Page 1 of 5 1 2 3 4 5
If you were to build an f16... #125258
12/02/07 10:06 PM
12/02/07 10:06 PM
Robi Offline OP
Robi  Offline OP
...Sourcing out your own parts, how and what would you get and why? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
I hope this gets good <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: If you were to build an f16... [Re: Robi] #125259
12/02/07 11:13 PM
12/02/07 11:13 PM
Rum. These things take lots of thought.
Re: If you were to build an f16... [Re: fin.] #125260
12/02/07 11:57 PM
12/02/07 11:57 PM
Robi:
IF I had the expertise, which O DON'T!!! <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> I would go with the Blade design. Seems to have the best design of the bunch. Right? Don't you like the planning hulls? And the weight. I can't wait to get one and join you guys.
Doug
Re: If you were to build an f16... [Re: Robi] #125261
12/03/07 01:35 AM
12/03/07 01:35 AM
I've got to go with Pete here, a bottle of Rum, and go watch Matt build my boat... <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: If you were to build an f16... [Re: Timbo] #125262
12/03/07 03:11 AM
12/03/07 03:11 AM
I would not source it out: http://woodastic.blogspot.com/ I would also prefer to buy a finished boat if I had the budget <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
But then, if I were to source it out and had a good budget, I would get:
Hulls and foils from formulacatamarans.com. I like these the best and know Marcus. Might have to order a set of T-foils from Darryl as well just to compare, as long as we are dreaming up boats.
Mast, preferably a carbon wingmast. Less weight is always good.
Beams from the dies Wouter and Phill did. I have only heard secondhand rumours and hints about this, but knowing both of them it would be good stuff.
Fittings from Riley, to test them out and see what they are like.
Sails from formulatamatarans.com, becouse Marcus is active in the class and optimizes his shapes for the boat instead of scaling down e.g. Tornado or F-18 spis.
Now, in the real world it is homebuildt hulls, cut down Tornado masts, alu-tubes for beams, homebuildt working sails and tramps and possibly homebuildt foils as well. Cheapest workable fittings (probably Riley, dont want to go too cheap and buy junk). All to save some money both in the short and the long run.
Re: If you were to build an f16... [Re: Timbo] #125263
12/03/07 05:24 AM
12/03/07 05:24 AM
Tim,
I have built a number of boats and drunk a lot of rum.
It's a close call but I think I'd bring my rum along and watch too. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: If you were to build an f16... [Re: phill] #125264
12/03/07 05:46 AM
12/03/07 05:46 AM
Robi Offline OP
Robi  Offline OP
Guys, im not building one myself. I am going to put it all together. I am most probably just purchasing hulls, mast beams and the spin pole. Everything else will probably all put together from different sources. All standing and running rigging, sails, blocks, tramp, tiller extension, rudders, boards, etc is going to be purchased separately.
Re: If you were to build an f16... [Re: Robi] #125265
12/03/07 08:27 AM
12/03/07 08:27 AM
The biggest pita on my boat is raising the main. Buy a halyard that doesn't chew the blocks up, and rig a swiveling block to the mast.
I would not replace the alu parts with carbon. It's overkill.
When are you going to announce the new owner of your old boat. It's your job to welcome him to the club! <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
Re: If you were to build an f16... [Re: Rolf_Nilsen] #125266
12/03/07 08:59 AM
12/03/07 08:59 AM
Basically what the other people said but I would put T-foil rudders on the top of my listing.
Even relatively small foils will take care of the last remaining issue with F16's; going downwind in a big blow.
Hey Rolf, you guys should really consider doing T-foil rudders.
Will make the rudder board design alot simpler as well as you would no longer need a taper at the end. Basically, you can make a 0.95 mtr. long prismatic rudderblade (square side profile) then cut the bottom 30 cm off and screw is to the bottom of the 65 cm long rudderboard made from the other section.. By using two screws and the natural curvature of (the top) of the T-foil you can fine-tune the angle of attack of the T-foil in a range of -4 to +4 degrees. Once the right angle is found you'll just fill up the openings with resin and filler.
It will be a relatively low aspect T-foil (aspect ratio of 2) but at least this one won't stall easily. Added drag is less then 2 kg on the total (when doing 12 knots of speed).
Re: If you were to build an f16... [Re: Wouter] #125267
12/03/07 09:06 AM
12/03/07 09:06 AM
You never put it so concisely before <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />! So that's what it's all about!
Okay, how do I modify the rudders I have? Stock VWM.
Re: If you were to build an f16... [Re: fin.] #125268
12/03/07 09:18 AM
12/03/07 09:18 AM
Wouter, we are discussing building T-foils. Both time and cost is a big part of that discussion, cost of buying a finished solution vs. the time it takes to build something decent. But let's not turn this into yet another T-foil thread. The next global challenge will probably be a T-foil vs. normal rudder showdown as people will have had time to experiment a bit more by then.
