| Advice for a newb ... #131182 02/08/08 11:12 AM 02/08/08 11:12 AM |
Posts: 8 Snoqualmie, WA | Hi all,
I've been doing lotsa research lately about getting into doing some beach cat sailing.
First let me start with some background ... I've been around boats most of my life living in AK. Most power, but have launched row dinghies into surf. Very little sailing other than rides/crew when young. My wife hasn't been on water much at all ...
I've also repaired boats (some quite extensive), so working with wood and fiberglass is not a problem for me.
On a recent vacation, we took out a beach cat for a few trips. That was enough to get her hooked, and now we'd like to get a cat we can use in the lakes here in the pacific northwest (probably trips down to the gorge too). We'll probably be moving to CA in the next few years which would increase the season we'd use a boat also.
I'm curious on suggestions some of the "salts" here would have about us getting started ...
Some options I've been considering.
1) Get a used boat (h16?), fix it up, and build my sailing skills. Would probably also mean lotsa renovation to be reliable and a decent performer. boat + trailer + refit == $3000?
2) Get a new boat (getaway?). Would get me sailing immediately, but may be disappointed with performance? Also, at $7500 (for a getaway+wings), I'd want it to hold some resale if/when I wanted.
3) Build a boat (Blade F16). Something I'll probably do (and the scope of the project doesn't worry me), but means I'd be building rather than sailing for a year. Any ideas on the cost here. Not looking for a fully race ready rig, but quality components (au spars, harken blocks, etc). If I went with option #1, how much of that rig could move over? For example, say I can get a cheap H16 that needs sails, could I get a F16 sail (perhaps with new spars), fit it to the H16 until I get to building new hulls?
My current thoughts are to keep my eyes out for a decent used 16' cat, but if nothing shows up perhaps bite the bullet and get the getaway. Then perhaps next winter I would start on a blade ... | | | Re: Advice for a newb ...
[Re: CurreyR]
#131183 02/08/08 11:53 AM 02/08/08 11:53 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Sounds like you have a plan.
My advice is stay away form the Getaway, unless that's what you're really looking for.
Used H 16's are dimes a dozen.
Good luck
F-18 Infusion #626- SOLD it!
[Re: Todd_Sails]
#131185 02/08/08 12:19 PM 02/08/08 12:19 PM |
Posts: 168 San Diego | You should easily be able to get a mid-80s Hobie 16/18, Nacra 5.0/5.2/5.7, prindle 16/18 for your price range. Look on the classifieds here, at thebeachcats.com, craigslist.org, and local newspapers for areas you are willing to drive to. | | | Re: Advice for a newb ...
[Re: mbounds]
#131186 02/08/08 01:39 PM 02/08/08 01:39 PM |
Posts: 8 Snoqualmie, WA | Plan A sounds the best for now.
Hook up with Hobie Fleet 95 in Seattle. They can turn you on to a good used boat. got any link on contacting them? ... I see fleet 72 seems active, but my search-fu is failing me to contact fleet 95. | | | Re: Advice for a newb ...
[Re: hokie]
#131187 02/08/08 02:04 PM 02/08/08 02:04 PM |
Posts: 8 Snoqualmie, WA | You should easily be able to get a mid-80s Hobie 16/18, Nacra 5.0/5.2/5.7, prindle 16/18 for your price range. Look on the classifieds here, at thebeachcats.com, craigslist.org, and local newspapers for areas you are willing to drive to. I might go look at this ... http://seattle.craigslist.org/est/boa/564018493.htmlpossibly a bit too much boat for a newb like me, but if I can hook up with some locals, it might be a good boat to grow into. | | | Re: Advice for a newb ...
[Re: CurreyR]
#131188 02/08/08 02:33 PM 02/08/08 02:33 PM |
I'm a F16 class co-founder and I say that option (1) is your best choice at this time.
Don't try to use H16 parts of whatever on the Blade F16, except small blocks and lines maybe. All the other stuff like mast, sails, mainsheet blocks etc needs to be suited to the F16 setup and none of the H16, P16 or whatever are. F16 is a total concept that pretty much needs all to work together well. That means a lightweight mast, relatively flat mainsail, high powered mainsheet blocks, highly stressed downhaul system. Otherwise sailing an F16 is about as much fun as riding a wild mustang.
If you still want a boat like the F16 eventually then I would find yourself a nice secondhander for a decent price and start building the F16 over 2 years or so while sailing this boat on the fair weather days. That will also take the pressure of the boatbuilding. Then after a year or 2 you'll be ready to switch boats and if you want or need the money you can sell your secondhander on to another newby.
[Re: Wouter]
#131191 02/08/08 03:19 PM 02/08/08 03:19 PM |
Joined: Apr 2006 Posts: 699 SE Pa. or Chesapeak Bay HMurphey
Posts: 699 SE Pa. or Chesapeak Bay | Hi,
Wouter's advise is spot on as usual. Let me add the comment that if you plan to eventually sail a more technical boat with more adjustments I would look for at the slightly larger boats then the H-16 or P-16/18, boats with adjustable mast rotation, downhaul, and outhaul features on the mainsail. The Nacra 5.5 was a nice ride sloop/uni-rig as were the 5.2s & 5.8s. Depending on your wieght the Prindle-18/2 or the P-19 are excellent rides also. The cheapest, most availible Hobie with these features would be the H-18 (of course), they are still raced so as to improve your skills quickly and are indestructable (all-most). If you wish find a "Magnum" (wings) model for cruising w/ friends, remove the wings for "class" racing. Currently HobieCat is producing an excellent quality set of sails for the boat.
