| broken tiller extension help!! #130599 02/02/08 11:31 PM 02/02/08 11:31 PM |
Joined: Jul 2005 Posts: 267 Ocean Springs, MS Capt_Cardiac OP
Posts: 267 Ocean Springs, MS | i've searched the archives but can't find the answer. I have a "duel sail system" telescoping tiller ext. its 7/8" in diameter and ranges from 66-125". I had a pretty good wreck 2 days ago and since then it won't engage the extension lock mechanism. i've tried all sorts of things to take it apart but can't unlock the puzzle. the grip end is 5/8". when i look in from the bottom i see a plastic "disk" blocking the way to the extending tube. i suspect this has dislodged from the inside tube. i can get it to move with a dowel but it won't "snap" back into place. I've tried knocking it out the bottom by hitting it from the top with a dowel. no luck. the inside tube won't come out the end and the "disk" is keeping it from coming out the bottom. is there anyone with some experience taking this one apart????
thanks
cc
Capt Cardiac Ocean Springs Yacht Club Sailor Nacra20 - Flight of Ideas #5 | | | Re: broken tiller extension help!!
[Re: Capt_Cardiac]
#130601 02/03/08 08:25 AM 02/03/08 08:25 AM | Anonymous
| Anonymous
Unregistered | i have never had luck with repairing alum sticks either | | | Re: broken tiller extension help!!
[Re: ]
#130602 02/03/08 09:18 AM 02/03/08 09:18 AM |
Posts: 6,049 Sebring, Florida. | I have always had one of those adjustable tiller extensions until I got the Blade, which has a fixed length fiberglass rod. I now find I like it much better, it never slides in or out when you are steering and I don't ever have to play with it while racing, just flip it around the blocks, grab it and go.
I think most of the A cat guys use a fixed carbon rod but at about $300 each, a little too much for me. The fixed fiberglass rod is less than $20 but quite a bit heavier. I don't think it slows me down though. A compromise might be a fixed length aluminum tube, but they will bend (or break) if you abuse them! I doubt I will ever go back to one of the sliding, adjustable types.
Blade F16 #777
[Re: HMurphey]
#130605 02/03/08 09:49 AM 02/03/08 09:49 AM |
Posts: 1,187 38.912, -95.37 | Sometimes the easist way to fix something is to throw $$$$ at it. A New Magnum "Hot Stick" ??? Even though his product is at Murray's, I've heard Bobby say he prefers selling to the OEM boat builders, and dealing directly with the end user. He's an avid racer and will get you exactly the dimensions you need for your boat. Drop him a line http://www.arribastick.com/
2,669
guests, and 213
