Rudder Adjustment Systems #121995
11/01/07 03:24 AM
11/01/07 03:24 AM
New Zealand
G
GoGecko Offline OP
GoGecko  Offline OP
G
New Zealand
I sail in shallow waters with an A Class cat and dont trust the rod rudder system so wonder if anyone has a real;y simple shock cord type arrangement so if hit anything the rudders will kick up and then drop down when I am past the sand bank.
Also just wondering if anyone has any data on opttimum rudder centreboard lengths for optimum upwind performance.
The reason I ask is that I am considering shortening the rudders and making shallow centreboards to ease the worry of ripping the centrboard cases out when sailing fast in the shallows.
I figure the ruders can be shortened to a point when I still have steerage downwind in a seaway.
Re: Rudder Adjustment Systems [Re: GoGecko] #121996
11/01/07 04:03 AM
11/01/07 04:03 AM
japan
erice Offline
erice  Offline
japan
ok i'm give it a shot
a system where the rudders kick up is easy, a system where they go back down is either impracticable or impossible, otherwise makers would be selling it. we all want it!
the problem is pre-load. enough to kick the rudders up before damage is possible as is a pre-load to pull them down
but both working together and against each other would mean rudders at about half way tending to steer poorly, not kick up correctly or stay down either.....can't see how you can have your cake and eat it too
same for optimum dagger board length
optimum length for upwind performance is probably infinite length.....but that's too long so they make them shorter
how much shorter depends on the maker. hobie think zero length is best while modern a-class boat makers think very long is good. the amount of variables that come into play is enormous. hull design, cost, weight etc
any engineer can build a better system if he is allowed to make it heavier and more expensive. where they earn their keep is by making them lighter and cheaper
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
0 registered members (), 17,356 guests, and 624 spiders.
Most Online22,490
Yesterday at 08:14 AM
