| ATN Tacker, anyone? #119318 10/04/07 12:14 PM 10/04/07 12:14 PM |
Joined: Aug 2003 Posts: 241 Largo, Florida papayamon2 OP
Posts: 241 Largo, Florida | In my ongoing quest to rig a spin: Has anyone used a similar idea (or perhaps the smallest version) of the ATN Tacker instead of a spin pole on their cat? http://www.atninc.com/tacker.html(be sure to play the video to see it in action) Also, note that their snuffer douses from the top. Is this a normal alternative? I thought most were on the pole, but I could be wrong. Thanks! Kevin Largo, FL Trac 14 | | | Re: ATN Tacker, anyone?
[Re: papayamon2]
#119319 10/04/07 12:47 PM 10/04/07 12:47 PM |
Posts: 12,310 South Carolina | no, and no. You have to go out on the bow to get a spinnaker sleeve snuffer to work and even then, there is a rediculous amount of windage up there. The tacker thing depends on a headstay and again, you probably need to go up on the bow to set it up (not practical on a cat)...we all double slot with spinnakers leaving our jibs up so you have two slots; one between the main and the jib, and the other between the jib and the spinnaker. Mo power and mo efficiency.
Jake Kohl | | | Re: ATN Tacker, anyone?
#119320 10/04/07 12:58 PM 10/04/07 12:58 PM |
Posts: 829 Charleston, SC | MMMMM HMMMM, love me sum mo power! N20 baby... Papayamon, I recommend that you find a local sailor with a spin rigged cat and check out the snuffer system and the overall spin setup. It is much easier to understand when you are actually looking at it.
Trey
[Re: NCSUtrey]
#119321 10/04/07 09:48 PM 10/04/07 09:48 PM |
Posts: 263 SC | Wow Trey, that was good advise, IMPRESSED!
Always borrow money from a pessimist. He won't expect it back.
355
guests, and 44
