| mainsheet systems #120409 10/18/07 03:11 AM 10/18/07 03:11 AM |
Joined: Aug 2007 Posts: 142 3 weeks Newman WA 1 week Robe ... Brian P OP
Posts: 142 3 weeks Newman WA 1 week Robe ... | hi guys, sorry to bring up that old dead horse subject. but i am about to change my mainsheet system as it seems to be putting me in to trouble more than what i want. the plan is to try the forward ratchet off the centre beam system( i.e darryn kopp/ peter nikitin) instead of the all on the traveller system ( i.e ugg the caveman).BUT......would like to sail MKII and wondering if any MKII guys find this system gets in the way?????? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" />
Brian Partridge STINGRAY 580 "Fantasia" A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD BUT YOU CAN ROLL IT IN GLITTER!!!!!
| | | Re: mainsheet systems
[Re: Brian P]
#120411 10/18/07 07:42 AM 10/18/07 07:42 AM |
Joined: Jan 2006 Posts: 556 Somers, Westernport Bay, Victo... Peter_Foulsum
Posts: 556 Somers, Westernport Bay, Victo... | Brian,
Trouble; Why trouble ???
When my son Andrew used to crew for me the centre sheeting was the first thing to go. When I bought my Mozzie it was set up as cat rigged then we put the jib on for some casual family sailing. It was just such a pain <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" /> and we would both end up too far rearward during tacking manouvers. The Mozzie would virtually stop dead until we got set up again in our proper positions again.
It was far better to get rid of the mess and have the whole trampoline area free for the crew to move around on.
Peter
Mosquito 1814 Macka Mozzie
[Re: Brian P]
#120412 10/18/07 09:55 PM 10/18/07 09:55 PM |
Joined: Mar 2003 Posts: 943 East Gippsland, Australia Tim_Mozzie
Posts: 943 East Gippsland, Australia | It probably depends on how big your crew is. Gary Maskiell sailed "Perfect Score" as a sloop with a centre mainsheet cleat on the beam. He had his son crewing, who was probably about 12 or 13 at the time. He won the states so it can't have been too much of a hindrance.
You can also put the ratchet block on the boom and run the sheet from there like I do (if you don't need a cleat). Then there's nothing in the crew's way.
Tim Shepperd Mosquito 1775 Karma Cat
[Re: Tim_Mozzie]
#120413 10/19/07 12:22 AM 10/19/07 12:22 AM |
Posts: 79 | Our first two boats were rear beam sheeting, the next two centre beam and the latest rear beam, all sloop rigged. At the moment my son sails with centre sheeting and I have rear beam and to be honest it doesn’t make much difference if it is set up properly. If you go with centre sheeting you will need enough room for your crew to cross the tramp in front of the block. The centre block also acts as a barrier when tacking keeping the crew forward or the skipper back depending on your point of view. We changed to rear beam sheeting a couple of years ago because of the extra rope added to the boat with the spinnaker.
Regards, Peter
Peter First Try
[Re: First_Try]
#120414 10/19/07 05:01 AM 10/19/07 05:01 AM |
Posts: 142 3 weeks Newman WA 1 week Robe ... | ok thanks all you guys who offered ideas. the question is with the centre beam sheeting do i need to get an opening stitched into the tramp for the pulley/cleat?
[Re: dkd]
#120416 10/19/07 06:14 PM 10/19/07 06:14 PM |
Posts: 142 3 weeks Newman WA 1 week Robe ... | thanks david. i have some work to do at the new destroyer base while i have my "two weeks off" there was something strange about my "two on two off" the boss meant two weeks in the mine, then two weeks working in adelaide. anyway, thats put me just near pete so i will probably call in for a chat. cheers mate.
[Re: Brian P]
#120418 10/20/07 06:32 PM 10/20/07 06:32 PM |
Posts: 943 East Gippsland, Australia | with the centre beam sheeting do i need to get an opening stitched into the tramp for the pulley/cleat? Yes if you are mounting a swivel/cleat. If you just want a ratchet block you only need either a tab stitched on (a lot of A-classes seem to have this) or an eyelet punched in either side of the beam - then you just tie a loop of rope around the beam and attach the ratchet block to that.
[Re: Tim_Mozzie]
#120419 10/20/07 06:45 PM 10/20/07 06:45 PM |
Joined: Jun 2004 Posts: 502 Port Noarlunga, SA, Australia Darryn
Posts: 502 Port Noarlunga, SA, Australia | with the centre beam sheeting do i need to get an opening stitched into the tramp for the pulley/cleat? Yes if you are mounting a swivel/cleat. If you just want a ratchet block you only need either a tab stitched on (a lot of A-classes seem to have this) or an eyelet punched in either side of the beam - then you just tie a loop of rope around the beam and attach the ratchet block to that. When I was experimenting to find the right spot to mount the ratchet block I just opened up the weave of the tramp a bit with a scribe and tied the block to the center beam with some 3mm dyneema. I sailed 6 races this way and it didn't do any damage to the tramp. Darryn 1782 | | |
2,481
guests, and 481
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 11 hours ago | | |
