| Re: Tornado ruled out by ISAF
[Re: ]
#122719 11/10/07 06:01 PM 11/10/07 06:01 PM |
Joined: Sep 2006 Posts: 613 New Hampshire, USA windswept
Posts: 613 New Hampshire, USA | I think that the Laser is a good case in point. It is a specific and tightly controlled one-design class. Throughout an Olympic campaign you will go through 2 hull, many different masts, sails, rudders and daggerboards either trying to find the best equipment available or because your boat has taken enough of a beating that it is no longer as stiff as you need it to be. Somewhere earlier on another thread about this topic, I went over a Laser selecting event that happened in Boston, actually just north east of Boston, where over 100 hulls, masts, booms, sails, rudder blades and daggerboards were present. For the next 12-24 hours they were sorted through to find the best of each. You were looking at sail shape, hull stiffness and fairing, etc... This is a ritual and a time consuming process. On Tornados we purchased either a Marstom, reg White, Sailcraft of Canada or Lindsay. Maybe we raced home-built boats, Holton or Gougoen. There were competent Australian builders (Boyer for one) and so-on. We faired our own hulls or had someone fair them and went out racing. These boats changed over time and Marstrom became the builder of choice with 90%+ of the market. They are race ready, last 8-12 years competively and until now held their market value. We keep hearing about the cost of a Tornado compared to other Olympic classes, but not even a Star has the racing life of a Tornado. A laser campaign will probably run $20,000 for the campaign, while a Tornado may run in excess of $40,000. A Star is in the $60,000 range. These are for the platforms, rigging, sdails and so-on. But lets also remember that the vehicle on which to compete is the smallest portion of the Olympic campaign budget. I was talking to a couple of Olympic sailors who put the overall cost of a campaign for 2004-2008 upwards of $400,000. So that puts the boat at 10% of the overall budget.
Tom Siders A-Cat USA-79 Tornado US775
[Re: rhodysail]
#122720 11/10/07 07:58 PM 11/10/07 07:58 PM |
Posts: 1,884 Detroit, MI | Personally I can't see any reason to retain my membership. It would probably be viewed as a small gesture I guess, but if 305 members resigned en masse it would at least indicate what the cat community thinks about this.
I did just that yesterday and also stepped off the MHC. I've heard about as much lip service as I can stand. Unfortunately, because ISAF Regulation 19 applies to the H-16 North Americans (participants in a North Americans of an ISAF International Class must be members of their MNA), that means you won't be eligible to sail in the 16 NA's in Clear Lake, Iowa next year. You might want to reconsider that, Bob. You can bet your butt that I'm going to corner David Sprague at the ODSS next weekend and inquire why he voted against the multihull. BTW, I'm planning to wear black all next weekend at the ODSS in protest.
[Re: Catfan]
#122722 11/10/07 10:15 PM 11/10/07 10:15 PM |
Posts: 1,307 Asuncion, Paraguay | A few thoughts:
FIRST This development (no multihulls in the Olympics) can be seen as a direct consequence of the inexistence of a suitable “entry cat” competing in the same market niche of the Optimist. I believe that an "entry cat program" is the most important action for the middle and long term development of multihulls.
SECOND ISAF chose the equipment BUT the classes haven't been chosen yet AND "dinghy" does not necessarily mean monohull.
It is possible to lobby immediately for the A Class (or another single-handed dinghy cat) to replace the Finn, Laser and/or Laser radial - and for the Tornado (or another double-handed dinghy cat) to replace the 470, 49er or women' 470.
If I had to choose one move only, I'd go for the A Class instead of the Finn or Laser. After the tests in Quiberon a few years ago, the A Class refused an invitation to be the Olympic "high performance dinghy".
This would be a short term move with fair possibilities of success.
THIRD IF the Tornado class is to die due to the loss of Olympic status, it will open space to develop a new B Class, replacing the old one, which was killed by the Tornado (a B Class cat) selection for the games. It will be quite interesting to see a 20ft X 10ft development class following the A Class rules or (even better) the C Class rules.
FOURTH I am not sure if excluding the multihull event from the games is such a big loss in terms of visibility. The giant multihulls and the new ORMA 70 one design will remain more visible and attractive for the media.
FIFTH Time changes things. "If you seat long enough by the river, you will see your enemy's body pass" (Chinese proverb).
Just my 2 cents...
