| So what is the Viper's Texel handicap #130841 02/04/08 08:08 AM 02/04/08 08:08 AM |
Posts: 539 | Got a regatta coming up in Singapore and trying to ensure that the correct Texel handicaps are used. Already had them correct the A-Cat from 100 to 101, but want to make sure the other boats are right. We are expecting 30 to 35 boats so should be a great turnout.
Now I believe that the Viper should be marked at 103 like the rest of the F16 boats, but Goodall and the local dealer think that it is 104 due to its excess weight.
But what I don't get is that the Viper was designed to the F16 box rule, but the builders/designers for some reason decided to make it more bloated and heavy rather than going for the class minimum weight. That is the only aspect where it differs from other F16 designs.
If it turned up at an F16 event it wouldn't get a credit for being heavier, so I believe that it should be rated at 103. We have a "F16 event" in April, so in that all boats won't have handicaps and where you finish across the line is your result, so you can't have it both ways. That to me is really taking the piss.
So looking to canvass views of what the F16 community thinks. We will be having 6 or so Vipers, and 10 or so Taipans all with kites racing. The guy with the Blade is unfortunately away.
Also find it funny that the Taipan is pushed as the older design here and need to upgrade to a more modern boat, but that boat rates slower!!
And whilst we are at it, what would the Texel rating be for a Taipan with a standard F16 spin, Taipan class jib, but a F16 design mainsail. And also the same boat with a 21 sq m kite.
Thanks!! | | | Some corrections ...
[Re: Hans_Ned_111]
#130844 02/04/08 03:06 PM 02/04/08 03:06 PM |
The short and simple answer is :
F16 1-up Texel = 101 (and not 100, as Hans says) F16 2-up Texel = 102
Taipan 1-up OD Texel = 108 (no spi and no new mainsail design are any F16 mods) Taipan 2-up OD Texel = 107 (no spi and no new mainsail design are any F16 mods)
Taipan 1-up OD with F16 or 21 sq. mtr spi Texel = 102 (but not the new mainsail) Taipan 2-up OD with F16 or 21 sp. mtr spi Texel = 103 (but not the new mainsail)
If a Taipan has a new mainsail as adopted by the Taipan class a while ago or has any other modifification not allowed by its 2002 class rules then that Taipan has no Texel handicap and can not officially make use of the F16 handicap either. The latter is the result of the F16 class rules that state that modifying the Taipan in any way, except adding a F16 spi, putting it out of its own 2002 class will void any F16 grandfather status.
Then what Hans says is correct, the Viper should be officially measured by a Texel official or an official accepted by Texel committee (ISAF measurers I guess) to get an official handicap awarded. Currently it has none.
If any Taipan owner modifies for example his mainsail to F16 specs then he can't sail with the Taipan jib anymore while making an appeal to F16 status. The Taipan jib is NOT F16 compliant and it is only grandfathered in combination with the (old) Taipan OD mainsail as that is slightly less performant then the new mainsails.
| | | Re: So what is the Viper's Texel handicap
[Re: tom_in_fire]
#130847 02/05/08 07:15 AM 02/05/08 07:15 AM |
Posts: 1,479 Thailand | So let me get this straight. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> F16 2-up Texel = 102 Viper 16 2-up Texel = 103 unless it's a 104 Old Taipan with newly approved main is faster then all of the above. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
[Re: Hans_Ned_111]
#130850 02/05/08 08:08 AM 02/05/08 08:08 AM | Anonymous
| Anonymous
Unregistered | When the boat weights 125 kg it will have a TR rating of 104 but it will NOT enter as a F16 to that event but as a Viper and will not sail in the F16 class of that open event. It will sail in the open or own class.
Isn't it true though that the skipper may choose to enter an open event as F16 and take the 101/102 F16 rating? I'm thinking that Viper owners may consider that their boats are actually just as fast as other F16s and prefer to sail to what they consider to be a more realistic rating in order to promote the view that the Viper is fully competitive as a F16. | | | Re: So what is the Viper's Texel handicap
[Re: Buccaneer]
#130851 02/05/08 08:56 AM 02/05/08 08:56 AM |
Posts: 9,582 North-West Europe | Old Taipan with newly approved main is faster then all of the above.
