setting up rudders #123224
11/11/07 05:24 AM
11/11/07 05:24 AM
Vic Australia
mozzie1717 Offline OP
Vic Australia
just got a new set of rudders (made in ex boyer molds) with lock down systems and just wondering what the best way to set them up is. which edge is the wroking edge and how much under toe should i set them up with? just trying to figgure out where to drill holes etc. a pic of the style of rudder is atatched.
any thaughts guys
Cheers Lindsay
mossie
1717
Re: setting up rudders [Re: mozzie1717] #123225
11/11/07 06:30 AM
11/11/07 06:30 AM
Peter_Foulsum Offline
Lindsay,
Have a look at the AHPC website (link below)
http://www.ahpc.com.au/pdf/Using%20Smart%20Lk%20Snap%20System.pdf
This may give you some pointers.
As to how far under check out some of the pictures from the 2006 training weekend at Hazelwood. There are some photos of ruddes similar to yours. A link is provided to phot albums from the VMCA website.
Peter
Mosquito 1814
Macka Mozzie
Re: setting up rudders [Re: mozzie1717] #123226
11/11/07 05:06 PM
11/11/07 05:06 PM
East Gippsland, Australia
Tim_Mozzie Offline
Tim_Mozzie  Offline
Here's some tips. When the rudder is down -
1. The top part should be as far forward in the rudder box as possible - so it's as close to the pintles as you can get it.
2. The leading edge at the tip (bottom end) should be 5 to 15 mm in front of the centreline of the pintles - you can judge this by eye just by looking down the line of the pintles.
Both rudders should be set up identically.
The head of the rudder blade should be a snug fit in the box when it is down. It needs to be held solid in the box over the whole area of the box - not just at a point.
Of course, after you've done all that, the two rudders must be parallel to each other, and vertical (in line with the centreboards). It's no small task setting up rudders.
Tim Shepperd
Mosquito 1775
Karma Cat
Re: setting up rudders [Re: Tim_Mozzie] #123227
11/11/07 07:39 PM
11/11/07 07:39 PM
Vic Australia
Vic Australia
thanx for the tips guys. just wasnt quite sure how to go about it and didnt really want to stuff it up leaving several holes in my rudders that would need to be re glassed. i know its not a quick job and thats why the rudders have been siting around for almost a month because i havnt had time to fit them, but hopefully ill get them on the boat soon.
0 registered members (), 336 guests, and 67 spiders.
