Highway Trailering #11829
10/18/02 12:39 AM
10/18/02 12:39 AM
Western Canada
nu2cats Offline OP
nu2cats  Offline OP
Western Canada
Yet another question;
A few years ago I towed my CL 16 cross country and had some heavy turbulence from the big trucks. The camper was shaking and the boat held on for dear life. I'll probably have to tow a catamaran a fair distance on the highway soon and am wondering what safety precautions can I take? I'd assume that the underside of the tramp would catch ALOT of wind.
Robert
Re: Highway Trailering [Re: nu2cats] #11830
10/18/02 01:16 AM
10/18/02 01:16 AM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Drive very fast and minimize your time on the highway!
On the other hand there is not much you can do. The boat dosen't weigh very much compared to its windage. That will be the biggest factor as the trucks pass you the headwind will blow you to the side. Actually I have found that if I am doing the passing the turbulence is less as I am pushing through their headwind instead of getting knocked by it. This could work only up to safe speeds for your vehicle and boat. The other option would be having more weight on the trailer to hold it down. (Then your fuel economy goes to hell)
Don't know if this helps but good luck.
Clayton
Re: Highway Trailering [Re: nu2cats] #11831
10/21/02 01:18 PM
10/21/02 01:18 PM
U
unlvrebel Offline
unlvrebel  Offline
U
I don't know how far you're going, but I just got back from a trip to Puerto Penasco, Mx from Los Angeles, CA - about 500 miles. I tow my H16 with a Dodge Durango and had no problems with my cat or trailer. The only extra weight I had on the trailer was the weight of the rudder system and sail bag (full of sails, boom and hiking stick). We ran down the road for 80 mph for most of the trip. No problems. Just make sure the boat is securely strapped to the trailer. On trips, my boat becomes one with the trailer with ratchet ties.
Good luck-
John
Re: Highway Trailering [Re: nu2cats] #11832
10/21/02 02:56 PM
10/21/02 02:56 PM
I drive to the eastern shore of maryland from north carolina about twice a month during the season with my h17. The only hairy part is when the lane narrows during construction.
Re: Highway Trailering [Re: nu2cats] #11833
10/21/02 06:13 PM
10/21/02 06:13 PM
catman Offline
catman  Offline
One other thing you might look at is the attitude of your boat when towing. I'm talking about making sure the bows aren't higher than the sterns. I've seen people towing their boats with the bows so high its amazing the things stay on the ground.I have mine set up so the bows or the front crossbar is slighty lower than the rear. I think this and removing the tramp are your best bet.
Re: Highway Trailering [Re: nu2cats] #11834
10/22/02 02:05 AM
10/22/02 02:05 AM
Ljubljana, Slovenia
mayhem Offline
mayhem  Offline
Ljubljana, Slovenia
I have towed a number of boats: large sailboats, small motorboats, Nacra60s, A-cats, etc. 2 years ago, I was towing a Nacra60 with a Nissan Sentra! Now I tow an A-cat here in Europe with a turbo Passat (up to 100+ mph on the Autobauns). My conclusion is that the only important factor is the quality of the trailer. With the same vehicle, I have two two different trailers with wildly different weights and I am always suprised how much of a difference the trailer quality makes.
For Catamarans, no one makes a better trailer than Trailex. It was the only way I could tow a Nacra60 with a Nissan Sentra. Invest the money and you will forget you are even towing.
Re: Highway Trailering [Re: nu2cats] #11835
10/22/02 08:59 AM
10/22/02 08:59 AM
Durham, North Carolina
jwrobie Offline
jwrobie  Offline
A related question.
I am towing my P16 with a Ford Escort, manual transmission. A friend was shocked, and suggested that *probably* with an automatic transmission I would be OK towing with such a small car, but that this is a really bad idea with a manual transmission.
Is there anything to this?
Jonathan
Re: Highway Trailering [Re: jwrobie] #11836
10/22/02 09:14 AM
10/22/02 09:14 AM
Dallas, Texas
thom Offline
thom  Offline
Dallas, Texas
The difference betwen an automatic and a stick is the manual clutch and you shift the gears . If you handle the clutch & shifting properly there should be no problem.
ASK YOUR FRIEND HOW MANY 18 WHEELERS HE HAS SEEN/DRIVEN WITH AN AUTOMATIC TRANSMISSION????
thom
Re: Highway Trailering [Re: jwrobie] #11837
10/22/02 10:04 AM
10/22/02 10:04 AM
Cambridge MA
Marco Offline
Marco  Offline
Cambridge MA
Re: manual vs. automatic shift
In fact, manual is way better for trailing. Everything else being equal, automatics decrease the power available at the wheels. Sometimes, particularly under heavy load, automatics keep shifting back and for between gears. With manual you are always in control.
m
Re: Highway Trailering [Re: Marco] #11838
10/22/02 10:21 AM
10/22/02 10:21 AM
When I forget to turn on "power mode" on my trooper, it does what you described Marco. It irritates me to no end.
