| Re: weight breakdown of cats
[Re: ceitzi]
#128614 01/31/08 03:32 AM 01/31/08 03:32 AM |
Posts: 285 | According to the class rules (see www.tornado.org) the minimum weight of a ready to sail Tornado is 155 Kg. New Marstrom Tornados carry 2-3 kg of lead to make the minimum. So if you own a recent boat your estimates are very likely correct. However a couple of figures are "strange": 1) you state that the stbd centerboard is Kg 4,80 and the port centerboard is Kg 3,40. Is there any particular reason to explain the difference? I cannot believe that Marstrom builds foils so differently. 2) you state that the boom weights 1,70 Kg. Does this figure refer to the bare section? Even in such case the section weights only around 0,70 Kg/m. Hence a "wall" thickness of only 0,15 mm. May you confirm? | | | Re: weight breakdown of cats
[Re: David Parker]
#128620 02/04/08 08:25 PM 02/04/08 08:25 PM |
Posts: 902 Norman,OK | They also listed a Hobie 13 and a Hobie 13 turbo
[Re: David Parker]
#128621 02/04/08 09:59 PM 02/04/08 09:59 PM | Anonymous
| Anonymous
Unregistered | i was not sure of how accurate the list was, but i helped Chris load his p16 on his trailer a few weeks ago and the 2 of us lifted it without any problem. | | | Re: weight breakdown of cats
[Re: ]
#128622 02/04/08 10:32 PM 02/04/08 10:32 PM |
Posts: 1,187 38.912, -95.37 | Nacra 6.0...472??? <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" /> damn, and I thought our boat was a hog! Tell me that's not right.
[Re: _flatlander_]
#128623 02/04/08 11:04 PM 02/04/08 11:04 PM |
Posts: 902 Norman,OK | I would bet it is pretty close, but I know my 5.2 is slightly lighter than the 350 listed.
2,924
guests, and 122
