Hobie 17 square top #134115
03/01/08 05:38 AM
03/01/08 05:38 AM
Bay of Islands, NZ
warbird Offline OP
warbird  Offline OP
Bay of Islands, NZ
I just bought a Hobie 17.
Any photos of same with square top?
Re: Hobie 17 square top [Re: warbird] #134116
03/01/08 08:27 AM
03/01/08 08:27 AM
Oklahoma City
ghhm43 Offline
ghhm43  Offline
Oklahoma City
Gordon
Macgregor 222
Nacra 5.5sl
E-Scow 1975 Hull #1
Re: Hobie 17 square top [Re: warbird] #134117
03/01/08 11:40 AM
03/01/08 11:40 AM
Westport, Ma. U.S.A.
Brian_Mc Offline
Brian_Mc  Offline
Here's mine (Attachment). It's a Calvert boomless, and I added the "super jib". I ordered them through Murray's, but suspect you could get them right here too. Brian
Re: Hobie 17 square top [Re: Brian_Mc] #134118
03/01/08 12:13 PM
03/01/08 12:13 PM
You will LOVE the 17 with a squaretop, especially when the wind is 15 and up. It will fly. Here is my old one.
Doug
Re: Hobie 17 square top [Re: ] #134119
03/01/08 02:37 PM
03/01/08 02:37 PM
Bay of Islands, NZ
warbird Offline OP
warbird  Offline OP
Bay of Islands, NZ
Thanks guys, that is great, but Doug, I can't see your one.....??
Re: Hobie 17 square top [Re: warbird] #134120
03/01/08 04:50 PM
03/01/08 04:50 PM
White Bear Lake, MN
h17racer Offline
h17racer  Offline
White Bear Lake, MN
Warbird, attached is one of mine. From Sabre Sails...nice addition....Tom G
Re: Hobie 17 square top [Re: h17racer] #134121
03/01/08 05:29 PM
03/01/08 05:29 PM
How much different is the Tiger main from a custom square top? Could you put a used Tiger main on a Hobie 17? Could you also add the spinnaker?
Re: Hobie 17 square top [Re: Timbo] #134122
03/01/08 05:40 PM
03/01/08 05:40 PM
A Tiger's mast is about 3' longer than a 17's and the sail luff is probably 18" longer. The foot of the Tiger's sail doesn't have the "upsweep" that a 17's boom requires - it's fairly level.
You'd have to remove the hook on the Tiger headboard, too.
Other than that, it's a perfect fit. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
The 17's bows are very tender laterally - that's why a bow foil is used on the sport version. You'd have to be very careful with the spin that you didn't overload the bows.
Re: Hobie 17 square top [Re: ] #134123
03/01/08 08:29 PM
03/01/08 08:29 PM
Sorry Attachment didn't take. It was a BAD boy!!! Have a custom one made, Pentex is real nice.
Doug
Re: Hobie 17 square top [Re: mbounds] #134124
03/01/08 08:31 PM
03/01/08 08:31 PM
Bernhards Bay, N.Y.
popeyez7 Offline
popeyez7  Offline
Bernhards Bay, N.Y.
Here's my 17 Hobie with a ''super jib''~(from Murrays).
I don't have a square top, but it goes.. I don't think it's a good idea to put a ''spin'' on it. I've been told the mast wouldn't take the load unless ya have ''diamond wires'' Alotta stress on the hulls to, they are tender <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION''
~17,18 Hobies,
~Jet boat~Speedster 150
~2 Kayaks~
~~~~VIETNAM VET. 69-71~~~~
Re: Hobie 17 square top [Re: popeyez7] #134125
03/01/08 08:36 PM
03/01/08 08:36 PM
I also had a custom reacher made for mine. Sabre should have the specs some where.
Doug
Re: Hobie 17 square top [Re: Timbo] #134126
03/04/08 04:45 PM
03/04/08 04:45 PM
Dunedin Causeway, FL
hobiephil Offline
hobiephil  Offline
This should answer the question. I have sailed with this spin for a couple of years now, in winds as high as 20 knots. In high winds the main must be centered, the sheet never released, downhaul off.
BTW, yes that is a 14 foot pole and a 235 sq ft chute.
Re: Hobie 17 square top [Re: hobiephil] #134127
03/04/08 05:01 PM
03/04/08 05:01 PM
Brian_Mc Offline
Brian_Mc  Offline
Phil, Did you have to modify the mast to handle the extra load of the chute?
Re: Hobie 17 square top [Re: Brian_Mc] #134128
03/04/08 05:41 PM
03/04/08 05:41 PM
If you add spin, NEVER put it up without main cleated in tight in pretty tight. You will SNAP the computip!!
Doug
Re: Hobie 17 square top [Re: ] #134129
03/04/08 10:57 PM
03/04/08 10:57 PM
TeamChums Offline
TeamChums  Offline
Doug, you should ad that since the 17 has such a skinny tapered comptip that a back stay is recomended. The main sheeted in will only help for so long till the thing grenades on you.
Lee
Lee
Re: Hobie 17 square top [Re: hobiephil] #134130
03/05/08 02:08 AM
03/05/08 02:08 AM
Bay of Islands, NZ
warbird Offline OP
warbird  Offline OP
Bay of Islands, NZ
BTW, yes that is a 14 foot pole and a 235 sq ft chute. [/quote]
Holy crap, that is great! What Chute did you use and how far up the mast is the tang?
How does the boat compete with other cats?
Re: Hobie 17 square top [Re: warbird] #134131
03/05/08 10:15 AM
03/05/08 10:15 AM
hobiephil Offline
hobiephil  Offline
cats? [/quote]
The mast is stock with comp tip, no mods other than the tang for the chute.
The boat is still hibernating at the club, so this is from memory. The tang about 25 ft from the base. The sail is custom from Whirlwind Sails.
The picture was taken during the 2007 Statue of Liberty Race. I made up alot of ground with the chute after being stuck in the Narrows with no air and a foul tide for 45 mins on the upwind leg. I corrected to a 3rd place finish.
Re: Hobie 17 square top [Re: hobiephil] #134132
03/05/08 11:03 AM
03/05/08 11:03 AM
Brian_Mc Offline
Brian_Mc  Offline
Phil, You are an inspiration! Don't know if I'll ever get around to it, but it sure would be fun to run one of those babies on my boat! Thanks !
Re: Hobie 17 square top [Re: hobiephil] #134133
03/05/08 11:08 AM
03/05/08 11:08 AM
Phil - did you make any mods to the forestay / bridles? I notice you don't use a bow foil (like on the 17 Sports) to reduce the lateral compression on the bows.
Also, how tight do you carry the rig? The 17 tends to like a looser rig (so the mast rotates freely). How does that work with the pre-bend in the pole?
Re: Hobie 17 square top [Re: mbounds] #134134
03/05/08 04:02 PM
03/05/08 04:02 PM
Bay of Islands, NZ
warbird Offline OP
warbird  Offline OP
Bay of Islands, NZ
Ditto. I don't want to break the boat but this looks like a very sensible option.
0 registered members (), 672 guests, and 153 spiders.
Posts267,056