Re: Highway Trailering [Re: MauganN20] #11839
10/22/02 12:01 PM
10/22/02 12:01 PM
Tampa, FL
dave taylor Offline
dave taylor  Offline
Tampa, FL
come on. we are talking about a trailer and boat that together weigh about 500 pounds with a tongue weight of about 60 pounds. i used to trailer my p16 with a manual transmission mazda miata (roof down, of course). it pulled the boat without a problem. it did get tricky getting the miata off of the beach without getting stuck, but that is a different issue all together.
Re: Highway Trailering [Re: dave taylor] #11840
10/23/02 08:48 AM
10/23/02 08:48 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
I towed my N6.0 from Houston to Destin this year for RTI 2002.
I do have a Dodge Dalota Quad Cab, with 5spd, v-8, and the trailer towing package factory.
We pulled it at 85mph, NO PROBLEM. My boat and traler probably weigh close to 800ish, then my box, another 1-200ish, I figure the entire thing is about 1,000 lbs, +/- 200.
Although I know people who have had the boat picked up by crosswinds, it has to be pretty extreme.
Personally, and this is personal, auto tranny's aren't worth it. Lucky for me my wife also drives a manual. They're heavy, less efficient, slow, etc. I want to be in the gear I put it in, not what some engineer wants me to be in.
F-18 Infusion
#626- SOLD it!
Re: Highway Trailering [Re: Todd_Sails] #11841
10/23/02 09:38 AM
10/23/02 09:38 AM
Yeah, but I can eat a sandwich and a drink while driving through town!
Re: Highway Trailering [Re: Jake] #11842
10/23/02 10:25 AM
10/23/02 10:25 AM
Tampa, FL
dave taylor Offline
dave taylor  Offline
Tampa, FL
...and write, talk on the phone, read a map, and yell at the guy in the car next to me who just cut me off.
Re: Highway Trailering [Re: dave taylor] #11843
10/23/02 11:58 AM
10/23/02 11:58 AM
Andrew Offline
Andrew  Offline
ya, but I do all those things with my five-speed. Of course, it means planning shifts ahead of time, and occasionally driving with my knees, so if you see Crazy Horse on the road, I may cut you off, but I dang sure won't run you down with my 4-banger!
Re: Highway Trailering w/ a Miata [Re: dave taylor] #11844
10/23/02 01:52 PM
10/23/02 01:52 PM
Arkansas, USA
Kirt Offline
Kirt  Offline
Arkansas, USA
Dave-
What year was your Miata? I've got a 1993 w/ the "little" engine and was wondering if it was up to the task-
Getting boats up ramps/out of sand is one other thing autos are good for, as well as towing heavy loads from dead stops uphill- You do pay in efficiency though-
Thanks!
Kirt
Kirt Simmons Taipan #159, "A" cat US 48
Re: Highway Trailering [Re: Andrew] #11845
10/23/02 01:56 PM
10/23/02 01:56 PM
Todd_Sails Offline
Todd_Sails  Offline
You know, an auto shifts all the time. If I shifted in traffic like an auto, doing things I shouldn't be doing anyway while driving would be difficult. But, as in town, you take your foot off the gas pedal, the tranny goes to the higher gears. Then you press it again, it downshifts AGAIN, and so on. With a manual, you don't shift it THAT often. And yes, I can drink etc. while driving.
Whether auto, or what, I try and use my headset anyway for the car. MUCH safer, MUCH. Try it, even with an auto tranny.
Have a good day,
Todd
F-18 Infusion
#626- SOLD it!
Re: Highway Trailering w/ a Miata [Re: Kirt] #11846
10/23/02 04:25 PM
10/23/02 04:25 PM
Tampa, FL
dave taylor Offline
dave taylor  Offline
Tampa, FL
1991. it felt like a truck pulling a 23 foot powerboat, but it didn't have any problems. like i said. the problem was more with the car getting stuck in the sand.
Re: Highway Trailering [Re: nu2cats] #11847
10/23/02 09:21 PM
10/23/02 09:21 PM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
Make sure you do a thorough check on the condition and lubrication of the wheel bearings as well as the tread and inflation of the tires. Lights, of course shoul be all checked as well.
Be sure that the tongue of your trailer has a good amount of weight on it; too little can lead to trailer sway.
Santa Monica Bay
1 registered members (FredL), 343 guests, and 59 spiders.
