| In the spirit of RG setting up web site addresses. #123351 11/12/07 06:23 PM 11/12/07 06:23 PM | Anonymous
| Anonymous
Unregistered | In order to guarantee that everyone wanting to develop a kids F12 is moving in the same direction, I've put together a prelim set of class rules. This document is intented as a starting point and I would welcome any feedback and be willing to change pretty much everything. www.ctmd.com.au/F12.pdf | | | Re: In the spirit of RG setting up web site addresses.
[Re: Seeker]
#123353 11/12/07 07:44 PM 11/12/07 07:44 PM | Anonymous
| Anonymous
Unregistered | Thats fine by me..
My original hulls had approx 20kg (10kg each) of ply in them including bulkheads, longitudinals centre case sides etc. The newer design has much less.
Where do people think the minium weight should be set? 45kg? (100lbs) | | | Re: In the spirit of RG setting up web site addres
[Re: RetiredGeek]
#123355 11/12/07 09:35 PM 11/12/07 09:35 PM | Anonymous
| Anonymous
Unregistered | Id rather just see a minimum beach weight as its quite hard to get a panel weight without cutting cores from the boat. I think we need to look at least 55-60 kg to make sure we end up with a durable boat, and to also allow the rotomolded crowd an even shot at producing a competitive boat as well.
I agree, however, do we really want to set a minimum weight heigher than the Paper Tiger (50kg) Also, based upon my perception of sentiment on the forum I've pulled the length back to 12 ft. Are the majority happy with that? | | | Re: In the spirit of RG setting up web site addresses.
[Re: ]
#123356 11/12/07 09:57 PM 11/12/07 09:57 PM |
Posts: 9,582 North-West Europe | Where do people think the minium weight should be set? 45kg? (100lbs)
Take a look at the weight analysis I did last earlier this year : http://www.xs4all.nl/~whijink/F12/F12_weight_and_cost_push_rod_setup.xlsI can't get it down to less then 63 kg ready to sail when using 4 mm ply. A rotomoulded version will be heavier by at least 15 kg according to my data. Even when using 3 mm ply (which is rather weak) you can't get it down to 45 kg overall while limiting yourself to only using simple materials and building methods. Wouter
[Re: ]
#123357 11/12/07 11:05 PM 11/12/07 11:05 PM |
Posts: 255 NZ | I agree, however, do we really want to set a minimum weight heigher than the Paper Tiger (50kg)
Also, based upon my perception of sentiment on the forum I've pulled the length back to 12 ft. Are the majority happy with that? The 50kg limit for a Paper Tiger is sans mast, boom mainsheet and sails, so its probably closer to 70-75kg with all the gear on it, so 55-60kg is still pretty agressive for something thats homebuilt or commercially produced. Another thing to think about is that if you set it too low, then a lot of creative people are going to start building carbon hulls which sort of defeats the purpose of trying to make these affordable. I know that if I got aggressive, I could probably build one under 50kg rigged but it would have no end of expensive stuff on it to get there. These are not A-Class cats, just a better performing Opti that hopefully a bunch of kids will want. Wouters weight estimate is reasonable within the bounds of keeping it reasonably cheap/affordable. As for the 12 ft, Im happy with that, what about everyone else ? RG | | | Re: In the spirit of RG setting up web site addres
[Re: RetiredGeek]
#123358 11/12/07 11:23 PM 11/12/07 11:23 PM |
Posts: 1,449 | My design is done at 12 ft 4.5 inches. It just happened this length allowed me to do what I wanted.
On the other side of the coin the beam , mast length and sail are a little less.
I will build it as light as I can without the use of materials that will increase the cost and based on my own estimates I hope to come in around 50kg.
The rules document is a good idea to provide some clarity and focus.
Regards, Phill
[Re: phill]
#123359 11/12/07 11:44 PM 11/12/07 11:44 PM | Anonymous
| Anonymous
Unregistered | RG can you please confirm your hull length to date? | | | Re: In the spirit of RG setting up web site addres
[Re: RetiredGeek]
#123361 11/13/07 05:38 AM 11/13/07 05:38 AM |
Posts: 9,582 North-West Europe | ... I presume Wouter wanted a rounded number in metric ? ...
