| Re: Hi speed V hulls, advice please.
[Re: PTP]
#131409 02/13/08 09:42 PM 02/13/08 09:42 PM |
Posts: 757 japan | very interesting project
where are you in the bay?
that looks a little like what i remember of matauwhi bay, by the reserve, or are you somewhere else entirely?
looking forward to seeing some pics with the new rig
[Re: warbird]
#131411 02/14/08 12:18 AM 02/14/08 12:18 AM |
Posts: 182 Coopersburg, PA | put a spinny on that beast and then I bet you'll be able to get her up to 25 knots in that wind. Its possible to get up to that kind of speed in any boat I would assume, but you are going to need a nasty storm with some sick winds, and a heavy crew. Keep us updated though on your progress! This kind of stuff gives me something to look forward to while I let the snow slowly melt away up here.
~vinny~
[Re: warbird]
#131414 02/14/08 04:41 AM 02/14/08 04:41 AM |
Posts: 1,203 uk | My top speeds have been 25.3 knots on the F18 and a little less on the inter20. That was only in bursts though. Without spinnaker too. I think that a spinnaker would collapse at 25 knots boat speed. A sustained 25 knots is a big ask for any boat. All the best.
[Re: warbird]
#131417 02/14/08 08:19 AM 02/14/08 08:19 AM |
Posts: 1,187 38.912, -95.37 | I've got "old school" standing rigging (read WAY less mast rake) on our H16 because we don't race the boat and use the boat primarily for what you're doing. While rake significantly helps pointing ability, IMO, it only hinders all other points of sale. Our stick's straight up compared to race position for beam/broad reach speed trials.
We travel the jib all the way out, travel the main out 1/3 to half way, trying to find a main traveller position that will allow one arm's length of gust dumping ability and not stuff the bow. Carving up and down the puffs to maintain a constant speed is difficult, at least on the 16, because you can't look over your shoulder, or behind you, to see the puffs coming for fear of stuffing the lee bow, you just have to react. Depending on wind speed (and for you to get to 25 knots) your crew weight will need to be between 450 & 550 pounds. How will you keep a double trapped crew on board? We use a line from the stern to prevent crew falling forward in a stuff (chicken line) main concern would be is your crew experienced enough to find the right trapeze height and agility to not be washed off when slammed by a wave at that speed. Also crew needs to anticipate major and quick course changes to avoid pitching in puffs and in order to maintain control of the boat I've found I cannot trapeze and maintain balance. I'm at the rear corner steering, eating water, trying to maintain vision.
Best of Luck
[Re: _flatlander_]
#131418 02/14/08 09:04 AM 02/14/08 09:04 AM |
Posts: 915 Dublin, Ireland | Set up the rig so that it can be tilted to windward - like a windsurfer. The Catapult has this facility.
Dermot Catapult 265
[Re: PTP]
#131419 02/14/08 10:05 AM 02/14/08 10:05 AM | Anonymous
| Anonymous
Unregistered | Raking will reduce power. Why would you rake it in an attempt to increase speed?
[Re: claus]
#131421 02/14/08 05:22 PM 02/14/08 05:22 PM |
Joined: Jul 2006 Posts: 1,147 Bay of Islands, NZ warbird OP
Posts: 1,147 Bay of Islands, NZ | Thanks for all of these comments. Mast rake is not for speed but to help with reducing healing moment. As I explained the boat has heaps of power, too much for really high speed. The sail is an old one cut to shape. It is very flat. I will do practice runs first to make sure new sail is worth while. I will also go to a broken A class carbon fiber mast so I can induce pre bend and lose weight. The boat is foam core and was 114 Kgs new. I particularly appreciate the Hobie experience of actually going out there for speed alone. What speeds have you logged?. I will take that info with me. As I have said I have used it once. Yesterday sailing at 15 knots boat speed in approx 15 knots of wind was okay as a start. I was hiking, not trapping and only one up and controlling the boat easily. I would crew when really trying to go fast. My crew will be just a tiller man. The main problem was the fullness of the jib and the way it was set as I had spent two days fitting the rig and ironing the most basic of problems. This is really about the hull shape guys. I opened my mouth here to say that planing is worth working into the late model boats and so I am just playing with that.
Also, the rig idea to pull the mast over, yes, I have thought through that and might go there but I wanted something that could relate to buoy style sailing.
Also, I wasted the Hydras downwind yesterday so I am not feeling downwind has been so adversely affected.....but I was planing and they were starting to stuff. | | | Re: Hi speed V hulls, advice please.
[Re: warbird]
#131422 02/14/08 05:44 PM 02/14/08 05:44 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Does it actually, really, truly plane? If so, that would be very exciting. <img src="http://www.catsailor.com/forums/images/graemlins/ooo.gif" alt="" /> | | | Re: Hi speed V hulls, advice please.
[Re: warbird]
#131423 02/14/08 05:53 PM 02/14/08 05:53 PM | Anonymous
| Anonymous
Unregistered | The boat is foam core and was 114 Kgs new. Wow, is that true? I had the original ply version that was used to make the mold for the glass boats (what I was told at least). It's a long time ago but I think it was a whole lot heavier than my Blade. | | | Re: Hi speed V hulls, advice please.
[Re: Mary]
#131424 02/14/08 05:56 PM 02/14/08 05:56 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | Warbird,
That is a great looking boat! The squaretop just looks right. Have you considered a full batten jib? One of the reasons a H16 is such a reach-monster. I love projects like this.
Also- You might want to consider a Hooter type sail. We plan to use one on our next boat and it is an old flat reacher from an E-Scow. Looks like a genoa more than a spinnaker- so fast at tight angles. Roller furled for ease of handling.
E-Scow 24' ULDB
20,577
guests, and 826
