| A beaten subject #128856 01/15/08 06:44 PM 01/15/08 06:44 PM |
Joined: Mar 2006 Posts: 21 College Station, Texas chloemac00 OP
Posts: 21 College Station, Texas | Hey gang..... I am giving my 5.2 a make over, as is my friend in Houston. He is giving his the same. We have been conversing many, many, times and we seem to be both on the same page and have the same issues. His is an '82 and mine is a '77. Okay, I know this subject has been beaten to death. Paint.... I have a few gel coat crazings. Nothing major, just 30 years of the Texas sun. What should I do? Next, should I use the existing paint as my primer? I am changing colors. I don't like the all white. I am giving her a white with a blue tint color. Third....auto paint or marine grade paint. The only difference is the copper content. If she were not a trailer sailor, then I would, hands down, choose the marine grade paint, but since she's going to be out of the water more than in the water, I don't see why I couldn't use auto paint. Someone please point me in the right direction. I also have a crossmember in the front portion of the starboard hull that has come detatched, so a little bit of glass work and she's strong as ever.
My pride and joys and my daughter, Chloe and our Nacra 5.2!!!
| | | Re: A beaten subject
[Re: chloemac00]
#128857 01/15/08 08:06 PM 01/15/08 08:06 PM |
Posts: 263 SC | I know some people have had good success with Emeron (sp?) automotive paint. I would use gelcoat myself, just tint it.
Always borrow money from a pessimist. He won't expect it back.
[Re: chloemac00]
#128858 01/16/08 06:10 AM 01/16/08 06:10 AM |
Posts: 571 Hamburg | Hi chloemac,
I would prefer gelcoat only, because I think that it is easier to make repairs on a gelcoat surface than on a gelcoat (polyester) + paint. But I never repaired a painted boat, so that's maybe my lack of expierence. There are basically two sorts of paint: acryl based polyurethan based (PU) Acryl is what most car builder use, PU is a high quality paint which is used for aircraft for example. Some boatbuilder use it too (good against UV rays, most solvents, chemicals, etc.). But its solvent is highly toxic. If you want to make the paint work by yourself, better chose acryl based paint, which has still good properties.
Cheers,
Klaus | | | Re: A beaten subject
[Re: zander]
#128863 01/16/08 01:53 PM 01/16/08 01:53 PM |
Posts: 291 | Emron is a strong paint but has to be sprayed to get a decent finish and requires a posotive air respriator when doing so (versus a good mask). Emron is also getting hard to find due to it being dated. Most car restorers are using Deltron now, same principle, different chemistry. Check out John Casey's book "This Old Boat". Very good reading for this type of project with valuable easy to read information. For what it is worth, I found the two part polyurethane from Interlux was very easy to work with when brushing.
[Re: JACKFLASH]
#128864 01/17/08 10:17 AM 01/17/08 10:17 AM |
Posts: 778 Houston | I have never heard of EMRON but DuPont Imron is probably the most commonly available 2 part polyurethane http://www.performancecoatings.dupont.com/bowstreet5/webengine/dpc/common/ControllerIt has been reformulated several times over the years and has lost favor with the custom painters who prefer clear coat paint systems. However for tough finishes I have not found anything that beats it. Check local auto paint supply. For best prices call around and consider using a generic reducer. The health concerns about using this product are real. The minimum requirements are free air flow and a proper mask and filter. If you are painting in a booth you need a positive pressure system. You can use Interlux brushing thinner if you plan to brush or roll. You can get a pretty good finish if you roll and tip and then 1200 grit sand and compound. My experience on repainting 20 - 30 year old catamarans is it's probably not worth spending more than 200 - 300 on repainting. These hulls are way past their design life. They may go for years or they may break in half next time out. | | | Re: A beaten subject
[Re: carlbohannon]
#128865 01/17/08 02:45 PM 01/17/08 02:45 PM |
Posts: 291 | Emron / Imron same stuff, wrong spelling. I thought it had been discontinued but if not it is durable stuff. I was told once that it doesn't roll/tip well and that is why I went the interlux for my monoslug project. I did spray my daysailor with Imron a few years ago and it has held up well even with beach landings.
[Re: JACKFLASH]
#128866 01/17/08 05:37 PM 01/17/08 05:37 PM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | Emron / Imron same stuff, wrong spelling. Reminds me of a story... Two guys are sitting in a bar. One is Chinese, the other Jewish. Suddenly the Jewish guy jumps up and slugs the Chinese guy in the face. Picking himself up off the floor, the Chinese guy says, “Why’d you hit me?” The Jewish guy replies, “That was for what your people did at Pearl Harbor.” The other fellow says, “But that was the Japanese, not the Chinese!” “What’s the difference?, answers the first. Another few beers go down in total silence. Then the Chinese guy stands up and hits the Jewish guy with a barstool. “What was that for?” says the Jewish guy, rubbing his head. “That was for what your people did to the Titanic,” says the other fellow. “But the Titanic was sunk by an iceberg!” said the Jewish guy. “Iceberg, Weinberg, Goldberg, what’s the difference?” answers the Chinese guy. | | | Re: A beaten subject
[Re: SurfCityRacing]
#128871 01/18/08 09:48 PM 01/18/08 09:48 PM |
Posts: 887 Crofton, MD | Exactly Jeremy!
Try that with paint.
1 registered members (windman),
470
guests, and 110
