| Re: HOBIE 18 problems ?
[Re: grandpap]
#130168 01/30/08 01:34 PM 01/30/08 01:34 PM |
Posts: 12,310 South Carolina | On any boat with age, stress fractures are a concern. Keep an eye on the bow section just forward of the main beam for any minor cracks and watch the shroud connections for any signs of movement. I've seen a Hobie 18 fold up a hull just forward of the main beam (and seen older Nacras do the same).
Jake Kohl | | | Re: HOBIE 18 problems ?
[Re: grandpap]
#130170 01/30/08 01:46 PM 01/30/08 01:46 PM |
Joined: Nov 2003 Posts: 749 Santa Cruz, CA SurfCityRacing
Posts: 749 Santa Cruz, CA | There's the possibility of those things happening to any boat, that's why maintenance and inspection are important. I'm not aware of any specific hull weaknesses in that vintage 18 other than the chainplate anchor points and the hull/deck seam near the crossbars, they were built pretty tough tough. Check the hulls and crossbars for cracks and deformation and cracks around the crossbars.
As far as the rigging...change it out every 5 years at least, no matter what. Starting at the anchor pins, and moving up to the mast tang, replace everything in between. Hobie recommends a shorter interval. Of course if you see any damage to any of the wires, replace them. Corrosion starts from the inside of the roller swages and you can't see it until a crack develops at which time the fitting is considerably weakened.
Anchor pins are critical replacement items!!!
Whatever you do, don't buy used rigging off of ebay. There have been a rash of dismastings here locally by people that got a "deal" on rigging. Go to your local Hobie dealer for rigging, it will be considerably less expensive than having it custom built at a rigging shop, and they have all the proper specs at the factory.
Good rigging on the older 18's is probably the most important maintenance item. Like I said before the 18's are pretty tough!!
Hope that helps. | | | Re: HOBIE 18 problems ?
[Re: SurfCityRacing]
#130171 01/30/08 02:50 PM 01/30/08 02:50 PM |
Joined: Apr 2006 Posts: 699 SE Pa. or Chesapeak Bay HMurphey
Posts: 699 SE Pa. or Chesapeak Bay | Hi Grandpa,
Ken Marshacks advice is spot on. Starting in June 84'(I believe)to sometime in 86' the "Red Foam" hulls were produced. To determine if you have these hulls look closely at the lip/gunwale, if there is a thin red line down the middle .... for further comformation take a flashlight and a small mirror, and looking through the porthole inspect at the joint (inside) between the hull cap/top and the hull bottom. If you see what looks like "red" foam/caulking ...
Know follow Ken's advice by inspecting the underside of the gunwales for long longitudinal cracks at the bolt holes. With the palm of your hand "feel" the hull just in front of the crossbar, does it feel flat or are there whipples. If you have whipples it is because the bows are towing in under load.
How to fix: DO NOT use a mainsheet stack of a ratio of greater then 6x1, the 7x1 stack can generate enough force to cause the bows to tow in and eventually cause failure. On my origonal red foam hulls I could go "block to block" with the 7x1 stack and guess what eventually happened ...
You should reinforce the crossbar cradles, and shroud anchor points on the inside with some additional layers of cloth and epoxy (WEST System) following all the standard practices. And add the retrokit crossbar/shroud anchor support plates, they are available through your Hobie dealer at a reduced price for this. I believe you will have to supply serial #'s to receive this deal
My E-mail address is in my profile, please feel free to contact me with any questions and I will happily share my experience with you.
Quote: "Most men learn from their own mistakes, I on the other hand prefer to learn from OTHER mens mistakes." Bismark. ( I think it is also cheaper)
Sail Flat, Sail Fast HarryMurphey H-18mag/ #9458, Fleet 54 Div 11 P-19mx/ #86, CRAC | | | Re: HOBIE 18 problems ?
#130172 01/30/08 02:51 PM 01/30/08 02:51 PM |
Joined: Mar 2005 Posts: 72 Rockledge Cay, FL Fearless_Rider
Posts: 72 Rockledge Cay, FL | ******WARNING***** The shroud attachment points are prone to failures on the TheMightyHobie18! It's an easy fix though... examine the stainless eyebolt fitting (which connects to the chain plate) that passes through the outer hull lip and threads into a round piece of stainless with a tapped hole. The threaded eyebolt sometimes developes cracks within the valleys of the threads that exist between the rod and the lip of the hull. CHECK OFTEN AND CAREFULLY!
