Tradewinds, the rescue #129813
01/24/08 03:46 PM
01/24/08 03:46 PM
Miami, FL
John McKnight Offline OP
Miami, FL
Tradewinds Regatta
January 19 &20, 2008
Islamorada, Florida
By John McKnight
The 2008 Tradewinds Regatta was held January 19 & 20, in Islamorada in the Florida Keys. It was a very windy affair on Saturday. No one even sailed on Sunday, because the winds were at least 20 to 30. Rick White was the PRO. He has also done a fine job of chronicling the regatta in words and pictures on CatSailor.com. http://catsailor.com/Stories_Temp/TradewindsStory08.html I always help work on the race committee for this regatta and forgo sailing, so all our out of town sailing friends can have a well run regatta. On Saturday there were many occurrences of boats flipping over and crews getting separated from their boats. There were many war stories being told Saturday afternoon. I have a story for you from my perspective on a chase boat.
The Rescue
You have heard the expression of things going from bad to worse. Well, that was what kept happening on the race course at the 2008 Tradewinds Regatta. I was on one of the four chase boats for the day. It was very windy on the race course. The winds were 15 to 20 knots with higher gusts on Saturday. At one of the NOAA lighthouse weather stations, in the vicinity, they were reporting gusts up to 26.
Before the first races on Saturday even started, boats were flipping over. On the first downwind leg of the first race, the boats looked like bowling pins getting knocked down.
"There's one down over there! There's another one over!"
At any one time we would have 4 to 5 boats flipped over. Crews were regularly getting separated from their boats. The worst leg for bow stuffing flips was the B to C broad reaching leg of the first triangle. As the boats got further from the shore, they lost the relative protection of the lea of the land, and the blustery wind was taking its toll. The spinnaker boats, Inter 20s, F-18s, and F-16s, seemed to be suffering the most. The nuclear blasts would hit the fleet, and if you didn't head down deep enough over you went. One of the most difficult spots on the course was right at C mark. Here the boats had to transition from the downwind mode to the upwind mode. If you got hit with big air here, you were in trouble. You can't yet head up fast enough to dump air, and you can't bear off to shadow your spinnaker with the mainsail. Warren Green and I were on the C mark chase boat and many boats were dumping it right in front of us.
We watched a yellow and white Inter 20 go over at the C mark. The crew got separated from the boat. Chip Short, on his motor boat, picked the crew up and returned them to their boat. Warren and I took over monitoring the situation. We watched the crew struggle to right the boat. They got the mast to come up, but it continued over the top and flopped in the water on the opposite hull. The crew again slowly climbed on the slippery hull and pulled on the righting line to right the Inter 20. Again, the boat righted and continued over in another flip. We came along side, and I mentioned to the crew that it looked like the jib was still cleated causing their boat to flip each time they righted it. They assured me that they had uncleated the jib, but that it must have recleated itself. Now the fun began. The battens were coming out of the mainsail. Evidently the punishment on the sail was loosening the battens. So while the crew tried to gather their strength for another attempt at righting, Warren and I started circling around plucking foam battens out of the water. There were four loose battens, but we were only able to snag 3 of them.
We watched in vain as the skipper and crew crawled back onto the hull of the overturned boat. I could see that something was wrong. The crew was standing on the hull ready for the next attempt, but the skipper was still in the water catching his breath.
"This is not looking good," I said to Warren.
The skipper finally got on the hull, and they slowly maneuvered the boat into the power righting position. Finally, they successfully righted the boat. The weary crew dragged themselves up onto the tramp. Warren and I thought we were done with this saga. NOT! We watched the boat sail off on a close reach and after a few hundred yards it flipped again!
"What gives here?" We are thinking.
We motored over to check them out. As we approached the Inter 20, we saw the crew up on the hull and the skipper still in the water. The crew yelled to us that the skipper was injured and exhausted. He needed to come onboard our motor boat. We found out later that the skipper had fallen into the boom on their initial capsize, and he had hurt his ribs. So we tossed the skipper a line and dragged him over to our boat. We had to help pull the skipper into our boat. We put the motors in neutral and had him climb up between the two engines. He used the fins on the motors as steps. Warren and I helped drag him into the boat. He was spent. He also announced that he has lost his insulin pump in this fiasco. I wasn't sure if that would become yet another factor.
You remember me mentioning bad to worse. This is where they continued to get worse. We now had an injured skipper onboard and a capsized Inter 20 with only the crew onboard. I asked the skipper about the experience of the crew. The skipper said that the crew was an experienced sailor, but this was one of his first experiences on a catamaran.