Luiz
[Re: Luiz]
#122723 11/10/07 10:24 PM 11/10/07 10:24 PM |
Posts: 4,119 Northfield Mn | "If you seat long enough by the river you will see your enemy's body pass" (Chinese proverb). Some need bigger rivers than others. Slightly off topic but, someone lately told me that you atrract more flies with sugar, but have you ever noticed the abundance of flies around a body? | | | Re: Tornado ruled out by ISAF
[Re: rhodysail]
#122726 11/11/07 02:28 AM 11/11/07 02:28 AM |
Posts: 917 Issaquah, WA, USA | When we met at the US SAILING AGM in Phoenix last month and represented you, the Multihull Sailors, the Multihull Council was pleased to report, as noted in another post, the USA Olympic Sailing Committee submitted to the ISAF the recommendation for the 2012 Olympics to include two multihull classes. The three USA ISAF members decided to go against the recommendations of US SAILING and voted to eliminate the multihull class in the 2012 Olympics. You may wish to share your feelings with the three USA ISAF Delegates: David Irish daveirish@irishboatshop.comCharley Cook chascook@comcast.netCory Sertl corysertl@rochester.rr.comBe polite, but let them know what you think of their decision. Caleb Tarleton, Multihull Council | | | Re: Tornado ruled out by ISAF
[Re: _flatlander_]
#122727 11/11/07 04:12 AM 11/11/07 04:12 AM |
Posts: 9,582 North-West Europe | Are we planning on writing a new rule book as well?
Why ? When my great-great grandfather was hauling fish out of the sea some 200 years ago on a sailing fishing vessel near Iceland he used the same internationally accepted "right of way" rules as we do now. ISAF is just an organisation that "claims" ownership of these rules. Besides one of the most simple things to do is right up these rules there is not to much there and frankly speaking they could use someone looking them over for clearity and unambiqious wordings. Wouter
[Re: Luiz]
#122729 11/11/07 04:36 AM 11/11/07 04:36 AM |
ISAF in general is against FORMULA based classes. It doesn't understand them and I religiously believes that strict One-Design, or rather Single-Manufacturer-One-Design, is the best form of sailboat racing.
Therefor any A-class, B-class or Formula 18 class are out of the question. They already had trouble accepting the "OD status but not SMOD" status of the Tornado where everybody could use different masts and sails.
Additionally a dinghy is most definately regarded as a Monohull by the whigs mostly because they don't consider Multihulls as real boats to begin with.
I wonder, is the ORMA 60 class a ISAF recognised class ?
But they certainly make no hassle about that, I guess because the French ORMA organisation is to powerful to pick a fight with. We need something like that for small catamaran racing.
[Re: Luiz]
#122730 11/11/07 04:40 AM 11/11/07 04:40 AM |
Posts: 9,582 North-West Europe | This development (no multihulls in the Olympics) can be seen as a direct consequence of the inexistence of a suitable “entry cat”
We are already working on covering that angle ! As you know. Wouter
[Re: H17cat]
#122731 11/11/07 07:05 AM 11/11/07 07:05 AM | Anonymous
| Anonymous
Unregistered | Caleb, can you clarify the relationship between the ISAF delegates and US Sailing. Who are the delegates appointed by, if not US Sailing, and if they are appointed by US Sailing what kind of authority do they have to disregard US Sailing's recommendation? | | | Re: Tornado ruled out by ISAF
[Re: Wouter]
#122732 11/11/07 07:11 AM 11/11/07 07:11 AM |
Posts: 1,307 Asuncion, Paraguay | This development (no multihulls in the Olympics) can be seen as a direct consequence of the inexistence of a suitable “entry cat”
We are already working on covering that angle ! As you know. Wouter Yes, but internal marketing is necessary to obtain momentum and I think the timing is good.
Luiz
[Re: rhodysail]
#122734 11/11/07 08:06 AM 11/11/07 08:06 AM |
Posts: 503 | Personally I can't see any reason to retain my membership. It would probably be viewed as a small gesture I guess, but if 305 members resigned en masse it would at least indicate what the cat community thinks about this.
I did just that yesterday and also stepped off the MHC. I've heard about as much lip service as I can stand. Im sure you have good reason. Id like also to hear what JW finds out about what happened with the US delegates before making any decision about US Sailing membership. As far as the argument that we as a sailing community should get more involved with US Sailing and work to have more of a voice... with enough volunteers, I would bet we could start from scratch, reproduce the majority of the benefits we receive from US Sailing, and then be in a much better position to control our own destiny long term. I think this would have to be a decision from our current multihull council members, but Id be the first to step on board to help. Viva Revolution! Catsailors have always been a different bunch! | | | Re: Tornado ruled out by ISAF
[Re: rhodysail]
#122737 11/11/07 12:20 PM 11/11/07 12:20 PM |
Posts: 1,884 Detroit, MI | 19. ELIGIBILITY CODE ISAF Eligibility Rules 19.1 A competitor whose ISAF eligibility has been suspended or revoked shall not engage in any competition in the sport of sailing. 19.2 To be eligible to compete in an event listed in 19.3, a competitor shall: (a) be governed by the regulations and rules of ISAF; (b) be a member of his/her Member National Authority or one of its affiliated organizations.
Events Requiring ISAF Eligibility 19.3 ISAF Eligibility is required for the following events: (a) the sailing regatta of the Olympic Games; (b) the sailing regattas of Regional Games recognized by the International Olympic Committee; (c) events including “ISAF” in their titles; (d) world and continental championships of ISAF classes and world championships of the IMS, Major Events and other events approved by ISAF as a World Championship; Technically true, however the NOR's for the last two 16 NA's have required MNA membership. Not that we've enforced it. | | |
16,438
guests, and 846
