| Re: Building a mast
[Re: Gato]
#133020 03/06/08 01:52 AM 03/06/08 01:52 AM | Anonymous
| Anonymous
Unregistered | Gato, lets assume you're going to use your existing profile. Can you please email it to me and I'll use its geometry when defining laminates. Do you have access to a tube for the track? do you definately want to strip plank or is ply an option? Whats the minimum practical thickness for your stripping system? | | | Re: Building a mast
[Re: Gato]
#133029 03/06/08 04:38 PM 03/06/08 04:38 PM | Anonymous
| Anonymous
Unregistered | Of course not. I'll do it from scratch it will just take a bit longer.
Rolf, you could always strip plank a female mould and then make a straight carbon mast. | | | Re: Building a mast
[Re: Rolf_Nilsen]
#133031 03/06/08 05:41 PM 03/06/08 05:41 PM | Anonymous
| Anonymous
Unregistered | My bad I thought the superwing was the default mast extrusion that wouter refers too any generally successful F16 mast will do. | | | Re: Building a mast
[Re: Gato]
#133033 03/07/08 05:35 AM 03/07/08 05:35 AM |
Posts: 1,449 | Folks, I do not want to interrupt the flow here so I will make this short. The fact is I keep all my emails both sent and rxd. I went looking back through them to find some mast deflection data and stumbled across emails about work I was doing on a composite mast. Back in 2003 I made a carbon composite section 6m long and did some deflection tests without and then with cardon on the outside of the section. It's kind of nostalgic reading through the old emails. From the emails it seems this was just before building the Blade prototype.
How time flies.
I also did comparative deflection tests with a superwing and Aussie wing of the same length so I could see how this project compared. (The Aussie wing 50x125mm extruded in Australia in the 80s to combt the importation of Sori sections for the A cat fleet. But in reality it was too heavy.) I have rough sketches that include all components and layups I used. Anyone interested in doing a bit of experimenting I'd be happy to send these emails to you so you can either improve on what I had tried or just say oh well it is better done some other way.
It seems from the emails I had worked out a way of modifying the technique to produce an F16 mast that would weigh around 9.91kg without fittings. How is not detailed in the emails. But If pushed I could probably work it out again. I never actually sailed with this mast just did static deflection tests. So no guarantees.
Anyhow just thought I'd mention it.
Regards, Phill
| | | Re: Building a mast
[Re: phill]
#133034 03/08/08 12:25 AM 03/08/08 12:25 AM | Anonymous
| Anonymous
Unregistered | I now have all the data I need (thanks Phill). I should have a mast for you by next weekend.
Gato, what sort of timber will you be using? | | | Re: Building a mast
[Re: ]
#133035 03/09/08 12:32 AM 03/09/08 12:32 AM | Anonymous
| Anonymous
Unregistered | F16 mast design is done. Will let Gato work out the bugs before giving it to anyone else though.
Theoretical tube weight with 4mm gaboon ply (stripped) core approx 11.5kg. Real world this will go up due to bog etc. Timber makes up about 45% of the weight. | | | Re: Building a mast
[Re: Gato]
#133037 03/09/08 02:06 PM 03/09/08 02:06 PM |
Joined: Oct 2007 Posts: 199 Constanta, Romania isvflorin
Posts: 199 Constanta, Romania | Gato, do you ever get out of the shop ? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Just joking but you seem to have a lot going on. Good luck with the new project and please post pics.
Florin
555
guests, and 40
