| Re: If you were to build an f16...
[Re: fin.]
#125320 12/06/07 11:09 AM 12/06/07 11:09 AM |
Posts: 6,049 Sebring, Florida. | Pete, I think the problem is the soft white plastic on that little block at the bottom of the mast. If it were the harder black plastic of a Harken block, probably wouldn't get so chewed up. I think I'll replace mine with a Harken bullet on the beam, ala Terry's set up.
Blade F16 #777
[Re: Timbo]
#125321 12/06/07 11:46 AM 12/06/07 11:46 AM |
Posts: 3,348 | I'll probably do the same. The halyard I have is rough on my hands, <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> which is another reason to replace it.
[Re: Rolf_Nilsen]
#125323 12/06/07 07:26 PM 12/06/07 07:26 PM |
Joined: Jul 2004 Posts: 2,718 St Petersburg FL Robi OP
Posts: 2,718 St Petersburg FL | Why do you use the bottom sheave anyway? I prefer to pull the sail up standing by the mast, pulling the halyard from the cutout the sail feeds into. Same for taking the sail down again. I did this since like maybe the first sail outing. It is much better and smoother. Anyway as far as carbon mast goes, the cost skyrockets compared to the aluminum superwing. I have lots of room to improve the tiller handling to justify a carbon mast. I mean the difference between aluminum and carbon is exponential and very unattractive. <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> | | | Re: If you were to build an f16...
[Re: Darryl_Barrett]
#125325 12/06/07 08:39 PM 12/06/07 08:39 PM |
Posts: 2,921 Michigan | first it was the foil rudders and now the thread is about masts... although masts certainly have more performance impact than foils IMHMFO. I need to see specific numbers regarding price for a carbon mast for an F16 before anyone talks about how easy it would be to get one! It ain't gonna be cheap and my guess would be at least 2500 to 3k at a minumum. Maybe it is less for a stealth mast if you make pounds rather than $. If carbon were the same price as Al then we would all have carbon masts... if anyone wants to say otherwise bring it on <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
I think the real benefit of carbon (aside from the obvious weight savings) is that it is stiffer which can give you more power. Go ahead... argue with me because I am speaking out of my a--! But my limited experience with carbon tells me that. My aluminum F16 mast is not very stiff. as for the bottom sheave- I used a small piece of spectra to tie a small block to the bottom sheave which makes it much easier to raise the sail. Pulling it out through the cutout in the track would create problems with pulling the luff rope out I would think
[Re: taipanfc]
#125329 12/06/07 11:01 PM 12/06/07 11:01 PM | Anonymous
| Anonymous
Unregistered | I'm more curious about the rumor that a US Viper actually exists. Anyone laid eyes on such a thing? | | | Re: If you were to build an f16...
[Re: fin.]
#125334 12/07/07 01:04 AM 12/07/07 01:04 AM |
Posts: 1,479 Thailand | Let's try a different tack. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
What would you keep? I'm happy with everything except the halyard. It's really abrasive and chews up blocks in a hurry. halyard? We don't need no stinking halyard! <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
[Re: Robi]
#125335 12/07/07 05:11 AM 12/07/07 05:11 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | What ever hulls you have I would stick to the standard beams dolphin stricker, centre boards and bare trampoline this should save on costs and also be proven to work. I'll leave rudders up to your personal taste in kick up mechanisms. Given the choice of spi poles and snuffers and the fact you're not likely to import I think you should purchase the VWM snuffer and pole, again its been tried tested and proven to work well. I can't see that you have a great selection of Masts to choose from if your selection criteria doesn't include custom made Carbon, the only one which springs to my mind is the AHPC superwing and again VWM could procure this. So this now leaves sails and hardware and due to the dollar exchange rates you will probably be buying sails from a US supplier who has a good knowledge of the market and can produce sails to your personal requirements. Glasser would appear to fit this criteria well. As for hardware my personal preference would be Harken throughout especially on the high load parts. I'll leave the sizes, makes and strengths of sheets and halyards up to your personal choice. So in summary as you have asked for peoples opinions mine would be to speak to Matt and get practically everything you need from him. Otherwise, you might just be wasting your hard earned cash on bits and bobs which don't compliment each other and ultimately you have wasted your time (sounds a bit harsh). But good luck and enjoy the experience.
MP*MULTIHULLS | | | Re: If you were to build an f16...
[Re: Mark P]
#125337 12/07/07 06:05 AM 12/07/07 06:05 AM |
Posts: 954 Mumbles Y.C Wales U.K | If I had the time and money to undertake such a project living here in the UK, I would either use Stealth or Viper hulls (Stealth have the volume, weigh less but aren't the sexiest the Viper look the business, have the volume up front but could be a little heavy). Definitely Stealth beams (probably carbon) The complete Stealth 'T' rudders, stocks and tiller arms and extension (all carbon) Stealth spi pole (carbon two piece) Stealth snuffer (mylar) Saarberg wing mast (carbon) Landenberg sails and Harken hardware throughout. I wouldn't choose the Blade hulls as I think that there isn't enough volume in the bows and their rear beams appear to be a bit low, but again they do look beautiful. MP*MULTIHULLS | | |
1,182
guests, and 41