The H-20 is too much of a pure racing machine and is very hard on novice crews. (unless your girlfriend is on the helm) It beats the women up terribly, its the jib traveler on the tramp-bruise city. The Nacra 6.0 is the same and the H-21se is most likely just Too large/heavy for you. The I/N-20s even used are pricey !!!
So I would find a used H-18mag, and start to learn ... building the F-16 over the next few years ... or buy a F-18 boat when you know how to make it GOoooo !!! You may find that you keep the H-18mag as a "beater", they are really good when the kids,nephews/nieces want to start to sail ....
Thats what happened to me ... you regress as you get older and slowwer.
Sail Flat, Sail Fast HarryMurphey H-18mag/#9458, Fleet54/Div11 P-19mx/#86, CRAC | | | Re: Advice for a newb ...
[Re: CurreyR]
#131192 02/08/08 03:27 PM 02/08/08 03:27 PM |
Posts: 334 Seattle,Wa | Plan A sounds the best for now.
Hook up with Hobie Fleet 95 in Seattle. They can turn you on to a good used boat. got any link on contacting them? ... I see fleet 72 seems active, but my search-fu is failing me to contact fleet 95. Don't worry Fleet 95 has found you! Go to http://www.div4.hobieclass.com/ for all the contacts and links. Or, http://www.hobiecat.com/community/viewforum.php?f=38We'll also be down at the Sail Sand Point Center on Saturday 2/9 @ 1:00pm. It's also the home of HobieCats Northwest, our local dealer.
Hobie Tiger 2003 | | | Re: Advice for a newb ...
[Re: CurreyR]
#131195 02/08/08 05:02 PM 02/08/08 05:02 PM |
Posts: 120 Finland | If you are interested in building more than the outcome then I would say go for it. I wont guess on prices though because I don't know situation at states, you'll save some money comparing a brand new one but you'll spend lot of time on your project. For me the journey was quite relaxing (mostly) and totally different than my day job.
Bottom line is that if you are just building to get a boat to sail you better get yourself brand new or used boat instead and go sailing <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />.
Valtteri
[Re: valtteri]
#131196 02/08/08 05:17 PM 02/08/08 05:17 PM |
Posts: 8 Snoqualmie, WA | Honestly, I *like* building. Primarily it's the pride in knowing *I* made this. There is also the fact I get it done *my* way and not what was cost effective or easily mass-produced. I'm also capable (and have the facilities), so that's not an issue ... concentrated time for a whole year, that can become an issue.
For example, I've been active in 4x4 off-roading, and there is a BIG differance in reliability, adjustability, and capability between a rig that is "built" vs an "off the lot" jeep with some additional $$$ parts.
I suspect the same is true for the sailing community. You may not have to home build hulls, but being able to outfit to *your* liking is what makes it *your* boat (race or not).
That said, I *DO* want to get some sailing done this season to build skills (no substitute for tiller time), so sounds like I'll by a used boat and then continue to dream about my *perfect* setup. | | | Re: Advice for a newb ...
[Re: CurreyR]
#131197 02/08/08 05:53 PM 02/08/08 05:53 PM |
Posts: 757 japan | just some ideas
- if the other 2 pass on that p18/2 buy that
- while it is still too cold to sail take bits off and put them back on, boom, rudder assembly etc. practice hoisting the sails on windless days, (nice sunny mornings god for this) tip it over and take the mast off, take it on and off the trailer etc.....
- when the sailing season starts take it down to the hobie fleet and ask if anyone wants to helm while you crew
- then swap and you helm while they crew
- offer to swap boats with anyone for the day
- if you find you really like the hobies let people know you'd swap boats for good
[Re: erice]
#131198 02/11/08 02:24 PM 02/11/08 02:24 PM |
Posts: 8 Snoqualmie, WA | So ... Seems like I'll get a used boat to start with. I traded some PM's with HMurphy about "size" ... I'd like to get a boat that I can right myself (I'm about 200 lbs). I also want something that'll be "fun" when my wife crews (she's about 160lbs). I also don;t expect to use this as a "race" boat, more of a "fun" boat. Thing is some performance is what'll make it fun (as well as just running around the water on a nice day). So, 16' or 18'? An 18 (or larger) I'm worried would be too much for me to rite myself, but sounds like would be great for a 360lbs of skip+crew. A 16 I would hope I could rite, might be a bit slow with our 360lbs, but still fun enough? I appreciate the comments so far, and have been watching for used boats in my area. - while it is still too cold to sail take bits off and put them back on, boom, rudder assembly etc. practice hoisting the sails on windless days, (nice sunny mornings god for this) tip it over and take the mast off, take it on and off the trailer etc.....
Yea, that's part of my plan on getting up to speed. | | | Re: Advice for a newb ...
[Re: CurreyR]
#131199 02/11/08 02:40 PM 02/11/08 02:40 PM |
Posts: 120 Finland | You sound like good candidate for enjoying the build process. I wasn't trying to put you down, just meant that it takes time to build that could be spent sailing if that is biggest priority. And launching your own creation is awesome feeling <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />.
Valtteri
[Re: valtteri]
#131201 02/11/08 03:30 PM 02/11/08 03:30 PM | Anonymous
| Anonymous
Unregistered | Forget righting it yourself... get mast float and a big righting bag and dont worry about it. | | |
16,085
guests, and 376