Yes, and I wanted the maximal hull length that I could get, at these sized everything helps. Also this length turned out to be very nice mathematically, but I won't bore everybody too much with that. Basically at this length a scaled down F18 or F16 hull will optimally carry 105 kg combined boat + crew weight (at the time I assumed 60 kg for craft and 45 kg for crew). Therefor the F12 was directly comparable to both of these boats and it was easy to make initial conclusions about factors like pitching, overall drag and rig induced loads. As a matter of fact it shared an even more tight relationship to the Prindle 16 catamaran. Basically you can scale that and end up with a very good first try for a boardless F12 using a deep V-ed hull that is very easy to make. How much difference does going from 3.75mtr to 3.65 mtr (= 12 foot) make ? Well, when using the scaling operations to get a first try at the F12 hull then weight carrying ability would go down from 105 kg to 95 kg, which wasn't (isn't) negligiable. I'm personally fine with 3.8 mtr if we all wanted a nice rounded number. But, I rather not go to less hull length then 3.75 mtr though. Most of what I've done so far is done on 3.75 mtr. I strongly prefer keeping it there. Wouter
[Re: ]
#123362 11/13/07 06:14 AM 11/13/07 06:14 AM |
Posts: 9,582 North-West Europe | Scarecrow,
Here my initial suggestions regarding the class rules.
- sail area
Suffice by ruling that a sleeved sail area is determined solely by its total surface area and that the halve the surface area of the mast is to be added when the sail is not fully covering the mast itself (excluding the area below the boom).
- Hull length
I strongly prefer 3.75 mtr overall length or more.
- Panel weight
Remove this rule entirely. For equalizing the performance only the ready to sail weight is needed. Also, ruling on a panel weight assumes you can predict that in the future we will never be able to create cheap and strong panels that weight less than giving in the rule. We simply don't know that. It is also another thing to check when measuring and certifying and it is also as good as impossible to check. Basically, this rule has large drawbacks and hardly any benefits. Give the designers all the freedom they want in this area, no-one wants to design a fragile boat and customers will vote with their feet anyway when one tries.
- Mast
Completely unregulating the construction of the mast may well turn out to be a big factor in losing control over the costs associated with F12's. It also makes international shipping alot harder = more expensive. I have experience in shipping masts internationally now and a significant portion gets damaged in transport. Also shippers really hate long, thin and easily damaged goods. You are alright if you can strap ten or more of those together, but shipping single masts or a pair of them is asking for trouble. Also a 6 mtr. mast is hard to transport legally without using a boat trailer, which will add another 1000-1500 bucks to owning a F12.
I really would like the see a rule that enforces the mast to be collapsable in parts that are no longer then the hulls themselves. Based on my experience so far I'm convinced we'll be thankful for that choice later.
I'm also concerned that leaving the mast unregulated beyond being collapsable is still inviting trouble. Some will want to have tapered carbon masts or specialized shapes. Rotating a mast will immediately add various hardware that will again add costs. I think like that it will proof very hard to control costs. Additionally, potential buyers will became hesitant as they will feel (justified or unjustified) that more expensive parts will always be more performant.
Based on my experience with the landyacht classes I feel we should seriously consider a setup as they have. They rule that the mast must be made up of normal standardized prismatic aluminium round sections. And that if we wanted more performance that we should allow camber inducers rather then fully rotating masts.
I can write a full post on this, but I won't now. Suffice to say that there is both need and room for ample deliberations on this aspect.
As a matter of personal opinion, while I strongly favour a pure formula class rule setup for larger catamarans I'm convinced that that is not the right approach for an simple and inexpensive class like the F12's. Any reductions in complexity and cost we achieve initially will only make adding costs and complexity more interesting to both builders and sailors. At the level of cost and complexity we are looking at to make the class maximally accessible and affordable there will not be much of a selfregulating effect as is found in the F16 and F18 classes. In the case of the F16's customers refuse to pay more the 15.000, no matter how well the craft is fitted out and that keeps the F16's sharp. But at 3000 euro's for the F12 it will be much easier for alot of people to justify spending an additional 1000 Euro's just to get a small advantage over the other sailors.
I really do believe we must look at making the F12 a OD class (but NOT a SMOD class) where the most important aspects of the basic layout is regulated but where smaller factors sail design, rudder design and the way of implementing the basic design are left open. I'm thinking of :
- regulating closely the shape of the hulls (enforce fairness of racing and easy of building) - regulating the type of rig (stayed / unstayed, sloop, uni-rig etc) - regulating the major over all dimensions - regulating the more troublesome components like mast to a medium level (collapsable or not, material) - regulating to have or not parts like daggerbaords/centreboards, camber inducers, T-foils, etc.
The rest can be left open as their influence on overall performance is too small to really matter and you must use the group of designers and enthousiasts to find the best solutions over time.