Only to people who have trouble noticing that a Taipan OD with spi at 103 is actually slower then a 102 F16 ! The new Taipan main can never make the Taipan rating faster by more then 1 point (rounded off, as difference it is actually 0.58%) before becoming non-F16 compliant. That means you again buccy ! have you ever been right in any of your postings so far ? Wouter
[Re: ]
#130853 02/05/08 11:08 AM 02/05/08 11:08 AM |
Posts: 221 Netherlands | When the boat weights 125 kg it will have a TR rating of 104 but it will NOT enter as a F16 to that event but as a Viper and will not sail in the F16 class of that open event. It will sail in the open or own class.
Isn't it true though that the skipper may choose to enter an open event as F16 and take the 101/102 F16 rating? I'm thinking that Viper owners may consider that their boats are actually just as fast as other F16s and prefer to sail to what they consider to be a more realistic rating in order to promote the view that the Viper is fully competitive as a F16. Yes ofcourse people may choose, i am not saying that. I only try to make clear that there is a difference when sailing an open event and sailing a F16 event. You have a choise with the Viper at 125 kg. | | | Re: So what is the Viper's Texel handicap
[Re: taipanfc]
#130854 02/05/08 11:54 AM 02/05/08 11:54 AM | Anonymous
| Anonymous
Unregistered | Say, when is that regatta? I just found out that I may be in Singapore the week of March 10. | | | Re: So what is the Viper's Texel handicap
[Re: ]
#130855 02/05/08 08:29 PM 02/05/08 08:29 PM |
Posts: 539 | MarkMT (and anyone else who is interested), Singapore regatta dates coming up are: Feb 23/24 - Monsoon Cup (also raced with yachts, sportboats, J24s and other lead poisonous things) Mar 15/16 - National Cat Champs Mar 23 - Outermark Race (distance race) Apr 5/6 - F16 Cat Champs Send a PM, or contact Alice Lim through this website: http://www.prosail-asia.com/ Sure to get you on a boat. | | | Re: So what is the Viper's Texel handicap
[Re: taipanfc]
#130856 02/05/08 09:03 PM 02/05/08 09:03 PM | Anonymous
| Anonymous
Unregistered | Cool. Even if I could get on the water to take photos I'd be thrilled (no sailing here in March <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> ). I will update you as my plans firm in the next few days. | | | Re: Some corrections ...
[Re: Wouter]
#130857 02/05/08 09:20 PM 02/05/08 09:20 PM |
Posts: 539 | Then what Hans says is correct, the Viper should be officially measured by a Texel official or an official accepted by Texel committee (ISAF measurers I guess) to get an official handicap awarded. Currently it has none.
So, if the Viper was designed to the F16 rule, and meets all the requirements then it should race on: F16 1-up Texel = 101 F16 2-up Texel = 102 We don't have any scales at our club so weight cannot be verified (but it does "feel" a lot heavier), and there aren't any measurers locally. Giving itself a rating of 104 isn't really justified until it has an official measurement cert to qualify that number. | | | Re: Some corrections ...
[Re: Hans_Ned_111]
#130859 02/06/08 12:05 PM 02/06/08 12:05 PM |
Posts: 3,528 Looking for a Job, I got credi... | The fact is that in both ways you will try to do your best to get a measurement certificate. This will ban every discussion. If the Viper has a measurement certificate then you can say what the TR can be. It is designed as a full spec F16.
Regards, Hans Exactly. If a Viper owner can present a measurement cert stating all up weight then it will get a SCHRS rating with that weight AS A VIPER. But if you enter the Viper as an F16 then you sail on the F16 rating.
F16 - GBR 553 - SOLD I also talk sport here | | |
4,629
guests, and 1,212
