Help on shim material for G Cat rudder castings #120716
10/21/07 07:58 PM
10/21/07 07:58 PM
Lake Murray SC
FasterDamnit Offline OP
Lake Murray SC
OK-
One casting is not bad but one is quite loose (rudder moves side to side in casting w/ rudder down.) I do not want to try and bend the casting as cast aluminum is pretty brittle. I have read up on prepping/aligning and shimming rudders, but with this unique frame, any advice on lining them to take up the slack? I know a more common rudder setup would be easier, but for now need to work with the stockers.
Thanks,
Jim.
E-Scow
24' ULDB
Re: Help on shim material for G Cat rudder castings [Re: FasterDamnit] #120717
10/21/07 08:06 PM
10/21/07 08:06 PM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
Have you heard of Marine-Tex?
How about building up the rudder at one point so that it is tight in the frame when down? This would be a mound about the size of a quarter.
Re: Help on shim material for G Cat rudder casting [Re: bobcat] #120718
10/21/07 08:11 PM
10/21/07 08:11 PM
Lake Murray SC
Lake Murray SC
Oh yeah!
LOTS of Marine-Tex on these hulls and rudders to smooth out all the dings and rash. Good idea. Thanks! <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: Help on shim material for G Cat rudder casting [Re: FasterDamnit] #120719
10/22/07 06:27 AM
10/22/07 06:27 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
You could also try small plastic ties on each side. Cheap, no waiting, no sanding.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Help on shim material for G Cat rudder casting [Re: Chris9] #120720
10/22/07 07:36 AM
10/22/07 07:36 AM
Lake Murray SC
Lake Murray SC
Another good one!
Thanks.
Re: Help on shim material for G Cat rudder casting [Re: Chris9] #120721
10/22/07 09:04 AM
10/22/07 09:04 AM
Kennethsf Offline
Kennethsf  Offline
tie wraps are the best for loose rudders!!
Re: Help on shim material for G Cat rudder casting [Re: Kennethsf] #120722
10/22/07 09:32 AM
10/22/07 09:32 AM
SC
zander Offline
zander  Offline
SC
I'm not sure how it would work on a G cat but I used to mix up some of that epoxy stick stuff. and jam it in the bottom of the casting. Wrap the corrisponding part of the rudder with saran wrap and lock the rudder down, let it dry overnight. You can always knock the chunk back out if you want to make an adjustment, an re-do it. It worked really well on my Hobie 20, I haven't tried it on the N-20 but I probably should.
Always borrow money from a pessimist. He won't expect it back.
Re: Help on shim material for G Cat rudder casting [Re: zander] #120723
10/22/07 12:16 PM
10/22/07 12:16 PM
Lake Murray SC
Lake Murray SC
Like plumber's putty?
Re: Help on shim material for G Cat rudder casting [Re: FasterDamnit] #120724
10/22/07 01:06 PM
10/22/07 01:06 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Not exactly. You can buy the epoxy sticks in Home Depot/Lowes or most hardware stores. I use the stuff for marine applications that is colored green on the outside and grey on the inside of the stick. You just cut off as much as you need and roll it out thin then fold in half and roll again. Repeat as many times as it takes to get a homogenous color. It dries off white and is excellent stuff to keep on hand for field repairs.
Chris.
Re: Help on shim material for G Cat rudder casting [Re: FasterDamnit] #120725
10/22/07 07:15 PM
10/22/07 07:15 PM
maui
jollyrodgers Offline
maui
zip ties seem like a good idea.
you can also contact cement formica to the head of the blade.
Re: Help on shim material for G Cat rudder casting [Re: jollyrodgers] #120726
10/22/07 07:21 PM
10/22/07 07:21 PM
SC
zander Offline
zander  Offline
SC
Thanks Flumpmaster that's the stuff I was talking about.
0 registered members (), 477 guests, and 37 spiders.
