| Re: mast rake hobie 18
[Re: wildtsail]
#11945 10/25/02 05:55 PM 10/25/02 05:55 PM |
Posts: 1,459 Annapolis,MD | When I say side-to-side I mean on the minor axis of the mast section, not necessarily on the boat, poor choice of words on my part.
A mast using pre-bend has its bend forced into it by the diamonds on the major axis, or front-to-rear, or thick direction of the mast.
A mast using the loose diamond technique (no pre-bend) will bend along both the minor and major axis of the mast section, with the amount on minor axis bending depending on the looseness of the diamonds. Of course the stays and mainsail hold the stick up, but the curve formed by the mast will be along the minor axis of the mast section. Some believe this allows the mast to interfere some with the jib slot (depending on rotation), something to consider with the 18 as the jib overlaps a fair amount. With this technique you run the diamonds looser to depower, tighter to power up. Mast rotation plays a critical role in using the bend allowed by the loose diamonds. On this type of rig you over-rotate to flatten/depower, but when going upwind that presents the flat section of mast to the wind, detrimental when it's really blowing.
There's a section in Catamaran Sailing for the 90's on this I believe, and details the different idea for how to run the diamonds, with pictures illustrating the slot issues. This is almost a technique mid-way between pre-bend and loose. By keeping the wires tight enough to prevent minor axis bending, you are essentially using your sail fully powered up as the default case - something some people (including myself, but I sail heavy) don't mind because they feel that the sails are a little flat by default anyway. When you crank on the downhaul, the mast bends mostly on the major (front-to-rear) axis, giving a pre-bend effect. When you rotate the mast now, the curve of the mast moves away from the slot. Bad thing here is I've noticed that if you over-rotate by accident the top of the mast can bend out of column, giving a wierd shape. When you see this decrease rotation. This also may be a little rough on the luff of the sail, as it is now fully responsible for forcing bend where before the loose diamonds would do a lot of that.
Which is faster? I'm not sure, honestly. I sail mostly against other designs in portsmouth, so I don't have two-boat comparisons to relate. I like the logic of the "stiff" mast approach and that's what I use, mostly because I don't have to mess with diamond wire tension anymore (getting old and lazy...). But I also appreciate the fact that the sails are cut for the loose rig, so maybe that's better. Someday with nothing else to do I'll revisit the loose rig and see if there's a noticeable difference good or bad. But I'll probably just enjoy being out sailing instead! ;-) | | |
2,752
guests, and 308
