| Re: Update On building mosquito
[Re: Matt_Stone]
#124325 11/21/07 01:27 AM 11/21/07 01:27 AM |
Posts: 461 Victoria, Oztralia | Hi Matt
I had a crack appear in my build about 100mm long, I closed the hull immediatley and repaired it. Firstly the crack was open a little, so I brushed a little epoxy into it and got the hair dryer and warmed it a bit so it would thin and soak into the crack, then put a 25mm wide piece of f/glass the length of the crack and flattened the join as best I could to its original shape (flat ply) and tried again a few days later.
Are you steaming the ply? I'm not sure, but when I build again, as I got to about half way with the bending, I would again hit it with the boiling water and towels to help it along a bit more.
Regards
Matt Harper
Homebuilt Taipan 4.9
[Re: Matt_Stone]
#124327 11/21/07 04:51 AM 11/21/07 04:51 AM |
To steam them, try and get a 44gal drum, even half a one. Stick your burners under it and boil up some water, when its boiling throw in some towels or blankets and boil them up again, then lay them on your hulls, you can pour some more boiling water on them as well.
I'm not sure what you mean by tent, if your thinking of steaming up the tent, like steaming up the bathroom, I don't think that would be good enough, you might need the more direct approach.
I used a old copper that I found out at the farm, designed to boil water with open fire underneath, worked well.
When setting your hull sides up for glassing the keel line, make sure the glass tape is accurately placed both inside and outside, this I think is very important. My thinking is if the inside keel tape is out further than the outside one, it would almost surely lead to breakage.
Regards
Matt Harper
437
guests, and 34
