| Re: box rule drawing
[Re: taipanfc]
#133339 02/28/08 08:43 AM 02/28/08 08:43 AM |
Posts: 9,582 North-West Europe | Where do you start and stop?
Ehhh, you start with the obvious stuff like the contours of the spi, mainsail and selftacking jib and you stop when you run out of the obvious stuff or run out of time and resources. Currently we still have time and resources, so .... Actually, adjusting the nose to show a more wave-piercer like hull is a good suggestion Taipanfc, we'll add that one to the list. The drawn daggerboard has an aspect ratio of 3 (Taipan/older Blades 1.8 ; new Blades 4) and are a good average if you ask me. Wouter
[Re: Gilo]
#133341 02/28/08 06:35 PM 02/28/08 06:35 PM |
Joined: Oct 2007 Posts: 199 Constanta, Romania isvflorin
Posts: 199 Constanta, Romania | Gill, with so many changes the drawing might not be ready by next Tuesday. But I agree the drawing should reflect a more modern boat/sailplan. Taking the changes step by step will require more time. Also the GC should have a say in this (I assume), I mean what the drawing should/shouldn't have. A more modern design -yes, but the drawing still has to be as simple as possible IMHO. This is the way I see it. Will check this thread soon for the mods.
Florin
[Re: Gilo]
#133343 02/29/08 02:37 PM 02/29/08 02:37 PM |
Posts: 49 | While it would be nice to fully modernise the drawing, we shouldn't allow that to overly-delay the production of the brochure/leaflet.
The wish list:
1. More pronounced 'modern' square-top mainsail 2. Higher aspect jib with or without self tacker 3. A generic hull, styled similar to Blade or Viper with wave piercer bow 4. Remove the lowest batten from the mainsail, add two battens to the jib
Other than these 'wish' items the drawing is fine and needs to be a simple 'at a glance' tool.
Thank you Florin, for doing this for the class, and thank you Gill for organising the flyer!
John Alani, ex-Secretary, F16 Governing Council
413
guests, and 45
