Decks on a 5.2 #119546
10/08/07 01:06 AM
10/08/07 01:06 AM
Norman,OK
gree2056 Offline OP
gree2056  Offline OP
Norman,OK
This winter I plan to rip the top decks off my 5.2 and fix the stringers and bulkheads in my boat.
I have seen a post somewhere about how people have done this before. If anyone knows where to find info on how to do it please post it here or send me a pm.
Yes I did search but nothing came up.
Re: Decks on a 5.2 [Re: gree2056] #119547
10/08/07 03:12 AM
10/08/07 03:12 AM
Brisbane Queensland- Australia
Q
Qb2 Offline
Qb2  Offline
Q
i don't know what i'm doing so here goes.
go to http://www.catsailor.net/cgi-bin/Ultimate.cgi?action=intro&BypassCookie=true
which is an Aussie website and look in the nacra forum
hope the link works
Re: Decks on a 5.2 [Re: Qb2] #119548
10/08/07 03:48 AM
10/08/07 03:48 AM
japan
erice Offline
erice  Offline
japan
hi gree, perhaps you mean this one
http://www.catsailor.net/cgi-bin/ubb/Forum5/HTML/000406.html
eric e
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Decks on a 5.2 [Re: gree2056] #119549
10/08/07 12:41 PM
10/08/07 12:41 PM
Rockledge Cay, FL
Fearless_Rider Offline
Rockledge Cay, FL
First off let me attest that my fiberglass skills are far better than my typing abilities... with that being said...
I removed both decks on my 5.2, forward and aft of the front beam. It is well worth the effort. I ended up installing several bulkheads and performing multiple repairs on delaminated stringers, adding about 6 lbs per hull. It was very similar to the job I did on a P19 which has a common failure of buckling on the forward hulls of older boats. Often this is seen as a 3 to 4 foot long horizontal crease on the forward sides of the P19 hulls.
I'll try to edit this post often, adding information as it comes to me... <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
N5.2 removal of the forward decks are pretty straight forward, using a very thin chisel or thick scraper and a hammer. Tap the chisel into the seem between the decks and the hull lip all around the perimeter of the deck. Don't be afraid to show the boat "who's the man!" It's better than suffering the consequences of an internal buckling failure which will rip the boat apart, literally. It may take several times around to lift the decks off. My decks splintered a bit, but were repairable with cloth and resin. Before doing the internal work, I separated the hulls from the beams so that I could lay them on their sides on saw horses. I believe I added 2 additional bulk heads to each of the forward hulls. I fabricated them out of foam and epoxy with cloth. I generated cardboard cut outs first to get the shapes of the bulkheads. Once the bulkhead layups were cured, I used 2 inch wide strips of nondirectional cloth with epoxy to secure in place. I also repaired alot of delaminations and cracks in the stringers. I really couldnt do much work to the bridle attachment tangs because of the narrow width of hulls that far forward.
Re: Decks on a 5.2 [Re: Fearless_Rider] #119550
10/08/07 12:47 PM
10/08/07 12:47 PM
Norman,OK
gree2056 Offline OP
gree2056  Offline OP
Norman,OK
Fearless,
I am going to send you a pm and try and pick your brain about how to do this.
Re: Decks on a 5.2 [Re: gree2056] #119551
10/08/07 01:53 PM
10/08/07 01:53 PM
Searched this forum and all other sources. Are the N5.2 hulls made from fiberglass with epoxy or polyester "adhesive"?
Re: Decks on a 5.2 [Re: ] #119552
10/08/07 02:18 PM
10/08/07 02:18 PM
Rockledge Cay, FL
Rockledge Cay, FL
polyester resin... old school. I choose to do structural repairs with epoxy or vinyl ester resins. I choose cloth material depending upon location on structure.
BTW, my BBQ Rocks!
0 registered members (), 311 guests, and 55 spiders.
