Page 7 of 13 1 2 5 6 7 8 9 12 13
Re: TinCan Tri [Re: TEAMVMG] #129605
02/14/08 12:23 PM
02/14/08 12:23 PM
srm Offline
srm  Offline
Not to worry, the hulls slam a lot less when they're full of water.
Re: TinCan Tri [Re: Tornado] #129606
02/14/08 12:27 PM
02/14/08 12:27 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
At least from the pics in the article it appears that he has reinforced the union of the beams at the central mounting point. Not sure if I would trust it still, but it looks like it will take a little more wear and tear now. He'll get a little further offshore before something bad happens...
Re: TinCan Tri [Re: Keith] #129607
02/14/08 01:38 PM
02/14/08 01:38 PM
not with that hatch like that.
Re: TinCan Tri [Re: Jake] #129608
02/14/08 02:40 PM
02/14/08 02:40 PM
Vancouver, BC
Tornado Offline OP
Tornado  Offline OP
Vancouver, BC
I'm not entirely sure the hatch is a no go. Sure it will leak and maybe even rip off...but he might have filled sections of the main hull with his miracle cure...Homedepot triple expanding foam. So, maybe even completely swamped, she'll not go down.
Latest news is he's still at anchor off SYC. Weather is knarly there today...ideal for a quick shake down. We're not sure why he hasn't set off.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: TinCan Tri [Re: Tornado] #129609
02/14/08 03:14 PM
02/14/08 03:14 PM
yeah, but he'll not still be sailing at that point.
Re: TinCan Tri [Re: Jake] #129610
02/14/08 03:19 PM
02/14/08 03:19 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
The hatch will be an issue for sure, however - if he gets lucky initially and the hatch is on the windward side for awhile its failure will be delayed. He may not sink initially for a hatch failure, but it would be catastrophic.
Ironically, all the foam that he may be counting on to save his butt may be part of the reason the hatch is under water in the first place. All that stuff has done is add weight to the structure without adding any flotation. If not part of the original design (if there really was one) it could account for it floating lower on it lines.
Re: TinCan Tri [Re: Keith] #129611
02/14/08 03:29 PM
02/14/08 03:29 PM
Perhaps there is a "sub" feature he has not revealed. Go, go gadget submarine!
Re: TinCan Tri [Re: ] #129612
02/14/08 04:12 PM
02/14/08 04:12 PM
Lake Murray SC
FasterDamnit Offline
Lake Murray SC
Holy crap! we have all raced/sailed in heavy air and come back busted up, cut up, broken up, nursing a concussion and many other injuries. Now imagine doing a lap around the southern hemisphere in the roaring 40's at THIS helmstation.
E-Scow
24' ULDB
Re: TinCan Tri [Re: ] #129613
02/14/08 04:19 PM
02/14/08 04:19 PM
Vancouver, BC
Tornado Offline OP
Tornado  Offline OP
Vancouver, BC
BREAKING NEWS...He's Hoisting sail:
Mike Dobbs
Re: TinCan Tri [Re: FasterDamnit] #129614
02/14/08 04:22 PM
02/14/08 04:22 PM
rexdenton Offline
rexdenton  Offline
If there is to be a failure, let's hope it is swift. Withstanding any ocean swell for any period of time is the question. Care on a run and broad reach may be required; I suspect the stern may submerge in a following swell of any significant proportion. No nets is a very bad idea. Shake out should be in an ocean swell, which may be a distance off shore. Cuts and bruises to be expected.
Nacra F18 #856
Re: TinCan Tri [Re: Tornado] #129615
02/14/08 04:35 PM
02/14/08 04:35 PM
Vancouver, BC
Tornado Offline OP
Tornado  Offline OP
Vancouver, BC
Now making for the GATE!!!
That's him at the lower left...^
There is awesome coverage over on SA forum...they've even got a guy out on a chase boat trying to get shots for us.
Mike Dobbs
Re: TinCan Tri [Re: rexdenton] #129616
02/14/08 04:35 PM
02/14/08 04:35 PM
Lake Murray SC
Lake Murray SC
E-Scow
24' ULDB
Re: TinCan Tri [Re: FasterDamnit] #129617
02/14/08 04:42 PM
02/14/08 04:42 PM
Vancouver, BC
Tornado Offline OP
Tornado  Offline OP
Vancouver, BC
YeeHa! Pedal to the Metal Baby!
GO 'CAN! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Mike Dobbs
Re: TinCan Tri [Re: Tornado] #129618
02/14/08 04:43 PM
02/14/08 04:43 PM
Lake Murray SC
Lake Murray SC
Two sails full and going under the gate...
Anyone have an audio clip of "the Final Countdown"?
E-Scow
24' ULDB
Re: TinCan Tri [Re: FasterDamnit] #129619
02/14/08 04:52 PM
02/14/08 04:52 PM
I can't watch....
Re: TinCan Tri [Re: Jake] #129620
02/14/08 04:58 PM
02/14/08 04:58 PM
I did - morbid fascination.
Re: TinCan Tri [Re: John Williams] #129621
02/14/08 05:07 PM
02/14/08 05:07 PM
What's it rate?
btw. Is it "aluminum" or "aluminium"?
Re: TinCan Tri [Re: Tony_F18] #129622
02/14/08 05:10 PM
02/14/08 05:10 PM
is there some live cam somewhere >?
Re: TinCan Tri [Re: ] #129623
02/14/08 05:12 PM
02/14/08 05:12 PM
Lake Murray SC
Lake Murray SC
Re: TinCan Tri [Re: FasterDamnit] #129624
02/14/08 05:18 PM
02/14/08 05:18 PM
cool... looks like he is doing well. Can you ask the camera guy to wipe the lense? (kiddin)
0 registered members (), 691 guests, and 883 spiders.
