mast rotator Nacra 5.2 #119982
10/10/07 08:20 AM
10/10/07 08:20 AM
jpmahoney Offline OP
My new to me 1976 5.2 #185 hase some funky issues. This is my first Nacra so maybee its me. The mast rotation controll seems to be set up on the wrong side of the boom.
It should be on the top of the boom as the boom mounts below the rotator. Why would it be set up on the bottom of the boom, the same side as the bails for the main sheet?
It also has some kind of a reefing line led out behind the outhaul car.
Re: mast rotator Nacra 5.2 [Re: jpmahoney] #119983
10/10/07 08:30 AM
10/10/07 08:30 AM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
my '76 5.2 had a straight rod as the the rotator arm that I removed and put the regular arm that you can buy from Layline or Murray's for about $20. My NACRA F18 has it mounted on top of the boom. Some have them on the bottom of the mast, really doesnt matter, as long as it works for you and doesnt bind when rotating.
BTW, save the straight arm, as it made a really good striker for a windsurfer tapered alum mast that I turned into a spin pole.
Re: mast rotator Nacra 5.2 [Re: dave mosley] #119984
10/10/07 08:37 AM
10/10/07 08:37 AM
I rember now that the mast is not original to the boat. and I think the seller of the boat got the mast just before i bought the boat. He never used it with this mast.
The mast has the new style rotator and the old mast probaly had the straight rod below the boom.
Re: mast rotator Nacra 5.2 [Re: jpmahoney] #119985
10/10/07 09:10 AM
10/10/07 09:10 AM
dallas tx
airborne Offline
airborne  Offline
dallas tx
This is how mine was.
airborne
nacra 5.2 #2410 live long and prosper
Re: mast rotator Nacra 5.2 [Re: airborne] #119986
10/10/07 09:57 AM
10/10/07 09:57 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
Mine is like Airborne's. IT works well and makes for easy adjustments.
Re: mast rotator Nacra 5.2 [Re: gree2056] #119987
10/10/07 02:33 PM
10/10/07 02:33 PM
I will switch the gear on the boom from the bottom to the top.
On another note, I noticed that one of my rear beam attachment straps seems to short. I am attaching a photo. What do you think?
Re: mast rotator Nacra 5.2 [Re: jpmahoney] #119988
10/10/07 03:24 PM
10/10/07 03:24 PM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
Are you tightening with a torque wrench? 19 ft-lbs or so? Clean, greased bolts? Perhaps the other side of the strap was cinched down all the way first? Is the other sides wedge/washer installed correctly?
Re: mast rotator Nacra 5.2 [Re: bobcat] #119989
10/10/07 04:49 PM
10/10/07 04:49 PM
dave mosley Offline
dave mosley  Offline
not saying it was right, but mine was like that too..and still is. It never tightened down all the way on any of the bolts. Jake, did yours?
Re: mast rotator Nacra 5.2 [Re: bobcat] #119990
10/10/07 04:58 PM
10/10/07 04:58 PM
japan
erice Offline
erice  Offline
japan
there are references in the nacra manual to the beam straps being different lengths from front to back. but it's possible you have a short where you need a long
as the manuals often cover 6 models i haven't quite worked out if the 5.2's straps are all the same length or not. if not they must be very close
during my winter pull down i will lay a bit of paper over the contours of the free straps and mark their lengths to check
a minor trainspotters detail on the mast rotators is that you can see from above that airborne's 5.2, (2410), arm has been formed smoothly from 1 bit of stainless and then a small section welded in to form a large vertical hole for the rotator control line. this is the style you see for sale from murrays etc, but the rotator arm on mine (2158), has been made of 2 bits of stainless crimped together with a small horizontal hole holding a shackle and a small pulley for the control line
very nice work on your barber haulers airborne, think our lake is too small and i'll be too busy solo to bother with them, spins or hooters
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: mast rotator Nacra 5.2 [Re: erice] #119991
10/10/07 11:44 PM
10/10/07 11:44 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Before you do that...
Re: mast rotator Nacra 5.2 [Re: erice] #119992
10/10/07 11:45 PM
10/10/07 11:45 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
and
Re: mast rotator Nacra 5.2 [Re: warbird] #119993
10/10/07 11:46 PM
10/10/07 11:46 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
annnnd.
Re: mast rotator Nacra 5.2 [Re: warbird] #119994
10/10/07 11:49 PM
10/10/07 11:49 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
So, there might be a reason your boat is set up that way. First look for telltale holes that would indicate aftermarket change. Then look for reasons for the change. Somebody did it for a reason........
Re: mast rotator Nacra 5.2 [Re: warbird] #119995
10/10/07 11:51 PM
10/10/07 11:51 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
It would keep it off the foot of the sail, that would be nice. But mine works fine!
Re: mast rotator Nacra 5.2 [Re: bobcat] #119996
10/11/07 10:18 AM
10/11/07 10:18 AM
I noticed that the front and main beams use different part #'s for the straps. The strap that does not fit on the rear beam fits fine in the front. So I ordered a new rear beam strap.
Re: mast rotator Nacra 5.2 [Re: warbird] #119997
10/11/07 10:21 AM
10/11/07 10:21 AM
Nice carbon mast. Do you know the part # of those diamond stay Tangs? I am upgrading what I have.
JM
Re: mast rotator Nacra 5.2 [Re: jpmahoney] #119998
10/11/07 03:37 PM
10/11/07 03:37 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
JM
No, just reference photos I keep for my projects and I thought they might come in useful for understanding how the under boom spanner might be set up.
0 registered members (), 21,235 guests, and 930 spiders.
Most Online23,137
12 minutes ago
