How many knots before twin trapeze needed? #125217
12/02/07 08:58 AM
12/02/07 08:58 AM
SIAM Offline OP
SIAM  Offline OP
Hi we have a stock H16 and sail with around 150kg / 330 lb of crew weight.... what wind speed would you normally expect to be both on trapeze?
Re: How many knots before twin trapeze needed? [Re: SIAM] #125218
12/02/07 02:12 PM
12/02/07 02:12 PM
Thunder Bay ON CAN
M
mmadge Offline
mmadge  Offline
M
Thunder Bay ON CAN
I would say with your crew weight,you are looking at 15knts of wind before being double trapped.Sailing at min.(285lbs) weight you are twin wired at around 12knts.I will be able to tell you better this summer as I bought myself a wind meter.
Re: How many knots before twin trapeze needed? [Re: mmadge] #125219
12/03/07 06:59 PM
12/03/07 06:59 PM
Cincinnati, Ohio
Tri_X_Troll Offline
Tri_X_Troll  Offline
Cincinnati, Ohio
This is good info.
Now, suppose the crew weight combined was more like 150lbs for myself and 120lbs for my girlfriend.
Would I be able to avoid double trapping if I were to sheet out?
The reason that I ask, is that my girlfriend is deathly affraid of sailing and I don't think I will ever be able to convince her to get out on the wire.
I honestly don't forsee myself sailing on more than 10-12 knot winds.
Re: How many knots before twin trapeze needed? [Re: Tri_X_Troll] #125220
12/03/07 07:35 PM
12/03/07 07:35 PM
Sheet the main in, you want good flow of the telltales, but just travel out till the boat settles down. Try as much downhaul as you can first. Good luck and that should make the boat a little more stable for her. Last thing you want to do is scare her. She will NEVER get on again then. I had to add barbell weight to the boat by the mast before to make class weight. Once you learn the boat a little more it should settle down ad be easier.
Doug
Re: How many knots before twin trapeze needed? [Re: ] #125221
12/03/07 09:46 PM
12/03/07 09:46 PM
My girlfriend wasn't a big fan of being on the wire untill she got used to it. Same with a few of my friends. They all discovered the same thing, and that its generally more comfortable than sitting on the side rail.
Re: How many knots before twin trapeze needed? [Re: Tri_X_Troll] #125222
01/08/08 08:44 PM
01/08/08 08:44 PM
offshore
peter_nelson Offline
offshore
Ryan --
I can't tell you how many girlfriends I have seen converted. Get her out on the wire once, and you'll never be able to get her back in!!
Of course, you will want to do it on a day that is not real puffy. And you will want to make sure you have your game face on to make sure you don't dump the poor gal. All the while, of course, you want to make sure you are smiling BIG like this is the most fun you have ever had on a Hobie -- which it might likely be!!
Just make a deal she can't refuse -- hot tub afterwards, candlelight dinner, that soapy movie she has been dying to see, and oh yeah, don't forget the brand new Lexus!
Time Warp Racing
Hobie 14, 16, & 17, Jeanneau Sun Odyssey 45.2
Re: How many knots before twin trapeze needed? [Re: peter_nelson] #125223
01/08/08 10:32 PM
01/08/08 10:32 PM
Coopersburg, PA
V
Vinny_M Offline
Vinny_M  Offline
V
Coopersburg, PA
That exact technique worked for me!!! well, with the exception of the Lexus
~vinny~
Re: How many knots before twin trapeze needed? [Re: Vinny_M] #125224
01/09/08 01:52 PM
01/09/08 01:52 PM
California
mmiller Offline
mmiller  Offline
California
A - Have new crew get used to the trapeze on dry land. Let them practice getting in and out. Show them proper footing and bracing. Front leg stiffer / straight, aft leg bent and the "shock absorber". Get them out there and push them a little from behind to get them used to the boat in motion and how to brace for deceleration. Spend some time, it pays off on the water.
B - You can always use the traveler to prevent the hull from flying when sailing with less weight on the wire. Travel out and sheet normally.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: How many knots before twin trapeze needed? [Re: mmiller] #125225
09/14/08 04:39 AM
09/14/08 04:39 AM
Jusa Offline
Jusa  Offline
Me and my friend have been learning using trapezes this summer and this have been very usefull information.
But how much wind you can take when sailing alone (80 kg / 176 lb) before you need trapeze?
Re: How many knots before twin trapeze needed? [Re: Jusa] #125226
09/15/08 11:46 AM
09/15/08 11:46 AM
California
mmiller Offline
mmiller  Offline
California
10 - 12 knots I suppose. You can use the main traveler (out) to keep the boat down too.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
0 registered members (), 22,008 guests, and 747 spiders.
Most Online23,915
1 hour ago
