proper use of jib sheets #1229
07/29/01 10:52 PM
07/29/01 10:52 PM
Anonymous OP
Anonymous OP
apart from having the issues of getting the jib battens to get past the mast on both tacks and jibes, i am wondering which sheet i should be using when trimming the jib. currently, i am letting both out and using the windward sheet to bring the jib in but it develops too much of a curl at the bottom, so i end up pulling on the leeward jib sheet to straighten the bottom out.
<br>
<br>is this the correct method?
<br>
<br>thanks in advance,
<br>jeff
<br><br><br>success is not having to work in may and october
<br>- art garfunkle
Re: proper use of jib sheets #1230
07/30/01 08:28 AM
07/30/01 08:28 AM
Anonymous OP
Anonymous OP
I recommend first setting the jib traveler cars at the right position for your point of sail. (more inboard for close-hauled and more outboard for broad-reaching). Then use the leeward sheet to tighten. I think you will find that this will help get rid of most of your hooking problems.
<br>
<br>kyle <><
<br>h16 80065<br><br>
1172- (61 downloads)
0 registered members (), 682 guests, and 86 spiders.
Posts267,056
