| Re: TACKING IN 15 KNOTS PLUS
[Re: SIAM]
#125205 12/02/07 09:21 AM 12/02/07 09:21 AM |
Posts: 160 North Carolina | I'm a novice sailor myself and had difficulties tacking in high winds also. Are you letting the main out as you turn into the wind. In light wind it's not that big of a deal but in heavy wind if you don't let the main out the sail tends to "weather vane" the boat into the wind putting you in irons. When I tack in heavy winds, right when I feel the main start to luff I let it out, go easy on the tiller, and of course let the jib backwind. But I haven't mastered this either, I still seem to go into irons at least once in heavy winds and of course it's usually at the worst possible time, like when I'm near a dock or another boat.
James 1983 Hobie 16'
[Re: SIAM]
#125207 12/02/07 10:33 AM 12/02/07 10:33 AM |
Posts: 160 North Carolina | I don't know, tacking in heavy air is kind of an art form I guess. Like I said, I don't do it successfully all of the time and it does seem harder in ocean chop/swells. I would ask the same question over on the Hobie forums, you'll probably get a lot more responses over there from people with a lot more experience than I have.
[Re: mmadge]
#125209 12/02/07 05:24 PM 12/02/07 05:24 PM | Anonymous
| Anonymous
Unregistered | The trick I use to use back when I was VERY good at racing a 16 in the late 70's - early 80's was:
Have to crew go down and get on knees by mast , release the jib sheet from cleat and hand hold it. When he/she tells me he/she is ready THEN I will start the tack. As said crack the main a little as you go head to wind and let the jib back wind you thru the tack. With the jib hand held, you can release it easy and pull in lazy sheet fast. I learned this AFTER going over backwards few times, do to not being to uncleat the jib fast enough. IF you do go into irons, push and boom and tiller away from you and the boat should back into the tack. Just have patience, it will come around.
Hope this helps,
Doug
[Re: SIAM]
#125210 12/03/07 09:37 AM 12/03/07 09:37 AM |
Posts: 164 fort Myers, FL | One other thing: once turned onto the new tack, make sure you sheet in the jib before the main. If you set the main too quickly, it will turn you back into the wind and into irons (see Rick's book).
Arie Hobie 16 111812
[Re: arievd]
#125211 12/03/07 11:18 AM 12/03/07 11:18 AM |
Posts: 3,348 | Arie and his family are our newest members, so welcome to GYC. AND , after an 18 year lay-off, he and his wife finished in the middle of the pack. Well done! We now have 4 (or 5) H-16s, 2 14s, 2 18s and a 21. Sadly, only a couple are active. We hope to re-establish an active Hobie fleet in the new year. Racers or recreational sailors, all are welcome. So, bring the kids, the wife and your dog. If I remember correctly, Ari has a wife, 11 y.o. son and Chocolate Lab. http://www.gulfportyachtclub.com/
[Re: fin.]
#125212 12/03/07 09:48 PM 12/03/07 09:48 PM |
Posts: 4,119 Northfield Mn | Pete- you aren't going to be trading in the BLADE are you? ![[Linked Image]](http://www.cumminsforum.com/forum/images/smilies/thud.gif)
[Re: SIAM]
#125215 12/07/07 02:09 PM 12/07/07 02:09 PM |
Joined: Jul 2004 Posts: 125 Clinton, Mississippi rattlenhum
Posts: 125 Clinton, Mississippi | 15 knots plus is a lot of wind. It helps to begin with a lot of boatspeed to make it through that kind of wind and associated waves, especially with full crew weight. Also, it helps to act more aggressively and quicker in order to minimize the time you're exposed to the forces trying to stop you (as opposed to finessing though the turn in lighter air). To maximize speed, initiate the turn from out on the wire (takes some practice). My sequence (as skipper) is begin turn, come in, keep turning, cut mainsheet (so as not to weathervane), keep turning, unhook, keep turning, make sure we've come across enough to complete the tack and that the jib is in on the new side, keep turning, then cross under boom and sheet main. For me, the worst part is if I can't unhook cleanly.....then I'm stuck to the trap wire, I'm on the leeward side of the boat, and I've got the boom coming at my face.
Lots of other good advice above, too, except I disagree with backwinding the jib. As mmadge says, fly the jib through the tack. (BTW...Rick White says the same...buy his books/videos on this site, and learn to do it right!) Backwinding is great....for going backwards. It may eventually push the bows over but only after it's killed what little momentum you had left after dragging two hulls through different arcs and pointing straight into the wind/waves for a couple of seconds.
If you stall, immediately reverse the rudders, and you'll back into the tack you were attempting to take. (In 15 knots, you won't even have to backwind the jib!)
Jerome Vaughan Hobie 16 Clinton, Mi'sippi | | |
2,437
guests, and 213
