| Tiller stick alternative ? #127116 12/28/07 08:30 AM 12/28/07 08:30 AM |
Joined: Oct 2007 Posts: 199 Constanta, Romania isvflorin OP
Posts: 199 Constanta, Romania | Anyone tried to use a carbon fiber fishing rod as a tiller stick ? Can it do the job ? Carbon fishing rods are less expensive then the carbon tiller stick. But they are just carbon tubes right ?
Florin
| | | Re: Tiller stick alternative ?
[Re: Rolf_Nilsen]
#127118 12/28/07 04:50 PM 12/28/07 04:50 PM |
Posts: 199 Constanta, Romania | Rolf, I've got an old fishing rod that is really strong, I think I'll give it a try next spring. If it breaks well...but if not I'll have a carbon stick for free. Any ideea how thick a regular carbon stick is ? I like the the fishing rod ideea beacause it has a nice grip handle at the end. I assume you will be using Alu tubing for your Blade, or get a stick from a used cat.
Have a Happy New Year everyone !
Florin
[Re: Rolf_Nilsen]
#127120 12/28/07 05:34 PM 12/28/07 05:34 PM |
Posts: 199 Constanta, Romania | Well, the rod I wanted to test is 28mm in diam. and about 1,5mm thick. It's the first part of a big telescopic fishing rod. It feels quite stiff. The first part of the rod was designed to bend very little and the top sections very flexible. It's a long way till spring but I'll give a shot then. Maybe it's just a stupid ideea and it will brake, but the thing is sitting in the garage and I don't see no use for it anymore.
Florin
[Re: isvflorin]
#127122 12/29/07 05:37 AM 12/29/07 05:37 AM |
Posts: 1,449 | I have know people using carbon fibre fishing rods for tillers at least 20yrs back. Just put a small ball or something on the thin end so it does not take someones eye out. They work great.
Regards, Phill
[Re: phill]
#127123 12/29/07 06:54 AM 12/29/07 06:54 AM |
Posts: 199 Constanta, Romania | Thanks for the answer Phill. I was hoping someone allready tried it and shared the experience. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Florin
[Re: isvflorin]
#127124 12/30/07 12:25 AM 12/30/07 12:25 AM |
Posts: 190 | On my 18Sq Meter (12 foot beam and a 6' 5" skipper) I used to use a 5/8" X 10' (.065 wall) aluminum tube, attached to a Ronstan RF3133 type Universal Joint. I started out with a 12' piece of tubing and cut it down to the right length after a few days of testing. I am now using the same setup on my Laser and use bike handlebar grip tape for the handle.
lesburn1.blogspot.com
A-Cat USA 49 18Sq 49
[Re: Qb2]
#127127 01/03/08 02:32 AM 01/03/08 02:32 AM |
Posts: 1,449 | Qb2, I've used electrical conduit and for me it is a little too flexable. But then each to his own.
Regards, Phill
[Re: phill]
#127128 01/03/08 03:41 AM 01/03/08 03:41 AM |
Posts: 461 Victoria, Oztralia | I used to use half aluminium and half conduit, stiffer than all conduit, but would flex over the side without damage if you capsized or fell off.
Matt Harper
Homebuilt Taipan 4.9
[Re: mattaipan]
#127129 01/03/08 05:34 AM 01/03/08 05:34 AM |
Posts: 1,449 | Matt, I've tried that too. Probably the best of both worlds if you don't have a carbon fishing rod handy.
Regards, Phill
[Re: Mal]
#127132 01/06/08 12:23 AM 01/06/08 12:23 AM |
Posts: 902 Norman,OK | When I first bought my hobie 14, I used a wooden dowl about 5 feet long and about 5 inchs around. I carves some grip into it. To attach it I screwed in an eyebolt and just put a pin through that when the tiller normally attaches.
It worked well until I needed to trapeze!
2,883
guests, and 311