"Oh Boy," I thought.
We now had a boat on its side that could not be righted. About this time we noticed that we were rapidly drifting toward a sand bar. If the I-20 drifted onto the sand bar, we would not be able to get close enough to help. I considered jumping in and helping right the boat and sailing it in. But I decided not to do that. Despite 34 years of catamaran experience, I had never been on an Inter 20. I didn't have all my sailing gear and that move might make things worse. So, instead we tossed the crew a line and decided to tow the crippled boat away from the sandbar. He tied the tow line to the dolphin striker. Unfortunately, the tow line was lying across the spinnaker pole and when we started to pull, the pole snapped in two.
"Can anything else go wrong here?" I am thinking.
The answer of course was, yes!
Initially, we had things under control. At least I thought we had them under control. We were towing the I-20 on its side slowly toward shore. We had about a two mile tow back to the beach. The crew was standing on the hull at the rear cross beam to try and keep the bow out of the waves. We were making progress. When we stopped to reroute the tow line after the spinnaker pole broke, we got into more trouble. We were drifting through an area of lobster traps. Attached to each lobster trap is a line and a round Styrofoam float. The floats are called lobster pots. The pots are painted in unique designs so that each lobsterman can identify his traps. Well, while we were drifting downwind, the I-20 became entangled in one of these lobster pots. The pot wedged between the mast and the shroud at the mast hound. The strong current was jamming the line and pot in the rigging. We thought briefly about cutting the line to the pot, but that is highly frowned upon in the Keys. We had the crew jump back in the water and try to free the pot from the rigging. After much tugging, we got it free. We continued the tow. We were thinking that the towing was going to ruin the mainsail, which was still on the mast. We did not think the crew could get it down by himself, so we continued on. About this time, the Inter 20 decided it was going to right itself. The wind got under the sail and tramp, and it just popped upright by itself. We stopped our tow to allow the crew to climb onto the tramp. He had no more flopped on the tramp when the sails caught air, and the boat started sailing. It was sailing right at the transom of our boat. It gained speed very rapidly and it was coming straight at us.
"We are going to get rammed." I am thinking.
The crew was sitting on the windward hull and his eyes were as big as saucers. Sure enough, the I-20 smashed into the back of our port engine at full force. "Crack," something had broken big time. I thought it was the engine cover. The Inter-20 bounced off the engine, and its windward hull was now flying. About the time it reached the end of the tow line, it flipped over once again. The crew was tossed into the water one more time. Things were not going well at this point. It was beginning to look like an episode of the Keystone Cops. We inspected the motor housing, and it just has a little bit of yellow paint on it. The crew inspected the port hull of the I-20 and found the bow had been split wide open from top to bottom. There was about an inch wide gap all the way down the bow. We now cannot right the boat, because the port hull would fill with water and sink and cause even more problems.
We decide that the mainsail has to come down to prevent another inadvertent righting. So we stopped the tow, and the crew went to work taking the mainsail off the mast. He painstakingly untied the main from the boat. This is a very difficult task for one person while a cat is bouncing around on its side in the choppy sea. The crew was doing a marvelous job. He was very strong and very agile as he scampered and swam about the boat gathering up sails and line. He got the mainsail wrapped up and secured. The spinnaker halyard was still loose, so he cut that away. Finally we were ready to tow again. When Warren put the motors in gear, an alarm went off on the starboard engine. Warren pulled the engines out of gear and I inspected the prop. Sure enough, some loose line had wrapped around the prop. I tried to unwrap the line and cut it away. I couldn't do it from onboard. The crew had to jump in the water and swim over to our boat and unwrap the line from the prop. We then notice that the I-20 had again become entangled in another lobster pot. We had to tow the boat upwind to relieve the pressure on the rigging so the pot would come loose. I think we had four entanglements with lobster pot during the tow. We finally got underway again creeping towards shore.
After 15 minutes more the crew signals that he is getting exhausted. He said he needs to come onboard the motor boat with the rest of us. We stop and he swims over and climbs onboard. We thought we needed him on the back of the I-20 to keep the bow out of the water, but the boat rode just fine without him. We slowly finish the arduous tow back to the beach. This ended the successful rescue of the I-20 crew. Murphy's Law comes to mind when I think back on this ordeal. One thing after another kept going wrong for us. Fortunately, the only injury was the badly bruised ribs.
I won't even begin to tell you about the demasted Taipan F-16 that we also towed in later that day. That is a whole other story. If you want some real excitement, volunteer for a chase boat duty at your next regatta. It is usually very interesting.
