Spinnaker on a 14? #118481
09/26/07 11:33 AM
09/26/07 11:33 AM
Largo, Florida
papayamon2 Offline OP
Largo, Florida
OK, while I'm starting posts (which I don't often do), I do have one other question. Can a 14' cat handle a spinnaker (are there any that do?), and can one be retrofitted on a boat designed w/out one?
I currently sail a Trac 14 (which is the same as a Windrush in Australia), and I was wondering about whether a spinnaker could be added. The Trac 14 has more hull bouyancy than the Hobie 14, but I'm not sure how much hull-burying tendency would be added via a spinnaker, and whether it would bury any 14'. For the record, I've never sailed w/ a spinnaker before, but it looks like it would be a hoot. Can anyone enlighten me?
Thanks!
Kevin
Re: Spinnaker on a 14? [Re: papayamon2] #118482
09/26/07 04:21 PM
09/26/07 04:21 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
Check out the f14 class they all either run hooters and spinnakers.
You can retrofit spins to most cats, some handle it better than others. I am in the process of doing just that to my Nacra 5.2.
Also the spinnaker if designed and attached correctly will actually lift the bows, not drive them down.
Re: Spinnaker on a 14? [Re: papayamon2] #118483
09/26/07 05:36 PM
09/26/07 05:36 PM
Scary.
Re: Spinnaker on a 14? [Re: Karl_Brogger] #118484
09/26/07 05:37 PM
09/26/07 05:37 PM
Wrong picture [Linked Image]
Re: Spinnaker on a 14? [Re: Karl_Brogger] #118485
09/26/07 05:48 PM
09/26/07 05:48 PM
rictorn Offline
rictorn  Offline
i am puting a spinnaker although it will probably be a roller reefing hooter on a windrush, i would suggest the hooter is the way forward as getting a spinnaker up and down on your own is a lot of effort, douse anyone think t foil rudders are worthwhile?
Re: Spinnaker on a 14? [Re: rictorn] #118486
09/26/07 07:36 PM
09/26/07 07:36 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
With a snuffer the spinnaker should not be to much trouble and they just look so much cooler than hooters...well the sail kind of hooters. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Spinnaker on a 14? [Re: gree2056] #118487
09/26/07 08:03 PM
09/26/07 08:03 PM
virginia beach, VA
dsltrc Offline
dsltrc  Offline
virginia beach, VA
i like my hooter sail......... i like not having to take my hand off the tiller to unfurl or furl the hoooter.....
Jason DiPietro supercat 19
Re: Spinnaker on a 14? [Re: dsltrc] #118488
09/26/07 08:15 PM
09/26/07 08:15 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
I am not saying that I don't like hooters, I just like spinnakers more. From what Rick says the hooter is just as fast if not faster so who knows.
Re: Spinnaker on a 14? [Re: dsltrc] #118489
09/26/07 11:05 PM
09/26/07 11:05 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Can you post a photo??
I say go for either.
I have sailed Windrush 14s a lot and I am sure you could arrange it so it added lift and a lot of speed.
Re: Spinnaker on a 14? [Re: warbird] #118490
09/27/07 04:51 PM
09/27/07 04:51 PM
Largo, Florida
Largo, Florida
I'm currently researching the hooter idea. It seems most appealing since I do single-hand quite a bit and, as I understand it, the hooter furls. BTW, is it possible to launch and retrieve a spinnaker solo?
Does anyone have a used hooter you'd like to part with? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Spinnaker on a 14? [Re: papayamon2] #118491
09/27/07 05:20 PM
09/27/07 05:20 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
There is a post on this site by Rick about a Wave hooter...pretty agricultural looking but good photos and enough to create the right idea with good running gear ideas.
Re: Spinnaker on a 14? [Re: papayamon2] #118492
09/27/07 09:09 PM
09/27/07 09:09 PM
Sure it is just have to have the proper set up. Snuffing to a bag on the tramp would be more difficult than to a tube or sock hanging on the pole. Having a single line to hoist the spinnaker instead of having a seperate tack line makes things easier as well.
A furling hooter would probably be the easiest though. I "think" you can go to weather with a hooter as well. I don't know this for sure, but it looks like you could.
Re: Spinnaker on a 14? [Re: papayamon2] #118493
09/27/07 09:20 PM
09/27/07 09:20 PM
virginia beach, VA
dsltrc Offline
dsltrc  Offline
virginia beach, VA
my buddy Waldo has a hooter for sale... its in excellent condition... barely used....here is his e-mail... tell him jason D sent you vaplayero@cox.net heres a picture of my hooter set up.... his is a different material...
Re: Spinnaker on a 14? [Re: papayamon2] #118494
09/27/07 09:48 PM
09/27/07 09:48 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
It's very possible to launch and retrieve a spinnaker solo with a well sorted snuffer/retrieval system, in light and moderate winds, though it requires overall boathandling skills, as well as learning to use your particular set up. All of that will come with some pain and adventure. You'll never regret it!
dave
A cat
Flight Risk
SC20
lookin' for a F18
Re: Spinnaker on a 14? [Re: davefarmer] #118495
09/28/07 06:12 AM
09/28/07 06:12 AM
Largo, Florida
Largo, Florida
Thanks, Jason. Hey, you'd better edit your post and remove the @ from your friend's email. Otherwise, spambots will pick it up and he'll get lots of offers on his sail from Nigeria. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Re: Spinnaker on a 14? [Re: papayamon2] #118496
09/30/07 12:46 PM
09/30/07 12:46 PM
virginia beach, VA
dsltrc Offline
dsltrc  Offline
virginia beach, VA
i tried editing it but its not giving me the option... i really hope he doesn't get spammed.......
Re: Spinnaker on a 14? [Re: dsltrc] #118497
09/30/07 12:55 PM
09/30/07 12:55 PM
Largo, Florida
Largo, Florida
At any rate, I did email him but got no response. Maybe he doesn't have it anymore?
Kevin
Re: Spinnaker on a 14? [Re: papayamon2] #118498
09/30/07 12:57 PM
09/30/07 12:57 PM
virginia beach, VA
dsltrc Offline
dsltrc  Offline
virginia beach, VA
he does he's just busy i guess... i havn't been able to get him on the phone either.... i will get ahold of him this week even if i have to grab a sixer and pop by his house... lol.....
Re: Spinnaker on a 14? [Re: dsltrc] #118499
10/01/07 07:08 PM
10/01/07 07:08 PM
virginia beach, VA
dsltrc Offline
dsltrc  Offline
virginia beach, VA
well i got ahold of waldo tonight... i will be selling the hooter and pole for him as he is swamped with work... i will be getting pictures up this week... if anyone has any questions please e-mail me at jjd78 at msn dot com.......
Re: Spinnaker on a 14? [Re: dsltrc] #118500
10/02/07 07:08 AM
10/02/07 07:08 AM
Brisbane Queensland- Australia
Q
Qb2 Offline
Qb2  Offline
Q
Try this link then scroll down to "formula 14 cats in Australia"
http://www.thebeachcats.com/videos.html
compare the speed of the F14 under spin to other larger cats
Interestingly I was advised by AO builder Darrel Barrett I can put a hooter/spinnaker on my 20 year old AO4.4 and make it really perform but not a jib without strengthening the bows.
1 registered members (TimTT), 603 guests, and 90 spiders.
Topics22,404
Posts267,055