[Re: Wouter]
#123364 11/13/07 07:17 AM 11/13/07 07:17 AM |
Posts: 461 Victoria, Oztralia | Hi All
Stayed out of the conversations for a while to see what would become of the F12 and it looks good.
Well done to those who have taken the time to design the cats, great to see new fresh designs being put out there.
I don't agree with making the F12 a OD, with 4-5 designs already presented, it will only lead to people proceding outside of the arena.
I would also like to say that the mast material be restricted to aluminium, I don't believe there should be any restriction on if the mast is one or more pieces, nor restrictions on stayed/unstayed rigs. There should be a sail area retsriction, but not to restrict things like luff or foot lengths.
Just my thoughts
Regards
Matt Harper
Homebuilt Taipan 4.9
[Re: Wouter]
#123366 11/13/07 09:24 AM 11/13/07 09:24 AM |
Posts: 9,582 North-West Europe | I'm continiously updating the info as provided through the F12 Website : http://www.xs4all.nl/~whijink/F12/It has taking a while by I know have a firm quote for a suitable F12 mast made from straight high 0.2% threshold aluminium tubing that will take a F12 sleeved mainsail. The mast can be taken apart into two or three parts. The same mast is used on the Promo landyacht which are becoming very popular. Its length is 5.5 mtr and the cost is 240 Euro's including 20% European taxes. The 5.5 sq mtr sail (not suitable to F12 as landyacht sails are too flat for soft water craft) cost 577 Euro's including 20% European taxes. However, the costs shouldn't change much when entlarging the sail and giving it more draft. The total load of a 5.5 sq. mtr landyacht sail in 20-30 knots of wind and a F12 rig in sub 20 knots winds are as good as identical. Please note here that Promo's use 5:1 to 7:1 purchase systems to sheet the sail as flat as a board. That is alot of rig tension ! The promo's are also 2 mtr wide and weight 60kg themselves and carry adults up to 90 kg without a fuss. Mast, sail, battens and boom will weight a total 14 kg or less. Say under 15 kg. That is certain now. Its centre of weight is below that of a normal prismatic mast as the promo mast is obviously tapered. I feel confident now that we can have a commericially build and offered F12 unstayed rig for 850 Euro's including 20% European taxes. The amount of EU taxation will be enough to cover shipping to any place in the world. This result still allows us to achieve the design goals of less the 3000 Euro for a ready to sail F12 and as this can be purchased ready to go it will also go a very long way in achieving the "building under 100 hours" design goal. The Dotan rudders are purchased as well. So that only leaves building the hulls, beams, push rods, trampoline and assembling the components. I think we can get darn close to 100 hours building time. Anyone out here want to look up dependable pricing for 5.5 to 7.0 sq.mtr surf masts and sails ? I would be very thankful if I don't have the spend the time to do that. I already invested alot more then I can justify. Wouter
[Re: Gato]
#123369 11/13/07 04:19 PM 11/13/07 04:19 PM |
Posts: 1,449 | Gato, While I think commercial construction has to be a primary objective to get them out there in numbers I agree regarding you rcomments on home building. I hope to provide plans that detail the construction in ply, foam and cedar strip depending on an individual's preference as well as detailed instructions on making the sail. The only marine fittings will be a couple of blocks. Everything else will be obtainable form a timber yard and hardware type store.
Regards, Phill
[Re: Gato]
#123370 11/13/07 08:30 PM 11/13/07 08:30 PM |
Posts: 9,582 North-West Europe | Well, here we go again. We are again at the point vere one is supposed to buy everything exept the hulls. Please keep the the design open for homebuilders...
You misunderstand my comments. All the components named can be easily homebuild. The fact that they can ALSO be bought ready to go for the given quotes only serves as proof of the maximal costs and economical viability when a company starts building these commercially. Of course lazy homebuilder can make use of these option if they want to get a craft quickly on the water. Actually Landyachting (and iceyachting) is far more homebuilder oriented then any other sailing craft. It is a good place to steal tricks from. Actually the commercial landyacht builders often use the same tricks and designs as developped by homebuilders. From the beginning (that is now several years ago) I tried to design the craft in such a way that both homebuilding and commercial builder would be practical. We must all learn to think in terms of ".... and ..." instead of "... or ...". We must fight the Pavlovian tendency to equated everything commercial with being hard to copy by homebuilding. That is when looking at my design and proposals. I'm not so sure the same holds for some of the other designs. Wouter
2,515
guests, and 95
