big sur [Re: Wouter] #118215
11/06/07 04:24 AM
11/06/07 04:24 AM
Norway
Stein Offline
Stein  Offline
Norway
That is exactly what the mechanism described in my previous posts does.
How do you display the attachment picture in the post?
Stein
Page 3 of 3 1 2 3
0 registered members (), 22,075 guests, and 503 spiders.
Yesterday at 04:54 AM