BTW, my BBQ Rocks!
[Re: srm]
#130175 01/30/08 04:35 PM 01/30/08 04:35 PM |
Posts: 1,187 38.912, -95.37 | Here's a relatively in depth discussion on adding shroud anchor plates at the front and rear beams http://www.hobiecat.com/community/viewtopic.php?t=8060&highlight=anchorMore/older posts are available on the Hobie site via the search function. Quote: "Most men learn from their own mistakes, I on the other hand prefer to learn from OTHER mens mistakes." Bismark. ( I think it is also cheaper) Quote "the best lessons learned are expensive, painful and humiliating" Jason's Dad <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: mmiller]
#130178 01/31/08 10:03 AM 01/31/08 10:03 AM | Anonymous
| Anonymous
Unregistered | I had allot of "slop" in my TheMightyHobie18 hulls last season. At one point I used about 15 "custom" rivets on my rear beam to help secure it and reduce play.
I did inspect and tighten the bolts (often) that secure the beams to the hulls. At last inspection 1 rear bolt had completely fallen out. This certainly didn’t help with the “Hobie wobble” in my hulls.
We ended up removing the rear beam and then found out I had stress fractures at the bolt holes on the beam. They were completely hidden and only found when the beam was removed.
A quick run to the alum welder and $75 fixed the situation. That is until I realized he had sanded off some rivets that hold the anchor (a big slug in the beam that anchors the hull/beam bolts) inside the rear beam off... 1 problem fixed 1 new problem to handle).
It sailed my 1985 TheMightyHobie18 about 100 days last year (and same for the year before that). I flew the hull at every chance, and did use Harkin, ratchamatic 7 to 1's. I never complained about service or maintaining the boat (even when I broke shroud anchor bolt and demasted)... I certainly got my moneys worth out of that boat and hope it treats its new owner as well as it did me.
[Re: ]
#130180 01/31/08 06:10 PM 01/31/08 06:10 PM |
Posts: 1,252 California | use Harkin, ratchamatic 7 to 1's Yes, 7:1 would be standard on the Hobie 18 and not a concern. The shroud anchor pin is the same for all models. We changed to a rolled thread several years ago to reduce the possibility of a thread cutting process creating a problem. The breaking strength is greatly improved. | | | Re: HOBIE 18 problems ?
[Re: DHO]
#130182 02/01/08 12:24 PM 02/01/08 12:24 PM |
Posts: 291 | Not the hull issues but if your chainplates are original I would definatley spend the 20 bucks to replace them.
[Re: DHO]
#130183 02/01/08 12:30 PM 02/01/08 12:30 PM |
Posts: 1,252 California | My TheMightyHobie18 is from 1978. Probably one of the first several hundred made. Should I be worried about any of this? Check the shroud anchor plate as described earlier. Be sure you have the plate with 4 bolts below the shround anchor area. | | | Re: HOBIE 18 problems ?
[Re: mmiller]
#130184 02/05/08 11:50 PM 02/05/08 11:50 PM |
Joined: Jan 2004 Posts: 216 Lakewood, Colorado MUST429
Posts: 216 Lakewood, Colorado | [quote The shroud anchor pin is the same for all models. We changed to a rolled thread several years ago to reduce the possibility of a thread cutting process creating a problem. The breaking strength is greatly improved. [/quote]
Matt, Having sailed a Hobie 18 since 1980, including but not limited to a 1980, 1982, 1986, 1988, and my current boat, a 2004, picked up from the Dealer in October of 2003, the same week the announcement was made that the boat was being discontinued, I have a fair perspective on the 18, and its pattern failures. That having been said, this year, for the first time I experienced a catastrophic failure of the shroud anchor pin on my 2004. Sadly it was on the starting line at the NAC event in New York. Thanks to outstanding help from the support safety boat, the beach captain, and the generosity of Matt Bounds who allowed me to rob one off of his H-16 that was sitting on the beach, we were able to reassemble my boat and make it out for the next race. Given the fact that I was racing within 5# of minimum weight, the wind and wave conditions that day were not by any stretch of the imagination "extreme" also the boat has only been sailed in salt water one time, and is stored inside a heated garage, that you may have a little more work to do on that particular piece of hardware.
Respectfully, Stephen
Life is not about waiting for the storms to pass... It's about learning to dance in the rain
635
guests, and 181
