| Re: Do you know for sure your boat won't sink?
[Re: MaryAWells]
#13448 04/15/03 02:23 PM 04/15/03 02:23 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | I just talked to W.F. Oliver, and he said the Bimare Jav 2's are required by law in Europe (as Wouter said) to have a certain amount of positive flotation. In this case, though, because of the size and location of the hole in the boat that was T-boned at the Alter Cup, the flotation was dislodged from where it was secured to the inside of the hull and it escaped through the hole. | | | Re: Do you know for sure your boat won't sink?
[Re: Mary]
#13449 04/15/03 02:40 PM 04/15/03 02:40 PM |
Joined: Jul 2001 Posts: 397 Burlington, Vermont USA Kevin Rose
Posts: 397 Burlington, Vermont USA | I just talked to W.F. Oliver, and he said the Bimare Jav 2's are required by law in Europe (as Wouter said) to have a certain amount of positive flotation. . . Mary, Did W.F. mention what kind of flotation material is used? How is it secured?
Kevin Rose
N6.0na #215
Lake Champlain (New England's "west coast")
Burlington, Vermont
[Re: Kevin Rose]
#13450 04/15/03 03:22 PM 04/15/03 03:22 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Well, Kevin, he told me, but I was not in a position to be paying close attention or taking notes at the time -- and he called on a completely different subject. What interested me is that, as I had supposed, when you add flotation to your hull (not built into the construction), you may have a hard time keeping it inside your hull if you get a big hole. Or, as someone else said in this thread, the flotation, when unattached, can go to one end of the hull or the other and cause a problem of a different sort.
He did say that the Bimare uses foam-core construction and has foam bulkheads but that those alone are not enough to meet the European standards, so additional flotation is put inside the hulls and secured. In this case the foam, of whatever nature, was dislodged and got out through the hole.
I would really rather not be the middle man here, and I think it would be best if W.F. or a factory representative would explain what kind of flotation is installed and how.
And I don't think it is really productive to pick on one specific boat without getting information from as many manufacturers as possible about what they do to make sure their boats won't sink. The Jav 2 just happens to be the one that got captured on film.
Is this really a major problem? I don't think so. How often do you hear of a beach-cat sinking right to the bottom? No reason to blow it out of proportion. But, still, it would be nice to know for sure that your boat will not sink.
I started this thread in the first place primarily because I thought the issue should be addressed in regard to boats that are used in the Worrell 1000. | | | Re: Do you know for sure your boat won't sink?
[Re: Mary]
#13451 04/15/03 03:51 PM 04/15/03 03:51 PM |
Posts: 397 Burlington, Vermont USA | . . . I don't think it is really productive to pick on one specific boat without getting information from as many manufacturers as possible about what they do to make sure their boats won't sink. The Jav 2 just happens to be the one that got captured on film. Mary, I agree. Whenever a new design hits the market, there seems to be a mixed response, ranging from, "Wow that boat's cool", to "Ya, but will that thing hold up to the rigors of hard use like mine". Unfortunately, a single incident like the one at the Alter Cup can sometimes capture the lion's share of attention (like Jensen Beach a couple years back). I was curious about the Jav's flotation because I was wondering if it were anything like what's been suggested in various posts in this thread. As you said, the likelihood of a cat having both hulls compromised is probably slim. One hull full of air certainly would stay at the surface, however flotation that would keep the holed hull at the surface, too, might make the towing/salvage efforts easier.
Kevin Rose
N6.0na #215
Burlington, Vermont
[Re: Kevin Rose]
#13452 04/16/03 06:23 PM 04/16/03 06:23 PM |
Posts: 67 Key Largo, Fl | This link has some shots of the RC boats and the salvage operation. David Billing from the Clearwater Yacht Club did some outstange powerboat driving. Funny thing, we just had some more chunks of the hull wash up on the beach yesterday. 5 days after the wreck! The Salvage operation | | | Re: Do you know for sure your boat won't sink?
[Re: Greg]
#13455 04/20/03 10:21 AM 04/20/03 10:21 AM |
Posts: 397 Burlington, Vermont USA | Kevin, I considered using my canoe floatation bags, but the glass doesn't look too friendly inside my H16. I am afraid that upon inflation it be punctured by the irregularities of the glass inside the hull. What do you think? Greg, H16, H14 That can be a problem. A solution (aside from sanding down the rough bits) would be to only partially inflate the bag so that it isn't held with air pressure against the inside of the hull.
