Mast head hook scratches the mast #122231
11/05/07 05:12 PM
11/05/07 05:12 PM
M
mrohrer Offline OP
mrohrer  Offline OP
M
How do prevent from scratching you mast while raising/lowering the sail? The hook at the head of the sail brushes against the mast. I’ve tried taping it, but it just gets ripped off from locking it in the mast tip hole. This is pretty disturbing because it’s leaving scratches up and down nearly the entire mast.
Thanks,
Mike Rohrer
Re: Mast head hook scratches the mast [Re: mrohrer] #122232
11/06/07 10:55 AM
11/06/07 10:55 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
Mike:
The hook at the top of the sail will scrape down the side of the mast. I have put my sail up hundreds of times and there is no sign of wear on the mast of my Tiger.
Maybe you have a sharp thingy on the hook. Check to see if there is something you could file off and sand smooth so there is nothing that could scratch the mast.
Sorry if you already tried this I cannot figure out why you are messing up your mast.
Later,
Dan
Re: Mast head hook scratches the mast [Re: Dan_Delave] #122233
11/14/07 06:24 AM
11/14/07 06:24 AM
couldn't resist it
Codblow Offline
Codblow  Offline
couldn't resist it
my A class did same thought of running a length of pvc tape where scratches were and replace when starting to wear through , it was in days of Ally masts so I wasn't unduly bothered and never got round to it , with a carbon mast would be more important , judicial filing i expect would help .
I think I also used to rotate mast slightly when pulling sail up to face hook away from mast , worked with A because of relative short foot (chord ?) length and sail would still pull up .
1 registered members (JesperS), 759 guests, and 38 spiders.