John McKnight
Commodore, Catamaran Association of Biscayne Bay (CABB)
(305) 251-7600
CABB Forum: http://www.catsailor.com/forums/postlist.php?Cat=&Board=CABB
Re: Tradewinds, the rescue [Re: John McKnight] #129814
01/24/08 05:52 PM
01/24/08 05:52 PM
Cutler Bay, Florida
Bajan_Bum Offline
Bajan_Bum  Offline
Cutler Bay, Florida
That's some story, John. Remind me not to go out in that much wind.
Re: Tradewinds, the rescue [Re: John McKnight] #129815
01/25/08 08:32 AM
01/25/08 08:32 AM
Thanks for your report John. It could have been any of us who sailed on that day.
I had some major miscalculations of my own. Sailing an F16, I took a strong experienced crew. Experienced on a variety of boats, but not F16s and not spinnakers.
My miscalculation was falling off the boat, leaving the crew alone! He simply lacked the knowledge and experience for righting, so we were dependant on others for assistance. And sure enough, Tim and Andi abandoned their race to help me out.
They shouldn't have been inconvenienced and my crew should not have been placed in that situation. That was my fault. It won't happen again.
Re: Tradewinds, the rescue [Re: fin.] #129816
01/25/08 04:50 PM
01/25/08 04:50 PM
Well it is a good thing he stayed with the boat! When we went by we saw him waving but were not sure if he wanted help or was just saying Hi. As we sped by under spinnaker, I was looking at the boat and looking for "the other guy" who I assumed was on the other side of the tramp. Once we passed by, I realized, there is NO other guy, he must have got separated and be upwind somewhere. So we snuffed and sailed back upwind to the boat, asked Auri (sp?) "Where's Pete??". He points up wind and says, "Back there." I looked up wind but with the whitecaps couldn't see you anywhere, so I asked, "How far?" He said something like, "Way back". So we took off upwind to look.
Andi sugested I stand up on the tramp to get a better look but I think he spotted you first. His eyes are 10 years younger than mine! What made me mad was when I asked you how many other boats had passed you by and you said, "All of them..."
When you see a boat on it's side and you KNOW there is a missing person, it is your duty to go and find them, just as you would like to be found if it were you. I looked around but saw no crash boats in the area (too busy elsewhere) so I knew it was us or nobody to find you.
I'm sure it will happen to many of us again the next time there is that much wind, people will get separated. I only hope somebody stops to ask if everything is ok when it does. It's a really crappy feeling to be in the water watching your boat drift away faster than you can swim for it! And you can get redress for the rescue when it's over.
John, great job on your rescue above, I know it's hard to get a motor boat near a sailboat without some damage to one or both. I was nearly -helped- to death one day out on my lake by a well meaning but inexperienced pontoon boat operator who thoght I needed help after a pitch-pole, but he nearly ran over my mast and then me! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Re: Tradewinds, the rescue [Re: Timbo] #129817
01/30/08 01:09 PM
01/30/08 01:09 PM
fort Myers, FL
arievd Offline
arievd  Offline
fort Myers, FL
Thanks again Tim and Andy! Pete was right, my lack of F16 and spin experience showed, I was floating along with the boat trying to figure out the best way to stow the spin etc prior to righting the boat without doing any damage (my experience is (was)exclusively on non-spin boats), and by that time you guys had come along and redelivered Pete. On the bright side, I now do know how to get the thing back upright! <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />
Arie
Hobie 16 111812
Re: Tradewinds, the rescue [Re: Timbo] #129818
01/31/08 09:06 PM
01/31/08 09:06 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Rescue can be tricky, safety is job one. I have learned how to pick up swimmers from a few years of pulling kids on tubes. There is no fast way to do it and you have to have a protocol to follow to avoid injury. Always keep a conservative distance unless life is in danger. Even tossing the water bottles at the sailors was a little goosey at times with that wind, I bumped a young lady on a Wave once, thank God for inventing rotomold.
Re: Tradewinds, the rescue [Re: John McKnight] #129819
02/03/08 10:04 AM
02/03/08 10:04 AM
Hey John, I think there is a picture of you guys towing the I20 on about page 15 in the photos, follow the link from the Tradewinds cover story to the photos, there are about 30 pages of them but in one, near page 15 I think, way off in the background, I see a powerboat with an I20 on it's side just behind it. And notice that in most photos there is a cat on it's side somewhere in the background! That's the kind of day it was!
0 registered members (), 640 guests, and 432 spiders.
