| Re: wings - pros and cons?
[Re: gvansickle]
#12553 11/04/02 09:24 PM 11/04/02 09:24 PM |
Posts: 273 Key Largo, FL | Wings are great for recreational sailing, cruising, family boat, etc.
But I just have to say something about wings vis-a-vis racing. Most of the popular beachcats require getting crew weight forward for best performance in the kinds of relatively light-air conditons experienced in most parts of the country. Wings add weight aft of the mast, which is only beneficial in heavy air and make it pretty impossible to get enough crew weight forward to keep the sterns from dragging in most light or moderate wind conditions.
In addition, the way in which the wings are attached to the boat make it very difficult for the crew to get forward on the bow of the boat -- knee-knocker, shin-cracker -- to counteract the weight. And when the crew is required to keep moving forward and aft on the boat to keep the boat balanced properly, you can forget it if there are wings attached.
For our seminars, if someone is coming with a two-person boat that has wings, we usually recommend that they take them off for the seminar, because otherwise they are not going to be able to learn the basics of proper weight distribution. And leaving them on would be cruel and unusual punishment for the crew.
Mary A. Wells
[Re: MauganN20]
#12555 11/05/02 06:34 AM 11/05/02 06:34 AM |
Posts: 273 Key Largo, FL | You can trap out as far forward as your trapeze wire will allow you to go. But you need something to hold onto to keep you from flying backward.
Mary A. Wells
[Re: MauganN20]
#12556 11/05/02 07:57 AM 11/05/02 07:57 AM |
Posts: 12,310 South Carolina | My crew frequently traps forward of the front crossbeam on my 6.0na because it has soooo much volume in the bows. Rarely do (did) they trap so far forward on my 5.2 but they sometimes stradled the front beam.
Jake Kohl | | | Re: wings - pros and cons?
[Re: jonr]
#12557 11/05/02 09:30 AM 11/05/02 09:30 AM |
Posts: 215 Ohio | Jon, your line over the wing will not make a difference in the righting of the boat until the upper wing clears the vertical plane of the upper hull... mast about 45 degrees to water or until the righting line doesn't touch the hull. Probably could use a diagram... here is one that is close to the same reason... http://home.columbus.rr.com/teamteets/catright.htmlThe text at the bottom describes the line placement.
Mike, Ohio Former H16, H18, N20, N17, M4.3
[Re: h17windbtch6333]
#12560 11/05/02 03:09 PM 11/05/02 03:09 PM |
Posts: 12 Sacramento, CA | As a recreational sailor, I have to agree with others that have shown a preference for wings. (I sail a H18M, with the shorter wings.) My wife and 7 year old love them. The wings really came in handy while crossing Tahoe last year when the wind kicked in hard and there was 3 foot chop. As a racer, my experience has been thus: 1- In really really light air, thank goodness I've had them - great paddling platforms, 2- in moderate air the wings are 40 lbs extra and don't add to performance, 3- in really good winds (20+), the extra leverage really allows you to push the boat hard by keeping it flat and ultimately results in less depowering while heading upwind, and more rear leverage when flying downwind. In the end, check the conditions you sail in and contrast that with the type of sailing you do. Hell, you can always take those loungers off in 15 minutes. Best Regards- | | | Re: wings - pros and cons?
[Re: MaryAWells]
#12562 11/06/02 10:28 AM 11/06/02 10:28 AM |
Posts: 23 Florida Suncoast | Mary, I must disagree with your generalization regarding wings and racing. Yes, in light air, they are a disadvantage, but in stronger wind...12 and above...they have proved to help in two ways on our Mystere 6.0: first, my crew can trap on the wing and add much more leverage and second, going up-wind, he uses the wing support for additional leverage up front. Maybe its the hobie wings you were referring to or maybe its my limited experience as opposed to the experts in Key Largo, but we use 'em and love 'em. John
John Maples
Nacra 5.0 #2677
Catalina 25 #1789
[Re: boiler70]
#12564 11/06/02 11:29 AM 11/06/02 11:29 AM |
Posts: 273 Key Largo, FL | Boiler70, it sounds like you are agreeing with me rather than disagreeing, because my post referred specifically to the light and shifty wind conditions which are experienced in most parts of the country in the summer. And I am certainly not an expert -- I'm just giving my personal opinion as a crew who has had some very bruising experiences with the wings on Hobies. And it is not the wings themselves that are the problem -- it is those things that attach them to the boat. I am sure the real problem is that I am just not young and agile enough.
Mary A. Wells
2,423
guests, and 262