Kevin Rose
N6.0na #215
Burlington, Vermont
[Re: Greg]
#13456 04/20/03 06:30 PM 04/20/03 06:30 PM |
Posts: 1,449 | Greg Another option that could be less expensive would be the bladders from casks of wine. They weigh 50 grams each and displace 4 litres or 4kg of water and they are quite durable. The hard part is finding cask wine that is to your liking.
Regards, Phill
[Re: phill]
#13457 04/20/03 07:16 PM 04/20/03 07:16 PM |
Posts: 397 Burlington, Vermont USA | Greg Another option that could be less expensive would be the bladders from casks of wine. They weigh 50 grams each and displace 4 litres or 4kg of water and they are quite durable. The hard part is finding cask wine that is to your liking.
Regards, Phill Only problem there is you'd have to drink an awful lot of wine to come up with the flotation available in a couple of canoe/kayak float bags
Kevin Rose
N6.0na #215
Burlington, Vermont
| | | And for you that is a problem ?
[Re: Kevin Rose]
#13458 04/21/03 02:23 AM 04/21/03 02:23 AM |
Posts: 9,582 North-West Europe | It's a joke !  Wouter
[Re: Kevin Rose]
#13459 04/27/03 09:36 AM 04/27/03 09:36 AM |
Joined: Jun 2001 Posts: 123 Santa Fe, New Mexico Greg
Posts: 123 Santa Fe, New Mexico | Kevin, That can be a problem. A solution (aside from sanding down the rough bits) would be to only partially inflate the bag so that it isn't held with air pressure against the inside of the hull. I am afraid that even with partially inflated floatation that if a leak occurs, once the hull is full of water pressure will be exerted on the bag. Greg (pessimist) H14,H16 | | | Fill the hulls with empty plastic bottles
[Re: MaryAWells]
#13460 04/28/03 10:37 AM 04/28/03 10:37 AM |
Posts: 1,307 Asuncion, Paraguay | Mary,
This idea is so simple that chances are that someone already wrote about it here (and elsewhere) - please forgive me if this is the case.
It is also not original, not fancy and not the lightest setup - but it works.
For additional safety, tie the bottles neck to neck beforehands. Tying will hold them together, so they aren't lost if the hull is cut in half. And, should it happen, the string of bottles makes for a good flotation aid.
I also learned the following in the discussion site br.groups.yahoo.com/group/altomar/messages (not in English):
The empty bottles are tough because they were designed to take relatively high internal pressures. Participants reported on pets being used as fenders (without cover) and mooring buoys as well.
When higher internal pressure is desired, they put them into the freezer before closing the lid. The cold air then expands, increasing the pressure. Depending on where you are, just leave them outside at night and close the lid in the morning.
Take care!
Luiz
| | | Re: Fill the hulls with empty plastic bottles
[Re: Luiz]
#13461 04/28/03 11:13 AM 04/28/03 11:13 AM |
Posts: 1,459 Annapolis,MD | Participants reported on pets being used as fenders (without cover) and mooring buoys as well.
Should I use my Golden Retriever or one of my cats? I know, I know, I just couldn't resist... | | | Hey Keith !
[Re: Keith]
#13463 04/28/03 12:03 PM 04/28/03 12:03 PM |
Its blond and smart, what is it ?
[Re: Keith]
#13464 04/28/03 03:54 PM 04/28/03 03:54 PM |
Posts: 1,307 Asuncion, Paraguay | Should I use my Golden Retriever or one of my cats? I know, I know, I just couldn't resist... Ecological safe sailing aid: [color:"red"] "Recycle - freeze your pet - make your boat safer" [/color] answering your question: I guess cats suit cats better. For monos, use monkeys.
Luiz
| | | Raising a sunken cat
[Re: Luiz]
#13465 05/09/03 02:55 PM 05/09/03 02:55 PM |
Posts: 2 SW Florida | Once sunk.. If it sinks during the test.. consider making a custom portal attachment and use a CO2 fire extinguisher to force the water back out of the hull. It won't take much to get it back to the surface.
Early model Hobie 18
2,670
guests, and 238