Re: If you were to build an f16... [Re: fin.] #125269
12/03/07 09:22 AM
12/03/07 09:22 AM
Well, I'm really seriously considering putting T-foil rudders on my F12 design (actually I have already decided doing that). As I have insufficient funds to buy T-foils I'm considering building my own over this winter. Sanding and glassing a rudderboard over is something I can do at my small appartment (highrise building).
I seem to remember having a 19 mm piece of ply wood laying around. With planing and sanding I should be able to get it to mirror a NACA010 or NACA012 profile. Then glass or carbon over the outside and cut the bottom off to become the T-foil. Sail with it for a while on my F16 and when satisfied with the potential make a proper one or buy a commercially made one.
I have to do this as I have AHPC rudders and they have a Shark Fin ending. Basically I have to saw off the bottom 3 inches to even get a surface area large and wide enough to take the T-foil and screws. I think my rudders are at the bare minimum of length anyway, they do stall on me now and then. So that doesn't seem like an attractive route.
I think your VWM rudder blades are alot better in this respect. You have a tapered ending right, with a square tip ? Matt, told me he that he makes the Blade F16 rudders longer then AHPC (a good decision in my opinion). I guess you could just take the bottom egde off to get a flat surface area and prepare the foam to take the screws and the loadings. Probably take a bit of foam out and fill it up again with resin and filler. Ask Matt what you should do here or have him do it for you. Maybe Matt is interested in doing it as an experiment where you cover part of the costs I don't know.
The T-foil can be fitted to this prepared rudder tip. How you make the T-foil is varied, whatever suits you best.
Re: If you were to build an f16... [Re: Wouter] #125270
12/03/07 04:13 PM
12/03/07 04:13 PM
Never had a problem downhill on my Stealth!
Better than my Inter 17 and comparable with my Hurricane 5.9!
Re: If you were to build an f16... [Re: scooby_simon] #125271
12/03/07 10:58 PM
12/03/07 10:58 PM
Adelaide South Australia
ratherbsailing Offline
I wanted to put Darryl's T foils on my Taipan but when we measured the stocks they are around 50-70mm to big and would mean building a new stock mold just to fit the Taipan.would be justified if there were more takers than just me.
Re: If you were to build an f16... [Re: ratherbsailing] #125272
12/04/07 01:39 AM
12/04/07 01:39 AM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
What about the loads on the stern? Does the Blade stern support that?
Gill
Falcon F16 - BEL666
Boats: TheBoatShop.be
Re: If you were to build an f16... [Re: Wouter] #125273
12/04/07 02:50 AM
12/04/07 02:50 AM
Marcus F16 Offline
Marcus F16  Offline
It seems to me that you are one of the only ones that has an issue with the F16's not having T-foils.
After sailing the Aus Blade at Zandvoort - i was very content with out them. The only serious nosedive i had was when my stupidity took over.
The only time I would consider a t-foil would be for stabilisation of upwind sailing in choppy water.
Maybe you should organise a test sail of Aus-401 before wasting your time on the t-foils.
Marcus
Marcus Towell
Re: If you were to build an f16... [Re: Marcus F16] #125274
12/04/07 06:13 AM
12/04/07 06:13 AM
Robi Offline OP
Robi  Offline OP
Marcus
Marcus, interesting that you say "wasting your time on the t-foils" Why do you consider it a waste of time?
Re: If you were to build an f16... [Re: Marcus F16] #125275
12/04/07 08:12 AM
12/04/07 08:12 AM
Well, we are not sailing the same boat are we ?
I can either justify 13.500 Euro for the Aussie Blade or less then 500 Euro's for a T-foil upgrade. Same applies to a score of other F16 owners. Of course I understand that you prefer them to all upgrade to an Aussie Blade, but that may be a bit unrealistic at this time.
I think 500 bucks is a reasonable sum to pay for giving my current F16 a new lease on life.
As such I don't really think T-foils are a waste of time irrespectibally or a test ride on the Blade 401. Actually I also believe T-foils are an excellent why to further equalize alu masts with the carbon variety (much reduced pitching in either setup). In the long run this may proof very useful in the F16 future as alu masts are indeed a [censored] load cheaper. Besides the T-foils are someting that can easily be explained to interested parties new to the F16's. You don't need many words at all to convince them that the last remaining benefit of the carbon masts is the ability to alter it stiffness along its length. Same with regard to short hull length and the assumed pitchpole happyness.
No, I actually feel many are underestimating the potential of the T-foil rudder setup. It has considerable advantages in many respects.
I wonder, have you had a test sail with the T-foil rudders yet ? If not then, maybe you should try it.
