| Re: What techniques to use to repair Marstrom nome
[Re: scooby_simon]
#128147 01/08/08 04:03 PM 01/08/08 04:03 PM |
Posts: 190 | I think that the " the cells were 6-12mm in diameter from the photo" is a little off. I think that the normal cell size is between 3-5 mm. For a quick how to go to. http://www.fibreglast.com/contentpages-Fibreglass+Repair+Composite+Repair-123.htmlIn the past I have routed out the bad core section and then vac. bag in a new core, then bag on the skin. If the inner skin is fractured this must be repaired first!
lesburn1.blogspot.com
A-Cat USA 49 18Sq 49
[Re: SteveBlevins]
#128149 01/08/08 05:32 PM 01/08/08 05:32 PM |
Posts: 1,200 Vancouver, BC | I would not use any type of core that is not specified for laminate worj with polyester or epoxy resins. Otherwise, you might find blistering, de-laminations down the road. Carl, I was thinking of using the extruded polystyrene (usually pink or blue) that we use in construction to insulate below grade (buried against cement structure) very high resistance to water absorption, 25 psi (available 40psi). This is not as good as corecell or baltek for small boat building but for a small repair it seems very good.
I sent you a pm recently about old Lindahl hulls. Disregard. I have taken another route. Steve
[Re: SteveBlevins]
#128150 01/08/08 06:46 PM 01/08/08 06:46 PM |
Joined: Oct 2007 Posts: 199 Constanta, Romania isvflorin
Posts: 199 Constanta, Romania | Epoxy, or polyester melts in a small degree the usual styrene type foams. Especially polyester resin. Epoxy only a very small degree. I think PU foam resists epoxy or polyester. Not 100% sure, but you might want to check or test the foam you want to use first to see how it reacts to the resin. But polyester melts styrene based foams for sure.
If you want a good patch up job you should use specific foams for boatbuilding.
Florin
[Re: isvflorin]
#128151 01/08/08 07:32 PM 01/08/08 07:32 PM |
Posts: 1,200 Vancouver, BC | That's true about the solvation of styrene. My concern was based on the "friablity" of the core bonding surface...certain types break down over time and any adhesion to the glass layer will be lost. Epoxy, or polyester melts in a small degree the usual styrene type foams. Especially polyester resin. Epoxy only a very small degree. I think PU foam resists epoxy or polyester. Not 100% sure, but you might want to check or test the foam you want to use first to see how it reacts to the resin. But polyester melts styrene based foams for sure.
319
guests, and 44
