ATN Tacker, anyone? #119318
10/04/07 12:14 PM
10/04/07 12:14 PM
Largo, Florida
papayamon2 Offline OP
Largo, Florida
In my ongoing quest to rig a spin: Has anyone used a similar idea (or perhaps the smallest version) of the ATN Tacker instead of a spin pole on their cat?
http://www.atninc.com/tacker.html
(be sure to play the video to see it in action)
Also, note that their snuffer douses from the top. Is this a normal alternative? I thought most were on the pole, but I could be wrong.
Thanks!
Kevin
Largo, FL
Trac 14
Re: ATN Tacker, anyone? [Re: papayamon2] #119319
10/04/07 12:47 PM
10/04/07 12:47 PM
no, and no. You have to go out on the bow to get a spinnaker sleeve snuffer to work and even then, there is a rediculous amount of windage up there. The tacker thing depends on a headstay and again, you probably need to go up on the bow to set it up (not practical on a cat)...we all double slot with spinnakers leaving our jibs up so you have two slots; one between the main and the jib, and the other between the jib and the spinnaker. Mo power and mo efficiency.
Re: ATN Tacker, anyone? [Re: Jake] #119320
10/04/07 12:58 PM
10/04/07 12:58 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
MMMMM HMMMM, love me sum mo power! N20 baby...
Papayamon, I recommend that you find a local sailor with a spin rigged cat and check out the snuffer system and the overall spin setup. It is much easier to understand when you are actually looking at it.
Trey
Re: ATN Tacker, anyone? [Re: NCSUtrey] #119321
10/04/07 09:48 PM
10/04/07 09:48 PM
SC
zander Offline
zander  Offline
SC
Wow Trey, that was good advise, IMPRESSED!
Always borrow money from a pessimist. He won't expect it back.
0 registered members (), 477 guests, and 37 spiders.