Re: If you were to build an f16... [Re: Gilo] #125276
12/04/07 08:26 AM
12/04/07 08:26 AM
Gilo,
The way I look at it is this.
When you jank your tillers over by say 20 degrees when sailing at 10 knots then the sideways load on the rudder blades is easily in the order of 100 kg. The loads on the pintles will be heigher still as they will have to resist the resulting moment on the rudder while having a relative small leverage.
The T-foil winglets are only 1/3rd the area of the rudderblades and so the forces they generate will be about 1/3rd as well. I don't see how the sterns will fail under those loads when they won't under the much higher loads generated with abrupt steering.
The only situation where you increase the loads is when you steer very abruptly during a full on pitchpole as then both loadings will be on the stern simultaniously. But they will also be perpendicular to eachother making the resulting force only 104.4% higher then the load without T-foils. (remember the law of Pythagoras)
I really don't see this as any cause for worry.
But if anybody thinks it is then the sterns can be reinforced from the inside, relatively easily I imagine even. Just glue a extra plate to the stern and two "angles" securing the stern more forcefully to the keel line and deck. I think this can be done with 5 mm ply after being saturated with resin. There are enough solutions and I don't see any of them as particulary difficult to perform.
Darryl has been experimenting with them in AUS where he simply used to old kick-up system of his old rudders. He report that the kick-up mechanism work just as it would with conventional rudders and he has had no damage yet. Getting back to to beach even in heavy surf should not be a problem with these kick-up T-foils. Basically I sailing my boat in with rudders down but lock down arms disconnected in these conditions anyway. As soon as I reach depths of less the 60 cm the rudders kick-up against the friction of the rudder stocks. By that time the breakers are behind you as no large wave can come as 60 cm shallow water without breaking. Been doing this for 3 years as well, no problems here. Sure the T-foils will add drag when kicked-up but when I sail in 60 cm deep water I want to slow down before hitting the beach anyway.
The only remaining "issue" is getting out through a big surf, although as soon as you reach water deeper then 60 cm you can just rotate them them down fully and have the stock friction keep them in place. I sail out through big surf in the same way with my conventional rudders and it is the best approach anyway. Again the big breakers are encountered over deeper water then 60 cm.
So I feel that a kick-up mechanism as we have now can easily be used for T-foils rudders, There is not really a need to have them slide up and down. Sliding up and down may well be an advantage on its own but it is not needed. That is also what Darryl told me about his experience with kick-up T-foils
I've also an idea to have the T-foil rudderboards use all the same hardware as we are using now, this includes the locking down the rudderstock in the vertical direction and I'm not refering to the litte clip. I discovered that simple solution by accident when trying to dismount my my AHPC rudders. At one time I tried to take my rudders off when the rudderboards were in their down positions, but I couldn't. See the attached picture of why that was (and I don't have that black retaining clip fitted ! ) :
The part of the rudderboard that is in front of the pintle axis, in order to balance the rudders, achieves a full lock of the stock/rudder on the lower rudderpintle, preventing it from slide up or down. With my rudders there is hardly any spacing between the rudder and pintle at all and the stock was held into place very firmly. I don't have even the retaining little clips on my sterns and I've been sailing like this succesfully for 3 years now. I only have small split rings through the little hole at the top of the pintles to keep my rudders attached to the sterns when going in and out through the surf with the rudders trailing behind the boat. That is all that is needed. Others can continue using the little clips for this purpose.
We can make use of the same principle to have fully locked T-foil rudders using all the hardware that our current rudders use, we only need to add little foils to their tips or have new rudders with T-foils made.
My presonal problem with using my current AHPC rudders is that they are not easily modified to take T-foils because of their shark fin tips. I have to cut off too much board to get a large enough area to fit the T-foils too. So I will have to get new boards. I think your rudders with their tapered by square head tips are alot more easily modified.
It is a wild idea but do you want to give this a try ?
I will ask Frank and Martien the same thing, maybe we can work together and get one demo set made by Hans that we can all use for a while, gether some experience with it, before we all spend some money on it. With the 4 of use the costs could be low enough to just give it a shot.
I don't know, this may well be the trick that gets stuff rolling.
Re: If you were to build an f16... [Re: Wouter] #125277
12/04/07 03:13 PM
12/04/07 03:13 PM
I think it is interesting that you think T foils will help solve your nose diving problems. Don't you think you could get just as much benefit from redesigning you spinnaker? from my experience getting a spinnaker that creates more lift works very well and it's what i have done on my Taipan I also did this on my F18.Most kites are just cut down Tornado or F18 designs so you need to tell you sail maker what you want not just get what they say is everyone else has got.
Danny
0 registered members (), 1,113 guests, and 36 spiders.
